Samsung plasma wont power on pn50a550
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Hi
    Picked up this tv today....when plugged in u can hear a click but standby light just blinks red
    Wont power on
    I do get 5v standby power
    Is there a common issue with this brand/ model for no power on?
    Also on logic board there are 2 green leds that just blibk rapidly continuously when tv plugged in.
    No blown fuses on y or z or ps
  • shelby5041
    • Feb 2009
    • 1505
    Re: Samsung plasma wont power on pn50a550
    I was thinking of removing cables from boards to see if i can get to power on and isoltae issue .....but some of these models wont power on with certain boards disconnected but it cant hurt to try
    • shelby5041
      • Feb 2009
      • 1505
      I checked and all voltages coming from ps appear to be good so ps prob not issue
      Vs good
      Va good
      Vg good
      Standby good
      • shelby5041
        • Feb 2009
        • 1505
        If i unplug y board from ps tv still wont power on
        If i unplug z board from ps tv will still not power on
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Main board issue. Try replacing C102 on the back. There are tons of threads about this if you just search for 'C102' on here. If the TV isn't playing the startup tone over and over, there's a good chance that the board has been damaged beyond just replacing C102 but that's a good place to start. 9x out of 10 it will remedy the issue.
          • shelby5041
            • Feb 2009
            • 1505
            Hi thanks
            Tv does not power on at all....no pic...no sound...no jingle
            The front samsung logo is lit up and all output voltages from ps are good but keeps clicking and wont power up
            • shelby5041
              • Feb 2009
              • 1505
              I will reseacrch the c102 issue....like u said its a start...and mine keeps cycling / making clicking sound every minute or sonbut never does turn on.....not sure if c102 is same repair as mine..
              Thank you
              • shelby5041
                • Feb 2009
                • 1505
                Brief research on this model had many main board issues...either reflowing or replacing c102 fix most cycling issues
                There are no main boards for sale on ebay and many people selling main board repair kits for this model....so im going to concentrate on main board
                Doubt its a y or z issue
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  you can confirm if it the main board by running the test patterns.
                  disconnect the lvds cable and jump pin 3+4 on the control board. if all other boards are good, you will have good clean test patterns showing on the screen.
                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  • shelby5041
                    • Feb 2009
                    • 1505
                    Ok i will try tomorrow
                    I tried reflowing main in oven at 385 for 10 min....didnt fix issue
                    • shelby5041
                      • Feb 2009
                      • 1505
                      Do i disconnect power cable to main or just the lvds?
                      And where are pins 3-4 on logic?
                      • shelby5041
                        • Feb 2009
                        • 1505
                        Can you clarify please
                        • attainteddragon
                          • Apr 2013
                          • 764
                          • australia
                          post a pic of your control board and we will point it out.
                          • shelby5041
                            • Feb 2009
                            • 1505
                            ok i will when i can....quick question....on the main board is a surface mount cap c102
                            its 47uf 10v "tatulum" polymer
                            can i just rrplace it with a typical thriugh hole alum cap and soldrr legs to pad?
                            • shelby5041
                              • Feb 2009
                              • 1505
                              and r u saying disconnrct lvds cable on logic and jump pins 1/3 whrre the rrmoved connector was?
                              • attainteddragon
                                • Apr 2013
                                • 764
                                • australia
                                i believe that you can change out that tantalum with a low esr alu cap, but i will let someone else confirm that.
                                there are 4 prongs or holes for jumping on the control board. you will need to jump pin 3 and 4.
                                not jump the lvds connector pins.
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  ok now i understand
                                  ill try to post pic
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    pic of logic board
                                    • aaronwt6
                                      • Apr 2013
                                      • 855
                                      • US
                                      You can at least test the board using an aluminum capacitor. I'd recommend an equivalent surface mount for a permanent replacement but I do believe people have had decent luck either way with the repair.
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        i agree....will test...with alum since i have some
                                        • Cooperr
                                          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                          by Cooperr
                                          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                          10-21-2025, 01:11 PM
                                        • CDNBrewer
                                          Samsung Plasma PN43D450A2D No Power
                                          by CDNBrewer
                                          Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
                                          This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
                                          I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
                                          When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
                                          03-02-2025, 04:59 PM
                                        • Espartaco Smith
                                          TV Samsung UE40MU6405U, not standby (after power failure)
                                          by Espartaco Smith
                                          Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
                                          After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
                                          The power supply is: L40E6_KSM (BN44-00875A)
                                          The main board: BN41-02568B
                                          The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
                                          I've also checked the...
                                          12-17-2024, 02:16 AM
                                        • XCon
                                          LG 60PN6500 Plasma with standby, but won't power up.
                                          by XCon
                                          Symptom is TV has standby, I get relay click, voltage rails come up, but no screen and TV shuts down after 5 seconds. If I disconnect the Z from the y sus, the unit stays powered up and I can read voltages.
                                          So I've read the two other threads on this TV and I can confirm the Y-Sus #EAX64789501 does not have diode or resister failure. Did not see any fractured solder joints on the transformer or anywhere else. All power boards have slight discoloration on the hot spots.
                                          The board in question is EAX64789601, Z board. I have 208 going to Y Sus, 5v standby. Pin 5 on P174 connector...
                                          06-27-2025, 05:30 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
