Liyama G-Master GB3466WQSU-B1 - Backlight on - Shutdown after a few Seconds
  • Pygo86
    • Oct 2022
    • 13
    • Deutschland
    Hey Folks,
    i'm not far into Monitor troubleshooting. It's my first time. Normaly i try to repair Laptops.
    The Monitor is powering up. And the Backlight turns on. After a few Seconds the Backlight shuts off and the Power LED turns form Blue to Red.
    I can power it up again, but it's always the same Result.
    No Matter which Connection is used.
    I can't see anything obvius after disassembling. No Heatspots with the Thermalcam visible.
    The Powerboard is looking great. There is 12V and 5V everywhere on the Logicboard.
    So, i decided to swap that Logicboard. But it's the same Result again.
    I can't find any Schematics online and everything looks great under my Microscope.
    What would you say? T-Con or Powerboard?
    I would say it's the T-Con Board, but some Sources will say, if the T-Con Board is Bad, there are Multiple Line and Screen Errors Visible.
    Any Advices?
    Greetings from Germany
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • sew333
    Pc shutdown, monitor flickered with no signal after 10 seconds
    by sew333
    My pc:
    10850K stock 4800mhz stock Kraken X73 good temps
    2x16 GB DDR4 GSKILL 3000mhz XMP
    Seasonic Tx-850 Ultra Titanium
    Gigabyte Rtx 3090 Gaming OC
    Aorus Z490 Pro Gaming
    1 TB SSD
    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
    Power...
    02-22-2022, 10:27 AM
  • alpersen
    Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
    by alpersen
    Hello
    Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
    07-25-2024, 12:50 AM
  • DrFalken
    Dell Inspiron 5593 shutdown after 5 seconds
    by DrFalken
    Hello everyone!
    Motherboard model: FDI55 LA-J081P
    Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
    I found and replaced a shorted MOSFET (PQZ3).
    Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
    BIOS has already been updated (both 64MB and 128MB IC)
    +3VALW and +5VALW are still present.
    +VCCIN = 1.8V stable (measured on PLZ1 at power up)
    Abnormal readings:
    PLZ1 to GND = 0 Ohm
    PLZ2 to GND = 0 Ohm
    04-09-2025, 10:45 AM
  • jmartins
    LG 55UC970V-ZA: vertical bands/lines appear after ~2 seconds, then clear, repeating
    by jmartins
    I have an LG 55UC970V-ZA (around 10 years old). The picture is normal right after power-on, but after ~2 seconds vertical bands/lines appear across the screen. Then it clears again, and the issue repeats in a cycle (roughly every 2 seconds).
    Symptom (repeatable):
    - After power-on, the picture is normal for about ~2 seconds.
    - Then vertical bands/lines appear across much of the screen.
    - It happens on everything, including the LG boot logo and the TV’s own menus/OSD, built-in apps, and all HDMI inputs.
    - Power-cycling (unplugged...
    01-10-2026, 07:58 PM
