Samsung 32" power supply BN44-0351B no backlight
  • seve91
    • Oct 2013
    • 75
    • Italy
    Re: Samsung 32" power supply BN44-0351B no backlight
    pins are ordered as reported in the datasheet:
    1) 13.34V
    2) 13.17V
    3) 0.4V
    dc voltage between pin 2-3 of ICM801 is 1.58V (only PSU connected, with 1kohm resistor between pins 16-18 of CNM801.
    Thanks budm for your tip and suggestions...checked the solder around the transformers, and other main devices...they are good.
      1) 13.34V
      2) 13.17V
      3) 0.4V
      Right now that Transistor QD801 is not turned on, that Base pin 2 should be < 1V or when QD802 is turned on as explain in my earlier thread.
      • seve91
        • Oct 2013
        • 75
        • Italy
        yes i know...so? what's the next step?
          As explained earlier, that protection circuit monitor the D100VDR Voltage, if it is not present or too low then that transistor will not be turned on as you can see in the schematic.
          So do you have Voltage at D100VDR as shown in the diagram?
          • seve91
            • Oct 2013
            • 75
            • Italy
            nope, no voltage
              nope, no voltage
              Well that is the section of the circuit you need to check and find out why it is not putting out any Voltage to feed the LED Voltage booster power supply section.
              • seve91
                • Oct 2013
                • 75
                • Italy
                #27
                the high voltage line seems to stop on the hot side of the TM802 (PFC_OUT is 323V)
                  The PFC boosted Voltage should be close to 380~400VDC range when the TV is turned on, 323V is normal Voltage in standby (230V x 1.414 = 325V).
                  So if that is what you have when TV is turned on then you need to start checking the PFC section. Check to see if the PFC Diodes are OK or not.
                  • seve91
                    • Oct 2013
                    • 75
                    • Italy
                    #29
                    ok so that part is not switched on...i will try to put the board back to the TV and power it on, then i will measure again the voltages
                    • seve91
                      • Oct 2013
                      • 75
                      • Italy
                      #30
                      yes, same voltages in PFC when TV is on
                      • seve91
                        • Oct 2013
                        • 75
                        • Italy
                        #31
                        the OUT of the BD801S is 323V, the DP801 and DP803 diodes are ok.
                        So how could be PFC_OUT 400V? Where is the spot of the circuit where PFC is boosted up to 400V?
                        • seve91
                          • Oct 2013
                          • 75
                          • Italy
                          #32
                          maybe ICP801 is dead...i believe that the IC controls the boost of the PFC
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #33
                            In your first post #1, you said you had sound and picture but no backlight so that would indicate that either the led voltage is missing, led driver is faulty or there is an led fault.
                            ICP801 drives the circuits that give you the secondary voltages A, D12V, Vamp, D5.3 and STBY5.2V and since you said everything but the backlights are working then its not likely that ICP801 is faulty.
                            You also said earlier that pin 2 (as shown on the schematic) of QD801 was at 0.3V and this supplies the voltage to pin 1 of ICD801. If this is the case then without a supply voltage to that IC, there can be no led boost voltage.
                            ICM801 pin 3 (VCC) = ??
                            ICP801 pin 8 (VCC) = ??
                            • seve91
                              • Oct 2013
                              • 75
                              • Italy
                              #34
                              Ok....
                              ICP801 pin 8 (VCC) = 1.60V
                              ICP801 pin 1 (FB) = 1.84V
                              ICM801 pin 3 (VCC) = 1.62V
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #35
                                Did you put your black meter lead on power ground to take the readings and not on the chassis?
                                • seve91
                                  • Oct 2013
                                  • 75
                                  • Italy
                                  #36
                                  black probe put in the GND pin of each IC measured
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #37
                                    I think the problem is around QS801 and the diodes as indicated by Thoma in an earlier post.
                                    There is 13V at pin 3 of QS801 and when Power On/Off is taken high and the opto-isolator PCS802S/B acting as a switch then shorts the 13V to RS809/RS810 taking the base to 13V. The emitter voltage should then be at the base voltage minus 0.7V.
                                    As a quick test, but at your own risk, I would quickly short QS801 emitter and collector to enable Multi_Vcc and see if the backlights come on.
                                    • seve91
                                      • Oct 2013
                                      • 75
                                      • Italy
                                      #38
                                      short done, and TV is working!!! THANKS A LOT!! so maybe is the opto isolator that doesn't switch on the QS801?
                                        So what is the PFC Voltage now?
                                        ICS802 is part of the PFC Over Voltage protection that will not allow QS801 from coming on by bypassing the bias current for QS801 to GND.
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #40
                                          As Budm has requested, what is the PFC voltage when the set is forced on by shorting emitter/collector?
                                          You need to check QS801. Youtube have plenty of video's that show you how to test it with your meter. The opto-isolator is fine and does not need to be replaced. It shorts the collector voltage to the base of QS801 when the Power ON/OFF input is taken high as it should.
                                          I would also replace the zener diode ZDS806 and diode DS806 connected to the base of QS801 as suggested by Thoma then your tv will be repaired properly.
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • cheeky2
                                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                            by cheeky2
                                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                            06-15-2025, 05:12 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
