RCA(Proscan) with two seconds of backlight
  • Chuper
    • Sep 2017
    • 36
    Model: RLDED4633A-D
    Main board: TP.MS3393.PC821
    There is 10 led light strips with 6 led on each divided between two connectors/lines, so 30 on each connector/line in series, total of 60 led. 21 of these led were open. I changed all open ones. Now I got backlight for about 2 sec. It measures about 145V on two white connectors for led lines for a second without load and climbs up to 75V and slowly drops with them connected when they all briefly come on. I tried checking all strips separately with a power supply applying 20.4V to each and each read about 200mA on my ammeter.
    Any suggestions on what the next step could be would be greatly appreciated.
  • CapLeaker
    Leaking Member
    • 8070
    Re: RCA(Proscan) with two seconds of backlight
    Not sure, but on your last picture is seems to me that some 20 or so LEDs are brighter than the others? The LED backlights are driven in current mode. So if the LED controller sees a mismatch in current on what the LEDs should draw and what they actually do draw, the LED controller senses that there is an error in the circuit or with the LEDs and it will shut itself down. Above that red cap CB325 is a little IC. What is the number on it? Should have something similar like OB3350CP. Pull up the spec sheet and see what happens around the pins. These have OVP, OCP, UVLO etc.
    Something else you could try is to turn the backlights waaaay down to next to nothin and see if they stay on. The problem is that there still could be a bad LED hiding, that works for seconds and measures good, but once it gets hot it fails. That's why when that many LED's (like 20 of them) fail, replace them all...
    • Chuper
      • Sep 2017
      • 36
      On some of the strips I replaced just one of them and on some as many as four but testing them individually they all lid up evenly and draw same current. That little IC is AS358M.
      "Something else you could try is to turn the backlights waaaay down to next to nothin and see if they stay on." - maybe not exactly smart question but how do I do this?
      Thank you CapLeaker for you help
      • CapLeaker
        Leaking Member
        • 8070
        Well... that's the wrong IC... that would be a dual op amp. I am looking for the backlight PWM.
        You have to turn the backlight down, in the menu settings / picture of the TV. Problem is you have no backlight, so you may have to shine a strong flashlight into the screen.
        "It measures about 145V on two white connectors for led lines for a second without load and climbs up to 75V and slowly drops with them connected when they all briefly come on."
        Could you explain that a little better? We want the exact voltages from each string with the backlights connected.
          We need the Voltage readings of the other two pins also, we know that 2 of the 4 pins are for the LED+ for feeding the Anode of each LED string, we now need the Voltage on the return pins to see what you have, you will have to leave the black probe on the chassis and read probe on the pin then turn on the TV while watching the meter to see what Voltage get, then turn off the TV and move the probe to another pin of the connector and repeat the same procedure, all this is done with EVERYTHING connected.
          When there is no load the Voltage went up to 145V and then it goes into protection shutdown due to no LED's connected so the Voltage drops back down to 75V.
          30 LEDs per string so the Vf of the LED string will be about 90V + Vdrops of about 20V on the PWM controlLed MOSFET, so the output Voltage at the LED connector with working LED connected should be around 110VDC or so.
          • Chuper
            • Sep 2017
            • 36
            So I went to check voltages on LED- (cathode) against chassis. I don't believe in magic but it does work now. Here are voltage readings after TV powers on:
            Connector 1: LED- 0.842Vdc; LED+ 99.7Vdc
            Connector 2: LED- 0.885Vdc; LED+ 99.7Vdc
            So the question is what did happen that it works now after a day of rest?
              We cannot tell because we did have all the Voltage readings of all the pins with LED connector in place when you were having problem.
              But make sure to turn down the backlights level (not Brightness)to as low as you can
              • Chuper
                • Sep 2017
                • 36
                budm are you referring to a setting in a TV menu?
                  It should be in one of the user on screen setup page.
                    It does not look like it has one, so you may have to try 'Picture Mode' to see if one of the setting will reduce the backlights level or not, otherwise you can expect the LEDs to fail again since they drive them at max rating.
                    • Chuper
                      • Sep 2017
                      • 36
                      I did go through the menu and looks like there is no way to lower backlight level. Thank you budm for the manual. I guess this thread came to it's end.
                      P.S. amazingly helpful forum you got here guys!
                      • CapLeaker
                        Leaking Member
                        • 8070
                        That is correct, there are some RCA models that one can't adjust the backlight level. I've ran into this once before a few years ago. I've just remembered because you said it. Why things are working now, I could be still a faulty LED, could be a dirty or bad connection somewhere, a cold solder joint, something along that line. I am glad you got it working for now.
                        • Pygo86
                          Liyama G-Master GB3466WQSU-B1 - Backlight on - Shutdown after a few Seconds
                          by Pygo86
                          Hey Folks,
                          i'm not far into Monitor troubleshooting. It's my first time. Normaly i try to repair Laptops.
                          The Monitor is powering up. And the Backlight turns on. After a few Seconds the Backlight shuts off and the Power LED turns form Blue to Red.
                          I can power it up again, but it's always the same Result.
                          No Matter which Connection is used.
                          I can't see anything obvius after disassembling. No Heatspots with the Thermalcam visible.
                          The Powerboard is looking great. There is 12V and 5V everywhere on the Logicboard.
                          So, i decided to swap that Logicboard....
                          03-04-2024, 11:38 AM
                        • alpersen
                          Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
                          by alpersen
                          Hello
                          Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
                          07-25-2024, 12:50 AM
                        • DanPoka
                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                          by DanPoka
                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                          02-15-2025, 05:05 AM
                        • Comp_Pro
                          No Backlight Macbook A1990 820-01041
                          by Comp_Pro
                          Hello all,
                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                          Tests performed:
                          There is no backlight even with a good screen.
                          Backlight IC is receiving the correct support voltages.
                          Fuse F8400 ok
                          Current sense resistor R8400 ok
                          Backlight IC is receiving 3.3V on enable pin.
                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                          Backlight IC receiving 5V from PP5V_G3S
                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                          05-06-2024, 10:23 PM
