AOC TV LE22H138 Power cycle when trying to turn it on
  • vitim
    The Best Member
    • Oct 2017
    • 10
    • Brazil
    I have a 21" AOC TV that is not turning on, the standby led (orange) is ON but when trying to turn it on, the led goes on blue for a second and it shuts off and goes back to stand by (orange).
    There's a whine noise coming from the transformer.
    I couldn't notice anything obvious in the visual inspection, while I know it is probably something wrong with the power supply, I don't know where to start.
    I don't have schematics, but the circuit is fairly simple as it is a single sided board. I included the best pictures I could take of the top and bottom, and a combined top/bottom image.
    From the quite loud noise coming from the transformer I suspect that it is not switching as fast as it should be, due to some dry cap, but it is just a guess.
    Any suggestion of where should I start?
    Your body is limited, but not your mind.
    Re: AOC TV LE22H138 Power cycle when trying to turn it on
    You cab=n start by reporting the DC Voltage of the pins of the connector on the power supply board that goes to the main board. You must report the pin name and follow by the Voltage reading for each pin. Black probe of the meter on the chassis.
    For example:
    +5.2V = xx V
    • vitim
      The Best Member
      • Oct 2017
      • 10
      • Brazil
      I will get a meter, and report the voltages back.
      Until then, I recorded a video about the high pitched noise I mentioned.
      https://youtu.be/if9sb0EM0zI
        Can we see straight shot pictures of the whole bottom side of the power supply board?
        Never mind, the second pictures of the bottom side is fine for me to see the traces..
          Does it still squeal without the backlights LED connector in place?
          • vitim
            The Best Member
            • Oct 2017
            • 10
            • Brazil
            Please check the pictures 2 and 3 attached on the first post, I don't think I can get better pictures than that.
              I was looking at number two picture with that see through of the top side showing but then I look at number 3 picture and that one is OK for me to see the traces.
              • vitim
                The Best Member
                • Oct 2017
                • 10
                • Brazil
                Removing the backlight connector makes no difference. (still squeaking, tv doesn't start either)
                Removing the main board makes it quieter, but it stills audible.
                  It is either the main board is drawing too much current or problem in the power supply with failed parts so it cannot handle load.
                  Unplug the TV from the outlet and use hair dryer to heat up the entire board for about 3 minutes and the try again to see if the squeal is still there.
                  I suspect bad cap C928 in the hot side of the circuit.
                  Also look real close at the legs of the main filter caps C904, C905 to see if there is some kind of corrosion on the legs of the caps.
                  • vitim
                    The Best Member
                    • Oct 2017
                    • 10
                    • Brazil
                    I will replace C928, but the main filter caps c904 and c905 just after the rectifier are holding charge for quite a while, after plugging the mains, so they are not completely dead, although they can be out of spec, I don't think I would blame then just yet. Or do you think they can still be the cause? Or ripple on the primary is that critical? I'm just speculating here, I don't really know
                    I thought about the main board, but the PSU is squealing by itself with nothing connected on it, so definitely theres something wrong with it. Although the main board can be the cause the PSU gone wrong in the first place.
                      "I thought about the main board, but the PSU is squealing by itself with nothing connected on it, " When I watch your video, I did not hear the squeal until you put the main board connector in place.
                      • vitim
                        The Best Member
                        • Oct 2017
                        • 10
                        • Brazil
                        It gets louder, when I plug the main board, but it still there, and I don't mean the usual coil wine that stuff usually does. And when it was OK it didn't squeal anyway.
                        • MobileXT
                          820-02100 Turn ON Turn OFF cycle
                          by MobileXT
                          Hello Everyone, I'm new on this board 820-02100 and having a problem on the charger 5v then 19v then back to 5V again in cycles. I don't know where to start. Any help greatly appreciate.
                          01-06-2025, 10:54 AM
                        • pajdek
                          Lenovo Y700-17ISK turn on and off
                          by pajdek
                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                          09-20-2023, 02:49 AM
                        • tony359
                          by tony359
                          11-28-2023, 05:18 AM
                        • RdeveLabs
                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                          by RdeveLabs
                          To all the members here...
                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                          05-05-2025, 04:59 AM
                        • MegaZAC
                          Onkyo TX-SR805 noise in one channel
                          by MegaZAC
                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                          There's some logic behind it. As soon as I select an input I get only left...
                          04-23-2025, 10:09 PM
