LG 60PN6500 Plasma with standby, but won't power up.
  • XCon
    Craptacular
    • Jan 2015
    • 22
    • I enjoy pulling stuff from the graveyard and breathing life back into them. Plus I get money for it.
    Symptom is TV has standby, I get relay click, voltage rails come up, but no screen and TV shuts down after 5 seconds. If I disconnect the Z from the y sus, the unit stays powered up and I can read voltages.
    So I've read the two other threads on this TV and I can confirm the Y-Sus #EAX64789501 does not have diode or resister failure. Did not see any fractured solder joints on the transformer or anywhere else. All power boards have slight discoloration on the hot spots.
    The board in question is EAX64789601, Z board. I have 208 going to Y Sus, 5v standby. Pin 5 on P174 connector going to Y-Sus is supposed to have 15v and only shows 5v. My suspicion is that the Y-Sus needs 15 vees to power up which appears to come from Z?
    Found it on the curb from a nice older gentleman who paid $1300 in 2012 in near mint condition, and he gave me the stand and remote to go with it 🥳
    I would really like to save this one from the landfill and not have to gamble on buying an extra board or worse, the wrong board, when I can fix the existing one with y'alls help 🫡
    Thanks in advance
    Curtis
    A Guy Can Try
    https://youtube.com/@aguycantry?si=jNCl6kxPlTpdJ_lx
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4836
    • Italy - Milan
    Ciao.. the first move when you don't know at all which board is , is to test PS board at bench with test loads.. .another test is to find the screen self test procedure to rule out main board..
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • dom.true
      IC2960 for A Board - Panasonic TH-P42X10Z Plasma Television
      by dom.true
      Hi Folks,
      I have a Panasonic TH-P42X10Z Plasma Television (2009-era; New Zealand model).
      This set has proven to be extremely reliable throughout its +16-year lifespan. However, late last year, when going to use the TV, I noticed a 9-blink red LED error code on the front of the set after the television failed to turn on. A quick Google search revealed that this indicates a problem with the set’s main A-board.
      After opening up the set and giving the board a thorough test with my digital multimeter, I found that one of the integrated circuits on the board...
      01-17-2026, 05:01 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Cooperr
      Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
      by Cooperr
      I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
      The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
      10-21-2025, 01:11 PM
    • GIzmo_Ger
      Gigabyte MZ31-AR0 VRM section - Schematic/standby-sequencing info needed
      by GIzmo_Ger
      Board: Gigabyte MZ31-AR0 Rev. 1.1, AMD SP3 socket, dual VRM design (separate VCore and VIO controllers).
      *Symptom:*
      With an AMD EPYC Rome-generation CPU installed, the board won't complete POST. Same board works fine with the original (Naples-generation) CPU it shipped with. Same Rome CPU is confirmed working in a different vendor's SP3 board, so the CPU itself is good.
      *What's been ruled out:*
      - Firmware — full reverse-engineering of the BIOS/AGESA PEI+DXE code found correct microcode, correct CPU detection, correct AP bring-up for this exact CPU....
      09-03-2026, 08:53 AM
