Broken gear in VCR. Replaceable?
+ More Options
Posts
  • pentium
    • Mar 2006
    • 2778
    My Sony SL-2700B is my last Betamax VCR. It has lived a good life and then this evening the unthinkable happened.
    As I was inserting a tape into the machine I heard an excessive "pop" and the tape would not load. I heard a motor whirring and that was it.
    I pulled it from my stack and opened it up on the table and found this:
    This gear had given me trouble in the past (you can see where I had heated it to try and repair cracks) as well however this time it was not fixable.
    So now I can't load or eject tapes and thus not use the VCR. Since I have seen a similar part in another Beta deck, this is a pretty common part, correct? I would really like to get it replaced and put the thing back into use as I simply love Betamax quality.
    FYI: I find it ironic that it happened when I was dumping (AKA: Pirating) the movie "Pirates of Silicon Valley" to a beta tape.
    Find Nedry!
    Check the Vending machines!!
  • Wizard
    • Mar 2008
    • 2296
    Re: Broken gear in VCR. Replaceable?
    hehe.
    Visit good electronic repair shop that does carry sony parts. They shouldn't be much in cost. that why I do not bother to repair as you have discovered that gluing nylon parts is fruitless.
    Cheers, Wizard
    • pentium
      • Mar 2006
      • 2778
      Oh lord.
      That means I have to see Giddens and they inflate the price on anything they do or offer.
      Hopefully I can just show them the part and ask for a replacement with no hassle (which can wait (the hassle) until I have to tear half this thing apart to install it).
      Still, is it a relatively common part?
      Find Nedry!
      • Wizard
        • Mar 2008
        • 2296
        High stress parts are usually common breakage in many VCR and is usually often stocked.
        Cheers, Wizard
        • zandrax
          Hit and miss
          • Dec 2007
          • 1157
          • Italy
          Sony stopped manifacturing spare parts for Beta decks in late '90s, so hope Giddens stocks some old pieces or can find you an equivalent replacement. Plastic gears should be available, but this isn't always granted. Pity
          Zandrax
          Have an happy life.
          • i4004
            • Oct 2006
            • 2029
            find used with that part still in one piece...
            then give the man 1$ and say you gave him 1$ too much...
            hehe...
            • pentium
              • Mar 2006
              • 2778
              I'm not going to find any spare beta decks here. If it has not already gone to the recyclers it's in a pawn shop for $50 or in the ownership of someone who will take it with them to the grave.
              It's a pity I no longer have access to a metal shop. Then I could at least try to cast a new and stronger one.
              Also, I have complained before that Giddens tried to charge me $40 for a fucking oven element.
              Find Nedry!
              • Wizard
                • Mar 2008
                • 2296
                Oven element for 40? not bad, and lasts years. We routinely see more for anything else too.
                Cheers, Wizard
                • pentium
                  • Mar 2006
                  • 2778
                  We went to another store and got the same element for $20. :/
                  Find Nedry!
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    I don't know if it will work for you but two exopoys come to mind. One is called belzona, and the other is PC7. Belzona is almost as hard as steel when set. Its a bitch to work with but man its strong. In the Millwright trade Belzona is commonly called Liquid metal. Yes its even a pain in the ass to grind down. PC7 is a little softer but after a 48 hour set it will make a good repair in most cases. If you know the profile of what the missing part of your gear looked like you just may be able to rebuild the broken part using one of these epoxys. Its going to be a pain in the ass to do but well worth it to keep the old unit going. The thing that you have to do is get rid of all traces of oil and grease. Also you have to scuff up the plastic so the epoxy gets a good bite. Let the repair cure out fully before you start trying work the repair into its final shape. This is where a Dremal tool come in handy. I have made repaired many small outboard motor parts these products. Belzona is an industrial product and may be hard for you to find. If you do find belzona you must mix it in the exact proportions that the directions say or it will not set. It may be a three to one mix but I don't remember exactly. Its been a while since I've worked with it. PC7 was originally designed for fixing cracked Heads from the old flathead car engines. I did work in this appication pritty well too as some of the old guys have told me. PC7 mix one to one so its easy. Good Luck!
