Panasonic TX-42A400B
  • ronhayes
    TV Engineer
    • Mar 2014
    • 458
    Hi All
    I have this Panasonic in with no picture but has sound and backlights are on ?
    I have took some pictures of the panels but I have not removed any as yet all caps look ok on all panels.
    I am thinking the fault will most likely be with the T-Con board?
    Unless someone has had this fault and knows different!!
    Any help much appreciated.
    Ron
  • ronhayes
    TV Engineer
    • Mar 2014
    • 458
    Re: Panasonic TX-42A400B
    I have checked the fuse F1 on the T-Con board and that seems ok.
    Ron
    • vinceroger69
      • Mar 2012
      • 6714
      as the panel pcb is on the bottom of the tv is it possible someone has cleaned the screen with fluid and damaged the tab bonds? im not sure if this would give you a whole no image situation though do you get voltage too both sides of the tcon fuse
      • ronhayes
        TV Engineer
        • Mar 2014
        • 458
        I get 12,2v both sides
        • vinceroger69
          • Mar 2012
          • 6714
          what about it you remove one side of the tcon too lcd panel ribbon cables, do you get a image on half of the screen? try this on both sides of the tcon
          • ronhayes
            TV Engineer
            • Mar 2014
            • 458
            Here are some pictures with the ribbons disconnected .
            The half white and half black with lines in it is with the right hand ribbon disconnected and the two blank screen pictures are one with the left hand ribbon disconnected and with both ribbons connected.
            • ronhayes
              TV Engineer
              • Mar 2014
              • 458
              Sorry if I don't reply after this message as I am now getting ready to go to work as I am on night shift this week.
              • ronhayes
                TV Engineer
                • Mar 2014
                • 458
                Going by the results of removing the ribbons it seems that the T-con board is certainly faulty ?
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  i think that you have a panel fault with the alternating picture status that you have shown.
                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  • ronhayes
                    TV Engineer
                    • Mar 2014
                    • 458
                    Hi All
                    Was wondering if anyone has a service manual for this set?
                    I have now tried replacing T-Con board and the main AV board but still have no picture !!
                    I have back lights and sound but no video any help would be much appreciated.
                    Or has anyone had one of these sets with this issue ?
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      Hi Ron,
                      Available to download from
                      https://www.electronica-pt.com/esque...s-km25e-32819/
                      I would strip it down and have a good look at the circuit board which the tcon connects to. This runs along the bottom of the set and also connects to the panel via the tabs. Check that water has not caused any damage.
                      • ronhayes
                        TV Engineer
                        • Mar 2014
                        • 458
                        I have had a good look at the boards connected to the screen and have even eased one of them out without causing any damage to connectors and can not see any water stains at all.
                        I have asked son for the remote so I can carry out some tests but I am thinking that the display is the fault.
                        • ronhayes
                          TV Engineer
                          • Mar 2014
                          • 458
                          I now have the remote for this set but as there is nothing displayed on screen you cant do anything with it.
                          Is there any way to test a lcd screen to see if it is faulty ?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            maybe with something like this?
                            http://www.ebay.co.uk/itm/TV-Laptop-....c100005.m1851
                            • ronhayes
                              TV Engineer
                              • Mar 2014
                              • 458
                              I have just been looking at those lcd testers they look like a good item to have.
                              Has anyone used these testers ? If they have what do they think of them ?
                              Are they user friendly to use and what sort of problems can they diagnose ?
                              Any info would be much appreciated before I go ahead and purchase one.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                This is a good video showing it in action the main thing is i guess would it have all the correct connectors to all the different brand of tv t cons
                                https://www.youtube.com/watch?v=i4Cq0hNTNIo
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  If I remember when reading the spec on it some time ago it still has to be connected to the Tcon so it would not eliminate a tcon fault or a coff chip fault. Therefore I think it has very limited use.
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    Yes I agree it is limited! When watching the video you have to connect it to the T-con board and what he is saying is if you still do not get a display then it is the T-con board.
                                    I have changed the T-con board but still no display.
                                    You would need to be able to connect this tester after the T-con board but they do not show if this is possible , They do show it being connected directly to a laptop screen so maybe you could connect directly to a TV lcd screen but you would probably need a different connector but that could be costly for all different models
                                    • ronhayes
                                      TV Engineer
                                      • Mar 2014
                                      • 458
                                      I will ask the question to one of the suppliers to see if it is possible to connect the tester directly to a TV lcd to test the screen rather than through the T-con board and see what they say ?
                                      • ronhayes
                                        TV Engineer
                                        • Mar 2014
                                        • 458
                                        Can anyone advice can a LCD screen lock out after so many hours of viewing ?
                                        For example no display if it has reached the allotted hours ?
                                        I think I read some ware in the past that some screens could only display for so many hours ? mainly LCD's
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • eccerr0r
                                          Sell or Shim Solar panels?
                                          by eccerr0r
                                          Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                                          However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                                          So now what to do with these small panels?
                                          I could sell them...
                                          Or I could shim them....
                                          03-29-2025, 01:07 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
