Samsung Distorted Screen
  • fire84rescue
    • Aug 2017
    • 29
    Samsung hps5053x/xaa. Anyone have any idea of what could need to be replaced?
  • koka0011
    • Apr 2013
    • 30
    • Sri Lanka
    Re: Samsung Distorted Screen
    clean the lvds cable first.then replace jumper coils on main board.L coils.if nothing happens change the tcon board
    • fire84rescue
      • Aug 2017
      • 29
      Took the cover off...found two caps swelling...would this be the reason for the red and green dots all over the screen
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        They would need to be replaced whether they are or not and they are cheap enough. Replace with high temperature, low ESR capacitors.
        I would also check all the solder joints on the board and make sure they are good.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          If you run with two threads on this it will be confusing.
          • fire84rescue
            • Aug 2017
            • 29
            Ok sounds good. Do you believe all the dots could be caused by the capacitors swelling?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Clean all that dust off, too. That looks like X-Board issue to me. That's the board on the right side looking from the back.
              • fire84rescue
                • Aug 2017
                • 29
                Yes I have taken care of the dust now. I have two caps swollen (not on the X Board). I am going to replace the caps and then look into the X board. Anything in particular on the x that I should be looking for?
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Basically cold solder joints, and measure the ESR on the e-caps on the X-Main and Y-main Bds. Measure the Vs, Va Ve, Vsc and Vy voltages and make sure they are in line with the voltages on the label.
                  • fire84rescue
                    • Aug 2017
                    • 29
                    I have found "working" X boards on Ebay really cheap. Y boards, not so much. I may just order an X board and go from there. I have been picking up so much time at work it is becoming hard to get to what I need to do at home. I have found a few x boards under $20, so that wont be much of a loss if that doesn't fix the issue.
                    • fire84rescue
                      • Aug 2017
                      • 29
                      Well, replaced the caps and screen is still jacked. May have to just order an x board anyway...
                      • fire84rescue
                        • Aug 2017
                        • 29
                        Well, I replaced the X board and the green and Red snowy screen is still there!!! Does anyone have any idea what it could be still?
                        • fire84rescue
                          • Aug 2017
                          • 29
                          Looks like this one is going in the trash! Anyone need any parts before hand?!? I haven't had luck fixing it so bye bye!
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Ok this is an LCD tv. Does not use an x board. X board is in a plasma tv. This honestly looks like an issue withh the eeprom on the mainboard.
                            Mute 1-8-2 power. Do this on thhe remote with the tv off. Look in service menu for lvds settings. Possibly someone got into menus and messed with it? Lvds bit rate possibly.
                            Btw I see your in Deleware. Did you feel that earthquake?
                              https://www.badcaps.net/forum/attach...1&d=1509508932
                              It is Plasma TV.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Oh stupid me .lol I thought it said LNT.
                                For.some reason I'm not able to view pictures lately.
                                But I would suspect something going on with y sustain. Have you measured all voltages yet? What's your VSCAN reading?
                                • fire84rescue
                                  • Aug 2017
                                  • 29
                                  Nope, I didn't feel the earthquake. I am southern Delaware almost to Ocean City Md. I know several people who did though.
                                  • Chrissygizmo
                                    by Chrissygizmo
                                    02-10-2025, 12:33 AM
                                  • Chrissygizmo
                                    samsung galaxy ao2s very temperamental after screen replaced
                                    by Chrissygizmo
                                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                    Ive eventually managed to get it on and working but it's very temperamental...
                                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                    05-26-2024, 12:05 AM
                                  • Kiberge
                                    Samsung LH82QENELGC/EN Help needed - Static line on screen
                                    by Kiberge
                                    HI guys!
                                    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                    04-22-2024, 11:28 AM
                                  • Ryan.man
                                    by Ryan.man
                                    02-04-2025, 12:23 PM
                                  • arbitarytwist
                                    Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                    by arbitarytwist
                                    Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                    Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                    03-01-2025, 01:16 PM
