Lg 60uf770v 4k screen problem
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4363
    • Italy - Milan
    #41
    Re: Lg 60uf770v 4k screen problem
    No datasheet for that sorry.. i try searching the SM...
    edit: no sm too..
    • london-freddie
      • May 2015
      • 472
      sent you a pm darren
      • daz2206
        • Oct 2013
        • 50
        #43
        Mainboard arrived today and tv is now working perfectly. Thank you all for your help
          Nice, thanks fir the update.
          • mmccomputer
            problem with replacing lcd screen
            by mmccomputer
            I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
            otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
            If anyone has any information on the subject...
            12-15-2024, 03:44 PM
          • jimjoe123
            LCD TV Green/Pink screen problem
            by jimjoe123
            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
            Then each time...
            02-23-2020, 01:29 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • alltvrepairs
            Lg TCon test pins for screen test
            by alltvrepairs
            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
            Appreciate your help....
            06-13-2025, 06:33 AM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
