LG 43LH604V - suspect Panel or TCON fault
  • pic_whiz
    • Feb 2014
    • 36
    • United Kingdom
    Hi All,
    Please see attached photo - does it look like a panel fault or TCON issue.
    Cheers,
    Matt
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 43LH604V - suspect Panel or TCON fault
    Panel fault in my opinion
    • diif
      • Feb 2014
      • 6978
      • England
      The panel is cracked.
      • pic_whiz
        • Feb 2014
        • 36
        • United Kingdom
        Thanks guys, much appreciated.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4465
          • Italy - Milan
          Obviously CRACKED!
          • nagaraju.g
            • Nov 2016
            • 3
            • india
            Originally posted by pic_whiz
            Hi All,
            Cheers,
            Matt
            panel
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • netgearnetgear
              TCL 43S423 TCON OR PANEL FAULTY???
              by netgearnetgear
              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
              08-20-2025, 06:04 PM
            • AK_777
              Sony KD-65A1 Repair – 4 Red Blinks Error
              by AK_777
              Hi everyone!
              I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
              Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
              02-20-2025, 04:15 PM
            • iglitare
              by iglitare
              09-04-2025, 07:13 AM
