Insignia NS-46E340A13
  • ngth82
    • Jul 2015
    • 541
    Re: Insignia NS-46E340A13
    Originally posted by david.aaron.long
    Funny story. I bought the tv from him on craigslist, thinking I would be able to come to badcaps and find a way to fix it...
    it was nice to meet you David.
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Well read through posts and continue with troubleshooting
      • lmpina
        • Jun 2013
        • 4
        My experience with this TV (Insignia NS-46E340A13):
        1. Color (using default factory settings) could be better - much improved (but still not great) by installing firmware update 2.05.
        2. Power on problems / won't power on at all - solved by replacing U403, the EPROM on the Main Board. Replacement EPROM costs about $20 on eBay. Instructables.com has a good tutorial on this titled "How to Repair Dead Mainboard on INSIGNIA LED TV NS-46e3401a13."
        • =N=
          • Jun 2019
          • 5
          • Usa
          Insignia NS-46E340A13 TV.
          The TV reboots and power cycles continuously.
          Power board: 715G5173-P02-W21-002M / (T)CR248XF3
          Main board: 715G5738-MOD-000-004K / (T)TXCCB0K090000TOP:A MB:A v2.02
          Upon applying AC power, the unit turns ON completely by itself
          The back-lights turn ON
          The TV power cycles itself (power LED blinks 3x times, the back lights turn on, the Insignia logo shows up, back lights turn off, and the process repeats) Tv stays ON for maybe 40 seconds and reboots forever regardless of time for warming up.
          Voltages observed on connector CN902)power boards PSU : are as follows (as observed from top to bottom with the board is installed): pic included
          CN902: (Volts)
          ON/OFF 4.5
          DIM 2.3
          12V 12.30
          12v 12.30
          GND 0
          GND 0
          GND 0
          24V 25.00
          24V 25.00
          PS_ON 5.0
          5.2V 5.0
          5.2V 5.0
          P_OK 0
          Voltage across the main caps are : 385V
          NO bulging ,no electrolyte spillage, looked with magnifying glass just in case since they can bulge from the bottom as well.
          No discolorations due to spillage of electrolyte OR over heating
          The fuses on the power board are good; same with the T-con fuse.
          Tried disconnecting the Power button board ( which appears useless) and the Tcon to isolate the issue and does the exact something .
          Thoughts
          • =N=
            • Jun 2019
            • 5
            • Usa
            forgot the pics :} here you go ,
            there the same as the original posters its identical to his ngth82.
            • =N=
              • Jun 2019
              • 5
              • Usa
              #26
              Any one ????
                • 12332
                • U.S.
                #27
                Post #23 looks interesting, you might have same problem.
                • =N=
                  • Jun 2019
                  • 5
                  • Usa
                  #28
                  indeed its been bought and arrives today or tomorrow, I have power everywhere its suppose to be, I think.
                    When the TV power cycle by itself, does PS-ON Voltage also swing up and down in sync with the power cycle?
                    • =N=
                      • Jun 2019
                      • 5
                      • Usa
                      #30
                      THX for trying to help. All voltages seemed present. so it turns out its 100% the bios.
                      bought it on ebay
                      https://www.ebay.com/itm/EEPROM-FOR-...53.m2749.l2649
                      Note: Changing a bios chip isnt like a screw you kinda need to know what your doing and avoid destroying traces.
                        Good to see it is running again.
                          • 12332
                          • U.S.
                          #32
                          Nice fix.
                          • max789
                            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                            by max789
                            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                            I made the following tests:
                            1. Disconnected the main board from Power Board = backlight works.
                            2. Connected the main board and disconnected the T-Con = backlights does not work.
                            So I ordered a main board from Ebay also BN41-02156A but from...
                            01-18-2024, 06:56 AM
                          • bpcannan
                            VIZIO M557-G0: Backlights or ???
                            by bpcannan
                            'Morning,
                            I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                            Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                            I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                            I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                            10-29-2023, 06:36 AM
                          • jesterace
                            Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                            by jesterace
                            Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                            However, I am in a dilemma.
                            I tested the backlight outputs with the lights disconnected...
                            10-20-2024, 10:15 AM
                          • x_orange90_x
                            Sony KD-75X750H no backlights
                            by x_orange90_x
                            I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                            Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                            07-16-2025, 07:49 PM
                          • jimbofz
                            toshiba 65ul2163 dbl no backlights NOT BACKLIGHTS?
                            by jimbofz
                            Hi this vestel 65in tv had classic no backlights ,so nothing new there!
                            tested with b/l tester and the b/l seemed to be fine
                            so investigated psu 17ips72 (on this 65inch there are 3 fets and control iv type DB83630P)
                            did a thorough check on b/l circuit all ok .
                            When i tried again with b/l tester all ok .but then when i reinstalled psu all worked fine ,
                            could there be a component on psu that is causing the protection mode to stop b/l
                            .maybee causing it to be too sensitive?
                            it seems to me if the b/l have been on with my tester ,within a couple of minutes...
                            06-07-2025, 10:11 AM