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • pentium
                      • Mar 2006
                      • 2778
                      I don't think we have any places that sell that strong of epoxy around here. Where would I look? Canadian tire?
                      Find Nedry!
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        ace hardware has pc7 here.
                        any ace hardware in ca?
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          Darn I forgot that you are in Canada. Kc is right again. PC7 can ge found at most Hardware stores. They also have some new crap called PC11 or something like that. I have not used the new stuff so I don't know if its any good. You can find Belzona online. You may also find it local at the bigger industrial supply places. I get it at Fugerson right up the street from me.
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            OK went and had a quick look at the Belzona site. These products look like they could do what you want to do: Belzona 1121, 1111, or 1221. If it were me I would go to their site and use the contact page and explain what you need to rebuild and let them recommend the product. I have some here and I would give you the number off it but I just don't exactly know where I put it away at this time...
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                            • pentium
                              • Mar 2006
                              • 2778
                              Well that means I'll have to get some spare time and remove what remains of the gear that is inside the case. I expect some swearing along the way.
                              Find Nedry!
                              • larrymoencurly
                                • Oct 2004
                                • 960
                                My experience is limited, but I'v had no luck at all with gluing nylon. OTOH every time I've melted nylon back together with a soldering iron, the fix has held for a long time, except in the case of the hood prop rod clip for my Toyota (plastic didn't melt at all but just charred). This includes some individual teeth for the tuner of an ancient TV that I still have.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Find a buddy in a shop class somewhere and have him machine you one out of aluminum.
                                  Mann-Made Global Warming.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Is there a Part Number on it?
                                    http://www.partstore.com/Model/Sony/Sony/SL2700B.aspx
                                    - Dr Seuss
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      FYI
                                      Perhaps also:
                                      Manualscenter.com
                                      Good luck!
                                      veritas odium parit
                                      • tmwalsh
                                        • Jan 2009
                                        • 119
                                        Pentium, did the PC7 or the Belzona work? I have a Canon printer that has a paper feed gear with a toothache. One of the teeth has worn, and causes a mis-mesh and jamming...
                                        The gear is made of what looks like nylon, but for all intents and purposes, it might as well be made of unobtainium. I had never heard of either product, and put it on the shelf awaiting dismantling or finding another with a different problem.
                                        Canon will only sell the complete feeder mechanism, which, of course, costs more than a new printer.
                                        If you had good luck, it would encourage me to disassemble the printer and attempt to effect a repair.
                                        tom
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • RetroComputingGrotto
                                          IBM LTO 7 Tape Drive - Dust Sensors??
                                          by RetroComputingGrotto
                                          I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                          I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                          09-19-2024, 01:54 AM
                                        • triplefour
                                          LG 75UN8570AUD panel issue fixed with tape.
                                          by triplefour
                                          I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                                          add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                                          07-17-2023, 10:22 PM
                                        • chth96
                                          Is it possible bridging tiny broken trace
                                          by chth96
                                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                          cutting tiny trace.
                                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                          12-03-2022, 11:32 PM
                                        • render1967
                                          Problem with the Logitech G27 gaming steering wheel gear lever
                                          by render1967
                                          Hello! First, please excuse me if my English is not good enough because it is not my native language!
                                          Now let me describe my specific problem. For two days, the gear lever on my Logitech G27 has shown the following defect. When switching in the game (for example ETS2) it often does not detect 1st, 3rd and 5th gear - in these positions it shows neutral or flashes between the specific gear and neutral (for example - 1st <> neutral). When I press the gear lever to the left or right while it is in a position, it still manages to guess the gear and engage. In addition, instead of rear...
                                          11-13-2021, 01:35 PM
