Samsung plasma wont power on pn50a550
    Hi
    Picked up this tv today....when plugged in u can hear a click but standby light just blinks red
    Wont power on
    I do get 5v standby power
    Is there a common issue with this brand/ model for no power on?
    Also on logic board there are 2 green leds that just blibk rapidly continuously when tv plugged in.
    No blown fuses on y or z or ps
    Re: Samsung plasma wont power on pn50a550
    I was thinking of removing cables from boards to see if i can get to power on and isoltae issue .....but some of these models wont power on with certain boards disconnected but it cant hurt to try
      I checked and all voltages coming from ps appear to be good so ps prob not issue
      Vs good
      Va good
      Vg good
      Standby good
        If i unplug y board from ps tv still wont power on
        If i unplug z board from ps tv will still not power on
          Main board issue. Try replacing C102 on the back. There are tons of threads about this if you just search for 'C102' on here. If the TV isn't playing the startup tone over and over, there's a good chance that the board has been damaged beyond just replacing C102 but that's a good place to start. 9x out of 10 it will remedy the issue.
            Hi thanks
            Tv does not power on at all....no pic...no sound...no jingle
            The front samsung logo is lit up and all output voltages from ps are good but keeps clicking and wont power up
              I will reseacrch the c102 issue....like u said its a start...and mine keeps cycling / making clicking sound every minute or sonbut never does turn on.....not sure if c102 is same repair as mine..
              Thank you
                Brief research on this model had many main board issues...either reflowing or replacing c102 fix most cycling issues
                There are no main boards for sale on ebay and many people selling main board repair kits for this model....so im going to concentrate on main board
                Doubt its a y or z issue
                  you can confirm if it the main board by running the test patterns.
                  disconnect the lvds cable and jump pin 3+4 on the control board. if all other boards are good, you will have good clean test patterns showing on the screen.
                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                    Ok i will try tomorrow
                    I tried reflowing main in oven at 385 for 10 min....didnt fix issue
                      Do i disconnect power cable to main or just the lvds?
                      And where are pins 3-4 on logic?
                        Can you clarify please
                          post a pic of your control board and we will point it out.
                            ok i will when i can....quick question....on the main board is a surface mount cap c102
                            its 47uf 10v "tatulum" polymer
                            can i just rrplace it with a typical thriugh hole alum cap and soldrr legs to pad?
                              and r u saying disconnrct lvds cable on logic and jump pins 1/3 whrre the rrmoved connector was?
                                i believe that you can change out that tantalum with a low esr alu cap, but i will let someone else confirm that.
                                there are 4 prongs or holes for jumping on the control board. you will need to jump pin 3 and 4.
                                not jump the lvds connector pins.
                                  ok now i understand
                                  ill try to post pic
                                    pic of logic board
                                      You can at least test the board using an aluminum capacitor. I'd recommend an equivalent surface mount for a permanent replacement but I do believe people have had decent luck either way with the repair.
                                        i agree....will test...with alum since i have some
