panasonic tx-55ax630b no backlight
  • sordids999
    • May 2013
    • 2158
    hello guys
    has anyone come across this fault i`m leaning towards a faulty led but just wanted confirmation on this first
    symptons:
    The back light blinks once but still no picture or back light
    voltages on the PSU
    SRV 5.1v =4.9 volts steady
    SRV 32v =0.0 volts but 32v once tv first turns on then drops to 0
    SRV 16V =0.0 volts nothing even when tv is turned on
    SRV VLED = 70v once tv turns on but drops to 32v then slowly decreases
    thanks
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: panasonic tx-55ax630b no backlight
    Is that a pico fuse alongside SRV-16?
    • sordids999
      • May 2013
      • 2158
      I thought that myself and tested all fine
        It looks like you have 6 LED strings so it has 6 power MOSFETs mounted on the heatsink for the LED current return controllers.
        1) TV off, black probe on the chassis, Red probe on one of the six black wire of the LED connector, turn on the TV and record the Voltage reading.
        2) Repeat the procedure as in step 1 on the other 5 black wires.
        3) Report all six readings.
        BTW, please provide straight shot picture of the top and bottom side of the power supply board.
        • sordids999
          • May 2013
          • 2158
          P6 led connector has 7 black wires
          black pin 1 jumps to 36v when tv turns on then decreases
          black pin 2 jumps to 36v when tv turns on then decreases
          black pin 3 no reading
          black pin 4 jumps to 36v when tv turns on then decreases
          black pin 5 jumps to 36v when tv turns on then decreases
          black pin 6 jumps to 36v when tv turns on then decreases
          black pin 7 jumps to 36v when tv turns on then decreases
          pictures attached so im thinking its pointing to a bad led ?
          • sordids999
            • May 2013
            • 2158
            i cant seem to get the pictures to face upwards
            • singingfish
              • Apr 2017
              Same tv.
              Same problem.
              After trying changing the 3 boards I gave in and took it to a local repairer.
              He found one faulty LED. he changed this out and the TV was fine for a week or so. Today
              Apparently this TV will detect a return current outside the tolerances specified for the back lights, shut down the whole set as soon as it detects it and do a slow single red light blink to indicate this. Maybe something to do with the control needed for the fancy adaptive backlighting where it can dim areas for better blacks, I think?
              Today the same fault is back. BALL ACHE :-(
              I'm now assuming the back light strips just have so many full brightness hours on them that they're going to ping out one by one. I bought the TV as used, not working as a project.
              So I'm going to source and replace all the LED strips.
              Wish me luck with the big screen and not breaking it.
              Matt
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                I got the same model and yes a single blink is a LED fault.
                Im waiting for the leds to arrive. I bought just the led's and not the strips because with strips you dont know the history......
                These models have a plastic lens on top of the LED , it is very easy to get it off and put it back on. ( clicking system ).
                Ps , why would you have backlight full on? It is best to set it with every led tv on 50/60%.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  yes i would replace all the leds like above post who knows how long second hand strips would last unless your thinking of buying brand new led strips.
                  • LOPT
                    • 7
                    • England
                    Did any of you fix the problem by fitting new leds ?
                    To budm.. what was your verdict on the voltages the OP reported back to you..?
                    I have the 1 second Red blink. On power-up the psu gets switched off except for SRV- 5.1v.
                    Service Manual says 1 blink code can be P, A or Panel.
                    I removed the power board and on the bench fed the 3.3v feedback voltage and all voltages were steady and correct. As the backlight flashed on power-up i thought it must be a faulty A board so changed it. Now the set goes to standby on power-up whereas before it would just blink fast green then single red. I don't usually work on Tv's so any pointers for testing / changing leds would be welcome. Obviously i can discover by doing but advice is always welcome.
                    SM is very vague but mentions testing panel by pressing set & remote buttons to confirm or rule out a panel or A board fault. I tried but nothing happened..! There must be a better service manual somwhere!
                    Tony
                      Those Voltage readings on the Black wires which are the Cathode return wires look to be perfectly match at 36V which does not make sense to me since we dealing with more than one string so I expect the bad string to show different Voltage reading, the red wires are all tied together to feed the Anode of the LED strings.
                      Do you have any LED tester to test each LED string?
                      What Voltages do you get if you perform the same test?
                      • LOPT
                        • 7
                        • England
                        Thanks for the reply and clarifying..
                        I have a lot of test equipment because i work with radio comms but i don't have a dedicated LED tester as i don't work with Tv's. However i did think last night that i would try to test those strings by supplying the necessary voltage directly from an external supply. I also thought i could do another test by supplying the 3.3v feedback voltage to the smps via a diode to see if i could force a start and maybe then see what the problem is either by magic smoke or partial backlight.
