Hi guys;another LCD tv saved from dumpster;i just resolver all critic joints on the power board,Tv works great,except it takes 2 or 3 pushes on the power button to turn on tv,has this to do with the start up cap? can someone point me to the start up cap,or something-else i could look over?thanks
Insignia NSLCD32 help.
Re: Insignia NSLCD32 help.
Hi guys;another LCD tv saved from dumpster;i just resolver all critic joints on the power board,Tv works great,except it takes 2 or 3 pushes on the power button to turn on tv,has this to do with the start up cap? can someone point me to the start up cap,or something-else i could look over?thanks -
check to see if stby is stable, then check if the voltage on the main cap is stable. after that, check if your ps/on voltage is changing states when you activate power, and remains stable.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
There are pin names of those white connectors, you need to put down pin names and follow by the DCV reading of each pin so we can see what you have right now.
Is this the exact board?
http://www.shopjimmy.com/insignia-66...pply-unit.htm#Last edited by budm; 08-22-2017, 09:38 AM.Never stop learning
http://www.shopjimmy.com/insignia-66...pply-unit.htm#Comment
we still need the voltages on the connector that goes to the main.
pin description, v in stby, v after power button is pressed.
if you have absolutely no stby voltage at all. disconnect the main board and then check to see if your stby voltage then comes up.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Can i connect the power to the board out of the TV and check voltages without load?i guess some voltages can't be checked without main board connection! any input would be appreciated, thanks for your patienceLast edited by ivtec; 08-23-2017, 08:21 AM.Comment
I don't have no voltages on the output to main or any other board, even when i unplug all the connectors,as i said now after i changed all suspected caps it's harder to turn tv on it takes many pushes on the power button in order to fire up tv,then it does it has all voltages on the output to the boards ,i don't have the remote control to check if it turns on with the remote,strange though is that when i plug in the power cord i should have a red led and i don't,as i said i have 167v at big Cap and at the bridge rectifier.
Can i connect the power to the board out of the TV and check voltages without load?i guess some voltages can't be checked without main board connection! any input would be appreciated, thanks for your patienceComment
I would think the big cap on your power board should churn out closer to 400v when all turned on - are you measuring legs of cap (hard to do with this mounting when assembled).Comment
theres not much in regards to pin markings on this psu there is two that say 5V and ON i wonder if you jump these two with a 1 k resistor will the other supplies come up then hopefully budm etc can advise before you try it.Comment
the link budm provided by shop jimmy has good zoomable pictures in maybe easier for you too trace the circuit?Comment
that is heaps better, pity i'm not that good at tracing these things out.
what is the part number of n502?WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Ok i checked R514=74 it's ok 75Homs
Checked R520= 1.7 ohms it's ohms not OK should be 75 ohms,
also checked R513=0.5 ohms not ok should be 15 ohms,
here pic of the bad resistors ,i think!Comment
R513 (in PFC section) is 0.15 Ohms resistor, it shows 0.5 Ohms on your meter because of your probes resistance.
Try heating C521 and the cap next to it with hair dryer first and then apply the power to see if you will get the 5VDC back.Last edited by budm; 08-24-2017, 10:52 AM.Never stop learning
by cajoegHello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV... -
by valvashonHaving a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new... -
by arnardI have a weird backlight issue on the above Insignia Plasma that I am coming up empty on researching.
The display is darker on the left than on the right side of the screen. It uses 4 U shaped plasma tubes. I have had it apart deep enough to tell you that the tubes are bright as they should be at the electrode ends but dim as they get to and go around the bend.
Since it is all 4 tubes it seems like it would be an inverter/backlight board but obviously can't be a blown up component as it does still somewhat work. I'm thinking low voltage but no idea where to go beyond...06-10-2023, 01:36 AM -
by srsI'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables... -
by captainKKKInsigna NS-50DR710NA17
Plug to AC, small blue power indicator light at center bottom illuminates. Only using flashlight test, Insignia emblem in center of screen for 90 seconds and then nothing. Power button pressed and still using flashlight screen test, the entire Roku, 4K menu is shown. Never does the back light show any light., even in dark room.
Boards are these: https://www.shopjimmy.com/insignia-n...-1182036900530
wifi unplugged
Voltages on CN9103 (Power supply board to... - Loading...
