Sharp LC-60EQ10U - powers on but no glow
Re: Sharp LC-60EQ10U - powers on but no glow
Got the board yesterday from Kelowna Digitronics. Put it in and happy to see my problem solved. 96$ US and a very happy uncle. He paid 1800$ for this Sharp TV and it went dead after 2 yrs and 1 month. Costco/Sharp didn't want to honour the warranty since it was 1 month past due. Just hope that this panel will last more than 2 yrs.Thanks, the LED sequence flashing in my case, 3-1, points to the main board according to the SM. I ordered one. Will cost 100$ to find out !! . I'll keep you posted.
The problem with EBay, often those supposedly good board are not. They've been sold and returned many times.Last edited by andytv; 09-27-2017, 05:02 PM.Comment
thanks for the info! glad it worked. I'll try ordering one from them.Got the board yesterday from Kelowna Digitronics. Put it in and happy to see my problem solved. 96$ US and a very happy uncle. He paid 1800$ for this Sharp TV and it went dead after 2 yrs and 1 month. Costco/Sharp didn't want to honour the warranty since it was 1 month past due. Just hope that this panel will last more than 2 yrs.Comment
I just got a Sharp LC-60SQ15U given to me about a week ago and I am having the EXACT same problem! Flashing code 3-1, unpluged one ribben from T-con board and get snow in the right hand side and lines on the left hand side. I will spend $100 on a T-con board for a free TV.
Keep us updated
Try to get the service manual. A 3-1 flash on my LC-60EQ10U pointed towards a defective Main board not T-con. Yours is a diff. model so not sure if it is also the Main Board.I just got a Sharp LC-60SQ15U given to me about a week ago and I am having the EXACT same problem! Flashing code 3-1, unpluged one ribben from T-con board and get snow in the right hand side and lines on the left hand side. I will spend $100 on a T-con board for a free TV.
Keep us updated
by nosajI have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
So I thought I'd just quit messing around and come to the best site... -
by malogroHello all,
I'm stumped on this guy, so wanted to see if anyone has any further ideas:
Intro:
This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
does... -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM - Loading...
