RCA no power indicator
Re: RCA no power indicator
Q12 on the back side of the board (great photo by the way) is blown apart.
or there is a piece of trash that looks like foil on the otherwise very clean looking board. Top right of photo near the bottom right of the center coil connectors... 2 up from D12
OOPS it is the TOP right of the center coil connectionsLast edited by Doc38343; 08-06-2017, 07:02 PM.Comment
So to me without the main board connected you have PS-ON to turn on the 12V power supply and probably the switched 5V as well which means it has pull-up resistor for the PS-ON which is pretty rare for re-badged RCA TV.
It still does not make sense to me to have TWO separated power supply with low output Voltage, especially the 5v to run the main board.
Something is not making sense here at all.Last edited by budm; 08-06-2017, 08:05 PM.Never stop learning
I see that now, I will see if I can do a continuity test later tonight and see if it is in fact burnt. I will also try to post a close up as well.Q12 on the back side of the board (great photo by the way) is blown apart.
OOPS it is the TOP right of the center coil connectionsComment
Hard to tell from photo could be trick of the lighting... you need to test the transistor... see if it is shorted to ground or shorted thru itself.
Something is cutting you voltage, but if it was a full short to ground it would either smoke and be obvious or just pull the rail to 0V.
I had a board once on a computer that had a low voltage issue and after many hours i found a shorted smd cap that was connecting a resistor to ground on a 3.3v line and the math for a voltage divider made it 1.2v and that would not let a mosfet trip on.
I don't know if that is your trouble just a possibility that is why it is hard to find.
That part looked completely blown in the other photo but not i'm not sure it may be ok just a lighting illusion... back to the testing board!! (sorry)Comment
I will be out of town for a week or two, I will continue testing then. Thanks for the help.Hard to tell from photo could be trick of the lighting... you need to test the transistor... see if it is shorted to ground or shorted thru itself.
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by GjacksonHi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
