Samsung 32" power supply BN44-0351B no backlight
  • seve91
    • Oct 2013
    • 75
    • Italy
    #41
    Re: Samsung 32" power supply BN44-0351B no backlight
    tomorrow i will check and i will let you know, thanks.
    I notice also a black spot on the top of the screen...looks like a burner LED backlight..
      I will not run the TV until more verification.
      • seve91
        • Oct 2013
        • 75
        • Italy
        #43
        Originally posted by budm
        So what is the PFC Voltage now?
        ICS802 is part of the PFC Over Voltage protection that will not allow QS801 from coming on by bypassing the bias current for QS801 to GND.
        Originally posted by dick_barton
        As Budm has requested, what is the PFC voltage when the set is forced on by shorting emitter/collector?
        You need to check QS801. Youtube have plenty of video's that show you how to test it with your meter. The opto-isolator is fine and does not need to be replaced. It shorts the collector voltage to the base of QS801 when the Power ON/OFF input is taken high as it should.
        I would also replace the zener diode ZDS806 and diode DS806 connected to the base of QS801 as suggested by Thoma then your tv will be repaired properly.
        PFC-OUT is now 380V. To test QS801 is better to desolder it, isn't it?
        • seve91
          • Oct 2013
          • 75
          • Italy
          #44
          desoldered QS801 and tested using multimeter in diode mode...it's ok.
          Tested also DS806 without desoldering, and it's good.
          Desoldered and tested ZDS806 using multimeter in diode mode...OK.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            #45
            Replace QS801. I'm pretty certain it's faulty.
            There's a supply into the collector and the opto-isolator is switched on and puts the voltage on the base.
            DS806 & ZDS806 I suspect are fine. When the voltage into ICS802 reaches 2.5V or greater it starts to block the voltage to the emitter of QS801 by reducing the voltage on the base. That's not the problem because the voltage is there so I don't believe ICS802 is at fault or the voltage being fed to ICS802 from R840, 841, 842, 843, 846, 847, 844 is greater than 2.5V so the PFC circuit is not over voltage.
            From the photo's above you also appear to have at least one faulty led that needs to be replaced.
            • seve91
              • Oct 2013
              • 75
              • Italy
              #46
              how do you say it's faulty? I tested only in diode mode...i usually test B-C and B-E, then i reverse the probes...first time OL, second time 0.6, so i supposed was fine.
              What about faulty led? is it possible to replace only one led? i have to find the right model disassembling the tv
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #47
                Only a suggestion since I cannot think of what else it could be.
                There are plenty of Youtube video's showing you how to replace the leds.
                • seve91
                  • Oct 2013
                  • 75
                  • Italy
                  #48
                  ok i will try to find the same model of BJT and replace it.
                  If it will solve the issue, then i have to learn a new method to test the transistors
                    Right now what dcv (in circuit when TV is turned on) do you have between E and B of that Transistor?
                    • R_J
                      • 9624
                      Why not try shorting PCS802S/B (e-c) if the QS801, etc. are ok the tv should turn on.
                      Or try shorting QS871 e-c to see if the tv comes on
                      Power on/off controls QS871, If QS871 is turned on it connects PCS802S/A to ground causing its led (in the optocoupler) to light.
                      • seve91
                        • Oct 2013
                        • 75
                        • Italy
                        #51
                        i'll try and let you know...i've disassembled the panel, and the TV got two stripes of LED named LMB-3200BM11. Can't find the replacement....i am able to desolder and resolder and smd led, but i need the exact model of that led
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #52
                          Have a look at:-
                          http://www.ebay.it/itm/152536779696
                          • seve91
                            • Oct 2013
                            • 75
                            • Italy
                            #53
                            with C-E shorted, is 0.15V
                            expired
                            • seve91
                              • Oct 2013
                              • 75
                              • Italy
                              #54
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                #55
                                That is a burned LED!
                                Looks like a Osram Duris E5 LED....
                                https://www.led-tech.de/en/High-Powe...0_206_216.html
                                replace the faulty led.
                                • seve91
                                  • Oct 2013
                                  • 75
                                  • Italy
                                  #56
                                  thanks looks like very similar...but which temperature? 2700k? 3000k? 5700k?
                                  and...how many? i suppose that they are connected in parallel, so it's not only one burned.
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    #57
                                    They are connected in series. If 1 dies , the whole strip is off. ( Christmas lights ).
                                    So in this case it looks like you only need one. Not sure about the lumen , maybe someone else can answer that. Maybe it is in the service manual.....
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      #58
                                      The best thing you can do is google the led strip name!
                                      https://www.vareza-elektronik.de/pro...85&language=en
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        #59
                                        Bright white which has a bluish tint. So I would say 5700K. Others will give yellowish tint
                                        • seve91
                                          • Oct 2013
                                          • 75
                                          • Italy
                                          #60
                                          thanks...i've ordered 10 of them, plus a 15V zener because i've lost the small one i've desoldered for testing
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • cheeky2
                                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                            by cheeky2
                                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                            06-15-2025, 05:12 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
