Another LED Strip Head Scratcher.. Sanyo DP42D23
  • Michale32086
    • Nov 2011
    • 1453
    This seems to be my month for weird LED Strip issues..
    I have this Sanyo that I broke down to the bare strips and discovered that the LED assembly is identical to some LGs and some VIZIOs I worked on..
    I used my LED tester to find the bad strips and LEDs and was able to create an array that was fully functional.. No bad LEDs at all..
    STILL wouldn't come on...
    So I cracked open a 47" LED that had a bad display panel. At least I HOPE it did..
    Anyways, long story short (too late!) I have confirmed that the following parts of the LED TV are fully function..
    Power PCB
    Main Video Board
    ALL LED Strips
    Cable that goes from the Power PCV to the Array board..
    The "array board" (green strip that all the LED Strips plug into) seems to be the culprit.. But, near as I can tell, it's just traces and I can't find any breaks...
    Voltages at the 4 pin connector on the array board are solid.. 200v at one testing....
    I am thinking I need to check the voltages at the point where the LED Strips plug into the array board but I wanted to get guidance on what voltages should be present...
    Thanx
    FURTHER INFO: Regarding the pic, the upper array board is from the Sanyo and doesn't work. The lower array board is from the LG and it works fine.. It should also be noted that, lemme see if I can explain this right, the connectors that go from the Power PCB to the array board are inverted.. On the LG, the connector tab on both ends face the same way.. On the SANYO, the connector tabs are opposite..... If that makes any sense
  • Michale32086
    • Nov 2011
    • 1453
    Re: Another LED Strip Head Scratcher.. Sanyo DP42D23
    Here is what I mean about the Power PCB/Array connectors...
      Can we see good clear pictures of the whole power supply/LED driver board?
      The SANYO one: the black wires are more likely to be the Anode of the LED string, the white wires are the Cathode returns.
        I've encountered a set where every LED tests okay on a meter, but the whole setup fails for some reason. Perhaps an LED breaking down as voltage is applied or as it heats up. Odd, though.
        • augiedoggy
          • Aug 2016
          • 62
          • united states
          Ive seen this too... sometimes Ive actually discovered it was just a cold solder joint on one of the leds..
          • CapLeaker
            Leaking Member
            • 8118
            LED's can work even for a while like it should and then go off. They can fail in a weird way and it is very hard to test unless you power the strip up properly on a CV/CC PSU and run it for a little while.
              But he said "STILL wouldn't come on..." I would expect if the LED/LEDs is bad with high drive current then they should at least come on for seconds and then go off, according to the post, they did not come on.
              • CapLeaker
                Leaking Member
                • 8118
                Then maybe measure the LED string voltages at each of the strips and see if LED power actually gets there? Gotta be an open somewhere then.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  I have supplied voltage to LED strips in different TV's especially LG, What normally happens is when I supply an external voltage to test LED strips, one led may light up on that strip however powered with the power supply on a much broader voltage range causing the LED to burn brighter starts to flicker
                    That is why it is important to use CC power supply to test the LED/LED strip due to the fact the if you have a bunch of shorted out LEDs on the strip then the good LED will be forced with lots of current trying to maintain the Vf when using CV power supply.
                    I.E. people see 4 LEDs on the strip so they figure that 4 LEDs x 3V =12V so he is going to use 12V to test the strip, but if two of the LEDs are shorted out then guess what happen when you apply 12V to the strip?
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Thanx for the replies, guys.. Turns out that it WAS a bad cable connector from the array board to the Power PCB...
                      Sorry it took so long to get back on it.. GRRRRRRRR I am NOT a holiday fan.. I would be happy to go from Oct 15 to Jan 16.....
                      Thanx again...
                        Thanks for the follow-up.
                        • edugimeno
                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                          by edugimeno
                          Hi There!
                          I'm trying to help my friend who owns a restaurant be just bought.
                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                          09-05-2024, 09:34 AM
                        • adelage
                          220v Led strip flickering
                          by adelage
                          Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                          I know that the best solution would be to get a voltage...
                          11-03-2024, 09:49 AM
                        • benareeno
                          Adjustable dc power supply and tcl led strip
                          by benareeno
                          I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
                          I have an adjustable dc power supply and was trying around 9 volts.
                          I have a pic of a single diode...where to put pos and neg terminals to light it up?
                          Pic of middle of strip..is this where i light the entire strip?
                          And pic of end...or does this light the entire strip?
                          Where to put pos and neg for single diode..multiple diodes and the entire...
                          07-11-2021, 02:31 PM
                        • mikey5791
                          Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                          by mikey5791
                          Got this working ips led monitor by the brand of
                          Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                          Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                          09-04-2023, 03:50 AM
                        • cj_reha
                          Mystery 80s Sanyo cap - perhaps polymer?
                          by cj_reha
                          Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                          01-06-2023, 09:24 AM
