Samsung hps5053x/xaa. Anyone have any idea of what could need to be replaced?
Samsung Distorted Screen
Re: Samsung Distorted Screen
Yes I have taken care of the dust now. I have two caps swollen (not on the X Board). I am going to replace the caps and then look into the X board. Anything in particular on the x that I should be looking for?Last edited by fire84rescue; 11-02-2017, 10:11 AM.
Basically cold solder joints, and measure the ESR on the e-caps on the X-Main and Y-main Bds. Measure the Vs, Va Ve, Vsc and Vy voltages and make sure they are in line with the voltages on the label.Last edited by Andrew F. Ali; 11-02-2017, 11:30 AM.
I have found "working" X boards on Ebay really cheap. Y boards, not so much. I may just order an X board and go from there. I have been picking up so much time at work it is becoming hard to get to what I need to do at home. I have found a few x boards under $20, so that wont be much of a loss if that doesn't fix the issue.
Ok this is an LCD tv. Does not use an x board. X board is in a plasma tv. This honestly looks like an issue withh the eeprom on the mainboard.
Mute 1-8-2 power. Do this on thhe remote with the tv off. Look in service menu for lvds settings. Possibly someone got into menus and messed with it? Lvds bit rate possibly.
Btw I see your in Deleware. Did you feel that earthquake?Last edited by freakaftr8; 11-30-2017, 11:14 PM.Did I leave the soldering iron on?
Oh stupid me .lol I thought it said LNT.
For.some reason I'm not able to view pictures lately.
But I would suspect something going on with y sustain. Have you measured all voltages yet? What's your VSCAN reading?Last edited by freakaftr8; 11-30-2017, 11:27 PM.Did I leave the soldering iron on?
