Changing Dell Asset Tag
  • desone01
    • Sep 2020
    • 14
    I have dug through my Dell utilities and located an old Dell Engineer's program which changes the Dell Asset Tag. I have used this SUITE of programs in the past to amend the Asset Tag on second hand motherboards I have installed.
    I don't know if it works with the newer Dell laptops. You should use extreme caution in using these programs. As you can see the program is fairly old one.
    Here are the instructions from the README file:
    SVCTAG.EXE
    Dell Internal Use Only
    NOT FOR EXTERNAL DISTRIBUTION
    What does this utility do?
    This utility is used to re-program the system service tag on certain
    Dell Portable systems. The utility may only work on systems which
    already have a service tag programmed. If no service tag currently
    exists, the utility may return an error message and fail.
    To program the service tag on a system that does not already have one:
    - For Value-line systems:
    Run EE-Value.exe /S=XXXXXXX, where XXXXXXX is alphanumeric and all
    letters are capitalized.
    - For SmartStep/Smart PC 200N/250N:
    Run STAG_W1.EXE /W XXXXXXX, where XXXXXXX is alphanumeric and all
    - For Molokai:
    Run SERTAG.exe /W XXXXXX, where XXXXXX is alphanumeric and all
    - For all other systems:
    Run ASSET.COM /S XXXXXXX, where XXXXXXX is the new service tag.
    USAGE:
    Boot from the diskette and follow the on-screen prompts to erase and
    program a new service tag.
    See the comments in AUTOEXEC.BAT on how to automate the process.
    General Information:
    This diskette contains 6 main programs or program types:
    1. SVCTAG.EXE
    2. 6 varieties of EE-ERASE
    - EE-CP.EXE
    - EE-CPA.EXE
    - EE-CPB.EXE
    - EE-LS.EXE
    - EE-LS2.EXE
    - EE-VALUE.EXE
    - STAG.EXE
    - STAG_W1.EXE
    3. 3 varieties of ASSET
    - ASSET.COM
    - EE-VALUE.EXE
    - STAG_W1.EXE
    4. NICSET.EXE
    5. FDD_RCL.EXE
    6. SVCTAG.INF
    1. SVCTAG.EXE is called from autoexec.bat. It is a utility that
    determines if the system on which it is being executed is supported
    by the disk. If so, it determines which type of system it is, using
    the system ID byte. This information is gathered from either SMBOIS
    calls or XBIOS calls, if SMBIOS fails. The utility also uses these
    calls to determine if a service tag is currently programmed on the
    system. If one isn't programmed, there is no need to run EE-ERASE
    so the utility goes directly to the ASSET program.
    2. Based on the information gathered, SVCTAG.EXE launches the
    appropriate version of EE-Erase.
    Each of these utilities can be run stand-alone. For EE-CPA.EXE, the
    -forcetype command line switch may be required.
    3. The appropriate version of ASSET program is then launched.
    SVCTAG.EXE first asks the user the enter the new service tag (twice
    for verification) then passes that value to ASSET when it is
    launched.
    The ASSET programs can be run as a stand-alone utilities as noted
    above.
    4. NICSET.EXE is launched by SVCTAG.EXE after EE_ERASE if the system
    is a Latitude C610 or Inspiron 4100. NICSET is needed in order to
    unhide and enable the onboard NIC, which is disabled by EE-ERASE.
    5. FDD_RCL.EXE is the launched from AUTOEXEC.BAT after SVCTAG.EXE. It
    performs a Recalibrate operation on the floppy diskette drive.
    The purpose of this utility is to ensure the FDD head is moved to
    track 0 in preperation for transport.
    It is important to power off the system immediately after this
    utility is run in order to guarantee the head remains at track 0.
    6. SVCTAG.INF is the text file contains vendor name, system id, ee-erase,
    erase options, asset and asset options. This file is processed
    by svctag.exe. The program goes through this file line by line
    and searches for system id and BIOS vendor string which match the
    system ID and BIOS vendor string read from the system on which
    the utility is being run. If a match is found, the corresponding
    line will be parsed and the executables and command line options
    from that line will be used to erase and program the service tag.
    Supported Systems
    All Dell Portable Systems
    readme.txt
    updated 07/10/03
    I attempted to make a bootable USB Drive with the program using RUFUS, but it didn't work. Others may be able to make the files bootable on a USB. I didn't spend too much time on it as I had a portable USB DVD burner.
    The compressed program is below:
  • gurj1979
    • Dec 2014
    • 186
    Re: Changing Dell Asset Tag
    To make it work in Rufus you must get Rufus to make FreeDOS USB.
    Then copy the contents from the dstcd.zip to the root of the USB.
    Remember to tell the BIOS to use Legacy, it will not work if set as UEFI.
    • amp3d
      • Oct 2022
      Thank you for that, it booted great for me.
      However, is there a new version of the CD that works with newer devices?
      • jogas
        • Oct 2019
        • 17
        • IE
        hi
        by any chance you have other versions to share thanks
        • littlepickle
          • Jan 2023
          Dell Asset/Service Tag BIOS Reset Tool (or DSTCD)
          Does anyone have a copy of this anywhere?
          Or a more up to date DSTCD?
          • littlepickle
            • Jan 2023
            This is what id be looking for
            • Chaminda4191
              Chaminda4191
              • Apr 2023
              • 29
              • Sri Lanka
              After command prompt type Asset /s /d
              it will erase the tag and you can change the tag after loading to bios setup
              EXAMPLE C:\>ASSET /S /D
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
                Dell Thunderbolt Firmware
                by SMDFlea
                Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                The SKU is in brackets (****)
                EDIT: NVM65...
                01-26-2025, 06:22 AM
              • F R 2568
                Dell Latitude 5420 does not start (no post) need help to find the reason why
                by F R 2568
                Hello all,
                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                If the laptop is only connected to the AC adapter (battery removed):
                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                The power/battery...
                01-08-2025, 05:45 AM
