Samsung inverse picture
  • jurgyman
    • Jul 2015
    • 27
    I have a Samsung ln40a500 LCD with a mostly white, inverse picture.
    I tried a brand new tcon board but it looked the same. What to try next?
    Re: Samsung inverse picture
    Please up load good clear pictures of the screen to show us what you are seeing.
    • jurgyman
      • Jul 2015
      • 27
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        disconnect one ribbon cable that goes from the t-con to the panel at a time and see if you get a clear picture on the half that is connected. reinsert first cable and disconnect other side and check pic again.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • jurgyman
          • Jul 2015
          • 27
          One panel cable disconn, half screen freezes, goes white. Same if other disconnected.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            hmmmmmmm. you could check the vgma test points on the t-con to see if it is a gamma issue.
            was your replacement t-con new or used?
            is the t-con on the lower side of the panel?
              I would say this is likely a gamma issue.
              • chrismurphy
                • May 2014
                • 251
                • australia
                my verdict faulty T-con
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4537
                  • Italy - Milan
                  Surely is tcon faulty, if it has an AUO panel is surely AS15 chip, search for "as15" in the forum, tons of threads, tons of chips on market, ebay, aliexpress.
                  • jurgyman
                    • Jul 2015
                    • 27
                    Had gotten a new replacement same board tcon from ebay. but it looked the same, even whiter and washed out than original. Im sending that one back.
                    If its a gamma issue, where is that addressed?
                    • jurgyman
                      • Jul 2015
                      • 27
                      I redid the disconnect tcon to panel cables... and got snaps.
                      • budwich
                        • Jul 2015
                        • 3097
                        what's history on the set (ie. how did it get to this "state").
                        • jurgyman
                          • Jul 2015
                          • 27
                          TV is a pick from the local electronics recycling site.
                          so for me its always had the white-washed inversed picture :-)
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4537
                            • Italy - Milan
                            You have luck! (to find it..) It's not unuseful to buy faulty tcon for working or NEW ones! Watch on the tcon, if there's a chip named like AS15-F, take a photo of it closely, i'm curious if someone has made a bad repair. It's better to buy a chip and go in a cellular repair shop asking it to solder it. Ah, usually with faulty as15 it tends to go whiter after you switched on the tv ..
                            • jurgyman
                              • Jul 2015
                              • 27
                              Is there anyone related to badcaps community that could replace the tcon as19 chip ? willing to pay around $20-25 (about the cost of another tcon board)
                              • attainteddragon
                                • Apr 2013
                                • 764
                                • australia
                                let's confirm the fault first.
                                on the top of the t-con, there are 18 test points within a white outline and gamma written in the middle.
                                can you measure each point in numerical order and let us know the result.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4537
                                  • Italy - Milan
                                  I had asked for a close view of the chip, there i can't see the pins well, but anyway..
                                  • jurgyman
                                    • Jul 2015
                                    • 27
                                    Here is a closeup of the chip: AS19-H1G
                                    doesnt look modded to me.
                                    • jurgyman
                                      • Jul 2015
                                      • 27
                                      Here are the requested tcon test point voltages.
                                      01 15.26
                                      02 12.77
                                      03 11.99
                                      04 11.45
                                      05 11.84
                                      06 10.71
                                      07 10.03
                                      08 9.04
                                      09 8.06
                                      10 6.87
                                      11 6.28
                                      12 5.53
                                      13 5.12
                                      14 4.71
                                      15 4.37
                                      16 3.44
                                      17 2.62
                                      DRL1 3.23
                                      OE1 0.78
                                      STV 0.0
                                      CKV 0.0
                                      VSCM 6.81
                                      in this video, I skipped 12, but then corrected myself. above Vs are correct.
                                      https://vimeo.com/234130462
                                      • microvibe
                                        • Mar 2013
                                        • 275
                                        • canada
                                        Is test point 4 + 5 switched around if it's not then that's tge problem. higher voltage on test point five than test point 4.
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
