LG 43LH604V - suspect Panel or TCON fault
  • pic_whiz
    • Feb 2014
    • 36
    • United Kingdom
    Hi All,
    Please see attached photo - does it look like a panel fault or TCON issue.
    Cheers,
    Matt
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 43LH604V - suspect Panel or TCON fault
    Panel fault in my opinion
    • diif
      • Feb 2014
      • 6978
      • England
      The panel is cracked.
      • pic_whiz
        • Feb 2014
        • 36
        • United Kingdom
        Thanks guys, much appreciated.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4325
          • Italy - Milan
          Obviously CRACKED!
          • nagaraju.g
            • Nov 2016
            • 3
            • india
            Originally posted by pic_whiz
            Hi All,
            Cheers,
            Matt
            panel
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • AK_777
              Sony KD-65A1 Repair – 4 Red Blinks Error
              by AK_777
              Hi everyone!
              I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
              Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
              02-20-2025, 04:15 PM
            • mmartell
              General Questions on the Relationship Between Mainboard, TCON and Panel
              by mmartell
              My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
              I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
              And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
              01-06-2024, 01:32 PM
            • Lee M.
              Amazon Fire TV Omni K24NE5 tcon or panel bad?
              by Lee M.
              TV came on with BL on but blank screen. Disconnected one of the ribbon cables from tcon to panel driver board and now I have half of the screen working normally. Any way to tell if the problem is with the tcon or the panel driver board or the panel itself? Should I just replace the tcon and see what happens?
              05-12-2023, 05:47 PM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
