lg tv 42lv450 does not start
  • Moddingscreen
    • Dec 2017
    • 65
    • Italia
    Good morning everyone is a new user of the forum, I have a small problem with the power supply of a lg EAX62865401 tv, the tv flashes the standby LED and subsequently also the white led and then turn off totally, I checked the voltage 3.5v and it is present but the relay does not attack, what can I do?
    Thank you all for your valuable advice, and excuse my English
  • Moddingscreen
    • Dec 2017
    • 65
    • Italia
    Re: lg tv 42lv450 does not start
    could it be the motherboard?
    • dskall
      • Oct 2016
      • 2905
      • usa
      Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
      Format:
      Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
      1 - XXXXXXX - XXv - XXXv
      2 - XXXXXXX - XXXv - XXXv
      3 - XXXXXXX - XXXv - XXXv
      4 - etc.
      • Moddingscreen
        • Dec 2017
        • 65
        • Italia
        as soon as I return home, I photograph everything, thanks for the help
        • Moddingscreen
          • Dec 2017
          • 65
          • Italia
          Here is the pin situation:
          ERROR 0V
          PWM 0V
          NC 0V
          DRY ON 0V
          VSYNC 0V
          3.5V 3.5V
          24V 0V
          PWR ON 0V
          I forgot to tell you that the relay does not attack
          • dskall
            • Oct 2016
            • 2905
            • usa
            What are voltages when you push power button?
            • freakaftr8
              • Oct 2012
              • 3743
              What is voltage at the main capacitors on hot side of power supply upon pressing power button?
              Link PWR_ON to 3.5v with a 1 ohm resistor on th e P201 connector. You should have relays click and energize power supply. Check capacitor voltages again.
              • Moddingscreen
                • Dec 2017
                • 65
                • Italia
                I measure 1.9v and 320v in attached photo
                • Moddingscreen
                  • Dec 2017
                  • 65
                  • Italia
                  connected resistance as mentioned, the TV now turns on appears the logo lg and then the display remains black
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Screen remains black because you also need to jump PS on to DRV on. If that works and turns on backlights, your mainboard is bad.
                    If back lights come on do you have a blank picture?
                    • Moddingscreen
                      • Dec 2017
                      • 65
                      • Italia
                      what is ps? I have DRV-ON where do I have to connect it?
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Also to the 3.5v
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Nevermind. Your picture shows that it's lighting up is it is stuck on the logo?
                          * Before you had mentioned that it was just blank I didn't see you added the fact that you have a logo and backlights.
                          • Moddingscreen
                            • Dec 2017
                            • 65
                            • Italia
                            then, without connecting DVR ON at 3.5v the TV turns on shows the logo and then remains black without backlight, now I try to connect the DVR ON at 3.5v and I'll let you know
                            • Moddingscreen
                              • Dec 2017
                              • 65
                              • Italia
                              I'm sorry I changed after the message, proceed with connecting the DVR ON to 3.5v?
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Yes try connecting DRV-ON With 3.5v also. It should cause of backlights to remain lit even with a blank screen if it's trying to blank out after the LG logo
                                  You MUST disconnect the DRV-ON wire going back to the main board first otherwise you will damage the switched Transistor on the main board that is in the full on mode right now.
                                  I always use resistor in case you make wrong connection or forget to disconnect the wire back to the main board first.
                                  • Moddingscreen
                                    • Dec 2017
                                    • 65
                                    • Italia
                                    in this way right?
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Yes you will want to remove the drive pin from the connector at the main board side Before powering up
                                      • Moddingscreen
                                        • Dec 2017
                                        • 65
                                        • Italia
                                        with the connection as above, the TV turns on but does not show anything even the logo that I could see for 10 seconds before
                                        • mohsinrizwan
                                          LG TV 49LW5700 does not power no Standby Voltage(PSU EAX62865401)
                                          by mohsinrizwan
                                          I have LG 49LW5700 which is not turning on, when I checked there was no standby (3.5V) can anyone guide how I can trace which component is faulty.
                                          05-28-2022, 10:35 AM
                                        • mohsinrizwan
                                          LG TV 47LW5500 does not power on (PSU EAX62865401/Main board EAX64405501)
                                          by mohsinrizwan
                                          My LED died while checking on PS-ON test not seeing any voltage.
                                          Here is result on PS-ON Pin 1 jump to Ping 9-10-11 or 12 (3.5V)
                                          23 - N.C -> 0V | 24 - ERROR -> 0V
                                          21 - 12V -> 0V | 22 - PWM -> 0V
                                          19 - 12V -> 0V | 20 - N.C -> 0V
                                          17 - 12V -> 0V | 18 - DRV-ON -> 0V
                                          15 - GND -> 0V | 16 - VSYNC -> 0V
                                          13 - GND -> 0V | 14 - GND -> 0V
                                          11 - 3.5V -> 3.52V | 12 - 3.5V -> 3.52V
                                          9 - 3.5V -> 3.52V...
                                          08-02-2020, 01:53 PM
                                        • desone01
                                          Changing Dell Asset Tag
                                          by desone01
                                          I have dug through my Dell utilities and located an old Dell Engineer's program which changes the Dell Asset Tag. I have used this SUITE of programs in the past to amend the Asset Tag on second hand motherboards I have installed.
                                          I don't know if it works with the newer Dell laptops. You should use extreme caution in using these programs. As you can see the program is fairly old one.
                                          Here are the instructions from the README file:
                                          SVCTAG.EXE
                                          Dell Internal Use
                                          09-04-2020, 07:33 PM
                                        • atari1968
                                          LG TV 42LW5700 does not power on fully (PSU EAX62865401/Main board EAX64405501)
                                          by atari1968
                                          My LG 42LW5700 doesn't power on. when tv plugged on the standby light is
                                          a very week until I switch power on then the standby light blinking slowly.
                                          After checking the power supply,
                                          I measured the output voltage after switch on and everything looks okay
                                          Please see the attached picture of the voltage test for the output ports.
                                          So probably the power supply is ok and the problem could be on the mainboard EAX64405501,
                                          The standby led is always very dim until I switch on and then the led start to blink (high and dim not in the same...
                                          08-16-2019, 08:20 AM
                                        • Flasman90
                                          Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
                                          by Flasman90
                                          Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
                                          My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
                                          What I have done so far:
                                          - All of the routine diagnostic methods including...
                                          08-29-2025, 08:38 AM
