Samsung UN60EH6000 Tries to come on, but stops
  • Tanko2
    • Dec 2017
    • 5
    • Nigeria
    #61
    Think it should be inverter fault
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      #62
      Re: Samsung UN60EH6000 Tries to come on, but stops
      if you replace the isl9860 make sure there is enough solder on the center pad.
      the 3 i have replaced did not.
      this may also be the cause of the 5 minute shutdown.
      the main path for heat to get out of the chip is through the pad to the boards copper ground plane.adding the sili pads to the chip is not good enough.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4542
        • Italy - Milan
        #63
        Hi, the ISL9860 (IC7100) i think is almost surely bad, after replacement of it one must replace also the power mosfet around it (Q7101) and some diodes (D7106-7 at least) or only the chip and after try heating them all at turn to see which one shortens the working period. And also kc8adu advice is good, ther can be a thermal protection, one can warm up it a bit with the soldering iron before switching on and see the behaviour..
        • Louis82
          • Feb 2012
          • 240
          Thanks for the input guys.
          So, today I went ahead and replaced the same IC on two more 00628C boards that I had defective with same issue, no picture only backlight.
          One of them is giving me the same problem, picture cuts off after 15 min and the other is working fine, 2hrs so far.
          I noticed that the ones that cut picture off, the big IC's in the middle of the board, they get extremely hot.
          Inputs? Should mosfets and diodes cause this?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4542
            • Italy - Milan
            #65
            Louis see the post #53 , test the point R that i think is the dc-dc regulator that feeds power to the processor (vcore) even if i can't judge if is a correct value or have to be a little more, example 1,2v, but 1v is almost typical...
            • Louis82
              • Feb 2012
              • 240
              Hi Davi. It’s 1V
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4542
                • Italy - Milan
                #67
                Or it's drawing to much current due to a intermittent short on the panel...
                • Louis82
                  • Feb 2012
                  • 240
                  All three boards measured 1V. One of this board seems to be doing fine. Tv is still playing. Going for two days of testing now.
                  • karthur
                    • Nov 2015
                    • 150
                    I got the new chip installed along with two new caps. TV still does the same thing when I turn it on.
                    Before, the two caps measured shorted between them, but they are open now even with the new IC in place.
                    @davi.P
                    The points that I measured before for you... can you tell me what they "should" be reading? I am getting some different readings now on points N-T (post #53), but I don't know if what I am getting is good or bad.
                    Thanks,
                    Kirk
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4542
                      • Italy - Milan
                      #70
                      T= IC Supply pins= 12v, N= Switch-In = around 15v, if N not=15 then test the point O, if i understand if N not=15v then O not=15v, unfortunately the complete datasheet is by request, i have requested another D.S. to Texas Ins. for example, as a "hobbyst repairer" , they provide it to me.. i don't know what command that switch..
                      For info:
                      https://www.intersil.com/content/dam...9/isl98602.jpg
                      • karthur
                        • Nov 2015
                        • 150
                        Yea. My "O" is not that value, so I am at lost as what to do next. I double checked that the ic is seated good and there are no bridged points. I have a good magnifing glass, but those points are really tough to see. Maybe I need to get a higher power glass.
                        Might be time to be trying to find a replacement board.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4542
                          • Italy - Milan
                          #72
                          So which readings you have for points N,T,O?
                          • karthur
                            • Nov 2015
                            • 150
                            N=12.7v, T=12.7v, O=18mV
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4542
                              • Italy - Milan
                              #74
                              Hi, the ISL is not switching a the output (pin40,39 AVDD/SWOUT) must be 15v, if O (pin38 of ISL) is 12v is because maybe an output circuit shorted to GND, so measure the N point to GND in ohm, if you see few ohms then something on the panel is sh.c., or maybe the new ISL chip is already shorted (measure in diode test between pin 36-37 and GND, if few millivolts=shorted).
                              • karthur
                                • Nov 2015
                                • 150
                                Tested point "N" to GRD its open, not shorted. I had 12.7V here.... but on the output side (pin 39 or point "O"), there is only 18 MILLI-volts. I agree that this needs to be somewhere between 9.5 to 15 Volts. Ohm tested point "O" back to ground and its open.
                                I looked at the schematic of the ISL9860 and found each point that should be going back to ground. Checking each point back to ground, I get this:
                                Pin 24 (VDC) = 400k ohms
                                Pin 28 (Phase1) = 504
                                Pin 26 (PGND2) = 0.7
                                Pin 7 (PGND1) = 0.5
                                Pin 33 (PGND3) = .5
                                Pin 34 (PGND4) = .5
                                Pin 12 (GHC) = 100k
                                Pin 11 (GHON) = 9.7k
                                I pulled the chip back off the board and tested from each trace around where the ISL9860 sits back to ground to see if anything was closed that shouldn't be. The following pins show shorted to ground, Pin 7,26,33,34. Which makes sense with the schematic of the chip.