                        Also thought to temporarily disable the protection circuits signal but need to study the schematic more first..
                        Was busy all day so only just onto the forum now. Will test those voltages and let you know. I know they will only appear for a second before the sos takes over and shuts everything down.
                        I'm presuming supplying 36v to the strips in turn will be adequate ?
                        • LOPT
                          • 7
                          • England
                          Just got chance to take those voltages this evening...
                          There are 7 Black return wires on my TX-55AX630B
                          Measuring the peak voltage was difficult because shutdown was fast so the following may be averages..
                          They read as follows:-
                          25v
                          25v
                          <4v
                          25v
                          25v
                          25v
                          25v
                          All Red wires show 36v.
                          Supplying an external 3.3v to keep the smps alive worked but the PWM chip initiated a shutdown as i found out..
                          I have no idea how many l.e.d strips this set has but from what you say can i presume it has 7 and do those voltage suggest one is bad..?
                          Thanks in anticipation
                          Tony
                          • LOPT
                            • 7
                            • England
                            HI budm..
                            Do you have any thoughts about the voltage results you asked about..? (posted above)
                            Does the 3rd result show a bad string.. or is the <4v as expected..?
                            rgds
                            • LOPT
                              • 7
                              • England
                              I've now found and fixed the problem.
                              This models back-light has 7 rows of l.e.d.s
                              Each row has a left & right string of 7 l.e.d.s. So each row has 14 l.e.ds making a total of 98 for the complete back-light. The left & right strings are wired in series.
                              7 mosfet drivers power the back-light through 7 pairs of Red & Black wires.
                              If any Black wire return current is low it means there is a problem on that row (at least one l.e.d has failed).
                              If the l.e.d is open then the whole string will be down and so you will need to test each l.e.d individually. 20v is enough to test each string initially to find the faulty one(s). I set a power supply to 20v @ 150mA which is enough to light the good strings without blinding yourself.
                              Replace faulty l.e.d.s with 3v types.
                              Taking a large panel apart is not for the faint hearted so make sure you support the panel glass and LCD properly. Remove all the countersunk edge screws and then release the plastic surround which is held on with a multitude of catches that will catch again as they did with me so another pair of hands would be useful at this stage. I didn't have this luxury but managed anyway.
                              If doing this alone it's best to reduce the weight by removing all the boards first and the metal pieces where the stand fit to so you dont damage the pcb edge of the LCD.
                              Everything is glued in place. The back-light has a White thin plastic reflector glued to the metal chassis which needs careful removal using a sharp knife around the edges and some careful pulling.
                              Once removed the l.e.d strings can be tested in situ to find the bad one(s).
                              The strings are also held tightly in place with thin double-sided tape which will tear easily so take it easy and you wont need to renew it. Also be careful because the string pcb is very thin. You don't want to damage it.
                              Pry off the l.e.d diffuser with a knife.. fit a new l.e.d and before re-gluing the diffuser clean the old glue from both the diffuser and the pcb to ensure the diffuser sits flat otherwise you risk a bright spot on your screen.
                              The Red standby light 1 second flash every 4 seconds points to this fault although obviously a failed smps could do the same but in most cases suspect the back-light.
                              Tony
                              • zomi
                                • Nov 2011
                                • 508
                                Best to redo all the leds, avoids running into the same issue again, mileage varies on replacing only the bad led.
                                  Good job finding the problem, sorry I was too busy to follow all the threads.
                                  • LOPT
                                    • 7
                                    • England
                                    Yes i agree.. I've bought 100 but it's going to be a tedious job..
                                    Cheers.. and thanks for the initial info which got me thinking on the right track
                                    Tony
                                    • BaHa
                                      • Jun 2016
                                      • 4
                                      • Ireland
                                      Hey guys
                                      I have the same problem as Tony!
                                      I just wanted to ask if there is any easy way I could "fool" the board into thinking that there is a good LED strip in place of the faulty one?
                                      I disconnected the faulty on from the connector and tried using 2 small pieces of 24V strips in series, but that is probably not enough current.
                                      Any idea what sort of current is the TV expecting?
                                      Just wanted to prove that this is the only issue before ordering LEDs and striping the TV's back light which is a pain...
                                      Also, if anyone has a link for the LEDs, that will be great! (I'm in Ireland and only found them in AliExpress so far...)
                                      Thanks!
                                      • alfatv
                                        • Sep 2020
                                        • 353
                                        Originally posted by BaHa
                                        Hey guys
                                        Thanks!
                                        What type of 24V strips are you using?
                                        If those are not LED strips from TV, they often use resistors to limit the current, this will not work in your case.
                                        You need 14 x 3V LEDs in series, see post #15. The current is also mentioned there.
                                        If you have LED tester, it's much easier to figure it out.
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
