Samsung LN46C610N1F no backlight
  • Danstona
    • Dec 2017
    • 48
    Re: Samsung LN46C610N1F no backlight
    Ok, so I am seeing -14.87vdc on what I believe is the VCC leg. Tracing it on the board it connects to CP818
      You mean +14.87VDC if you use the negative leg of the main filter cap as the GND REF. for the meter.
      If it is then that IC is not working because it has VCC but it is not running.
      • Danstona
        • Dec 2017
        • 48
        Ok, I put negative lead to tv chassis and positive to VCC, my Fluke meter read -14.87. I don't feel comfortable crossing sides with the meter leads when the board is lifted and loose.
        If this IC is bad, before I go replacing it and CP820.. could there still potentially be other problems? I don't want to end up rebuilding the entire PSU if a working replacement is available. I'm also playing around with a 50" LG that I need to open, and see what parts may be required while ordering.
          You are working in the hot side of the circuit so you cannot use chassis as the GND ref. for your meter, the Negative leg is the GND ref. for the meter, that is why it should not be negative Voltage as your report.
          At this point you may be better off buying a working replacement board.
          Do you have tools to do surface mounted repair works?
          • Danstona
            • Dec 2017
            • 48
            I do not and have not ever attempted surface mount repair work. I just have a regular adjustable temperature iron. If we're fairly certain that the PSU is the issue, then I'll order up a replacement since I cannot properly fix.
            • Danstona
              • Dec 2017
              • 48
              On second thought, what would be the best preferred tools to properly repair this? Shopjimmy doesn't say its not available, but when you click on it its out of stock... I'd really like to salvage the set rather than toss it.
              Basically looking for suggestions of soldering iron etc.
                At this point we know that we have PS-ON but the PFC circuit did not operate so without boosted Voltage then you will not have the backlights.
                We do not know the condition of the main board and the T-CON board unless you can see the image on the screen using the flash lights.
                You will have to practice on some junk board first before attempting on the real board otherwise you can damage the traces.
                • Danstona
                  • Dec 2017
                  • 48
                  I can do that. I just need advice on the best iron to buy. The picture is there with flashlight. So input board and tcon seem to be operating.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #49
                    shopjimmy do a repair kit for this board
                    https://www.ebay.com/itm/Samsung-BN4...-/361606113610
                    • Danstona
                      • Dec 2017
                      • 48
                      thanks but no parts in this kit are of the defective ones
                        The kit is for xxx340B, your board is xxx341B.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #52
                          sorry op not sure why in my search that wrong board number came up.
                          • Danstona
                            • Dec 2017
                            • 48
                            budm, how do I go about finding that IC on digikey to order, like value. Along with the CP820.. and maybe get that CI818 just incase for future.
                              The schematic gives you the P/N of the IC and the value of the cap.
                              • Danstona
                                • Dec 2017
                                • 48
                                I did a search for the fan7530 they come up with an MX at the end, is that compatible thats my only concern...
                                • yshraybm
                                  • Jan 2023
                                  Did you ever figured it out? I too have blown CP820. Was it just capacitor or was it more to it?
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    #57
                                    throw a new one in there and try it.
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • ermals
                                      Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                      by ermals
                                      Hi all!
                                      I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                      1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                      2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                      3. I've checked voltages...
                                      08-01-2022, 10:35 AM
                                      09-07-2024, 05:50 AM
                                    • Nicktronic
                                      Samsung Power Supply Board BN44-00874F
                                      by Nicktronic
                                      Hey everyone,
                                      This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                      Anybody...
                                      03-17-2025, 06:20 AM