                                I wanted to see if the chip itself was shorted, but with the chip off the board, I checked 36 to GND and 37 to GRD. This is open. GND being the center heat sink of the chip.
                                Any other ideas? Right now the chip is not on the board.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4542
                                  • Italy - Milan
                                  #76
                                  Sorry, many errors by me in the last post... both digitation and not.. not a good idea for me to remove the chip again so soon. Since datasheet is not complete, i assumed PVin1-2 was the chip supply pins, but i can be wrong, maybe are only the input of the BUCK1, so remount the chip and check SUPN-SUPP pins (5,9), maybe you can test them in volt also before remount the chip, the better is that you contact intersil (www.intersil.com) and ask him for the datasheet, tell him that you are an hobbyst repairer.
                                  • karthur
                                    • Nov 2015
                                    • 150
                                    I just ordered a replacment board and got that installed. TV works great now, so it is definitely a problem with the T-Con board. The board that I replaced this with is a BN95-00944B (BN97-07663A). This board doesn't have the same ISL9860 chip on it. I was hoping it did, that way I could check some voltages and ohms on the working board and compare that to the non-working board and find the problem.
                                    I may try again to replace the ISL9860 on my original board and see if it works. Since I could not find anything that stands out as being the problem, it might just be my soldering job.
                                    • Cornito
                                      Denon AVR-2700H audio stops while receiver still works
                                      by Cornito
                                      Hello team,
                                      I've got a new issue with a Denon Avr-2700H.
                                      After several minutes working, receiver stops playing sound with a poc eared in the speakers.
                                      Receiver still work and display video with error message on display.
                                      Seems to me that is the main output relay.
                                      I'm looking for the service manual that I can't find for the moment.
                                      Does somebody have it?
                                      Regards...
                                      08-03-2025, 06:10 AM
                                    • karthur
                                      Samsung UN60EH6000 Dump
                                      by karthur
                                      I have a Samsung UN60EH6000 that will not turn on. When I turn it on, no start-up melody. Only the screen flickers around the edges. I have replaced the T-con board, but issue persists. I have also checked the voltages on the power board and they seem to be correct.
                                      Power Board: BN44-00500A
                                      T-Con Board: BN95-00944B
                                      Main Board: BN94-05549E
                                      I have pulled off the chip IC901 on the main board. This is a Winbond W25Q128BVFG Chip.
                                      My bin dump is below. Can someone look at this and see if this is good or bad file?
                                      12-16-2023, 02:11 PM
                                    • karthur
                                      Samsung UN60EH6000 wont come on after lightning strike.
                                      by karthur
                                      We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                      I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                      When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                      Here is what I have checked.
                                      On the power supply board, 14pin connector:
                                      1 :12.7 Vdc
                                      3 :12.7
                                      5 :12.7
                                      7 :12.7
                                      9 :0
                                      11 :5.
                                      13 :5....
                                      11-01-2023, 06:18 PM
                                    • 6BW6
                                      Win7 Performance test stops
                                      by 6BW6
                                      I had a dodgy Molex Sata lead go bad that cause crashes once in a while, after repairing all is well with no crashing BUT.... Windows performance test stops. I get-:
                                      Problem signature:
                                      Problem Event Name: APPCRASH
                                      Application Name: WinSAT.exe
                                      Application Version: 6.1.7601.17514
                                      Application Timestamp: 4ce798fc
                                      Fault Module Name: atiuxp64.dll
                                      Fault Module Version: 8.14.1.6463
                                      Fault Module Timestamp: 56254af6
                                      Exception Code: c0000005
                                      Exception Offset: 000000000000dc14
                                      OS Version: 6.1.7601.2.1.0.256.48...
                                      05-29-2023, 04:21 PM
                                    • someonenotyou
                                      Lenovo A485/T480 USB stops working when USB2.0 is plugged.
                                      by someonenotyou
                                      Hi.
                                      I have 2 Lenovo laptops (A485 and T480) with identical USB problem.
                                      When I plug in a USB 3.x device (USB storage), the USB ports are working normal.
                                      But as soon I plug in USB 2.0 device (mouse, USB storage), all the USB ports stop working. Even if I plug in USB 3.x device.
                                      The only way to get USB working again is disconnect battery and reset BIOS.
                                      Has anyone had anything similar?
                                      I have not yet tried another BIOS, but would that be the problem with USB?
                                      Thank you.
                                      03-19-2025, 12:15 PM
