toshiba 65ul2163 dbl no backlights NOT BACKLIGHTS?
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Hi this vestel 65in tv had classic no backlights ,so nothing new there!
    tested with b/l tester and the b/l seemed to be fine
    so investigated psu 17ips72 (on this 65inch there are 3 fets and control iv type DB83630P)
    did a thorough check on b/l circuit all ok .
    When i tried again with b/l tester all ok .but then when i reinstalled psu all worked fine ,
    could there be a component on psu that is causing the protection mode to stop b/l
    .maybee causing it to be too sensitive?
    it seems to me if the b/l have been on with my tester ,within a couple of minutes if i reconnect the psu they will work fine
  • EazyBone
    • Jun 2023
    • 1351
    • United states
    Backlights can be funky. I get tvs with BLs out from customers, turn on and they work. Even for 2-3 days and test fine. Doesn't always rule them out. They eventually go out again and I can then make them test bad. Just throwing that out there before you decide they are just good.
    Pictures of PSU/connectors would help also
    • jimbofz
      • Apr 2013
      • 539
      • uk
      its still a work in progress
      i have reduced the backlight current ,by increasing the fet source pin resistance
      .it had 5 resistors in parallel .47 ohm
      i simply removed two of these as an experiment .now the tv b/l come on as normal
      i was given the tv so its fine to experiment
      • lotas
        • Jan 2016
        • 4700
        • Russia
        The 17IPS72 has a OB3363QP backlight driver, so the backlight current is regulated by 5 pin. ISET (when the resistance of this series resistor chain increases, the current to the LEDs drops).
        • jimbofz
          • Apr 2013
          • 539
          • uk
          thanks lotas and eazybone for your reply
          .i will keep it running on test ,
          the original owner had the b/l at 100%
          reducing it to 50 % and removing two of the parallel resistors (increasing the resistance )
          tv still gives good picture
          • nomoresonys
            • 12212
            • U.S.
            So what you have is probably one or more weak backlights, since lowering the current they stay on. It may live for a long time like that but if it does the same you know where to look.
            • jimbofz
              • Apr 2013
              • 539
              • uk
              exactly. i have replaced many b/l over the years
              and sometimes its obvious that the strips have had a hard life as they are discolured
              this one they all looked fine ,but only time will tell
              • mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                by mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                11-25-2024, 05:22 PM
                09-06-2024, 05:27 AM
                09-06-2024, 05:59 AM
