KDL-60W600B won't open just Red Blinks 6 times
    Re: KDL-60W600B won't open just Red Blinks 6 times
    Is the reading different if you reverse red and black for the diode?
      Originally posted by Ali101
      Dear budm,
      i had checked with ohm & diode mode, i put black probe on middle leg & red probe on left or right leg & below are results,
      with ohm: 173.5 reading
      with diode: 0.237 V reading
      any advise will be highly appreciated,
      173.5 Ohms reading in both directions? If that is the case then you need to remove it and re-test it off the board.
      Is it in Ohm, K Ohms, or M Ohms?
      • Ali101
        • Jul 2017
        • 152
        • Taiwan
        #63
        @tom bro if reverse than no reading, i.e ohm 0.00 and diode 1
        @budm bro not sure what is that means both directions, i can check if you tell me how to check.both direction, BTW ohms set on 200 Range and do you mean i need to remove board from tv than check or i need to remove D6801 diode and than test with multi meter,
        Appreciated your help,
        Thanks alot.
          I am confused by the 0 ohm reading, can you double check?
          I only expect the single "1" in diode and single "1" in ohm (which indicates that the diode is not conducting in reverse, which is good.)
          • Ali101
            • Jul 2017
            • 152
            • Taiwan
            #65
            @tom sorry my bad, both have reading 1, i just wakeup its 6 :00 am here, this tv is nightmare for me now, Please accept my apology for above mistake, so now it means D6801 is faulti? What i need to do now,
            Thanks alot.
              Thanks alot.
              It's OK. You don't need to apologise, I get up early too and know all too well how easy it is to make mistake.
              Your diode tests OK, so something else must be wrong, I will wait for budm to suggest the next step.
              • Ali101
                • Jul 2017
                • 152
                • Taiwan
                #67
                Dear Tom, appreciated, & thanks alot bro,
                @budm bro waiting for your support,
                Thanks.
                  Dear budm, with CN6401 which pin# i need to check since i already check CN6401 all pins each by each with tv turn on,
                  Like i did with each by each pin to leave the meter connected to that pin and then turn the TV on & results below
                  CN6401: on PSU
                  Pin 1 = 3.5 V after turn on tv it goes 0.00 V
                  Pin 2 to 5 = 0.00 V
                  Pin 6 to 8 = 12.7 V after turn on tv it goes 0.00 V
                  Pin 9 to 14 = 0.00 V
                  do i need to check some other way? your advise will be highly appreciated,
                  Thanks.
                  It looks like you count the pins wrong, it has Even and Odd column. We need to know the DCV of BL-ON pin (no BL-ON = no Boosted Voltage, BL-ON is one of the required signals/Voltage for the booster to work) which you cannot get to it from the top, you have to use skinny probe on the back side of the connector (all connectors must be in place) or from the bottom side of the board, see pin out picture attached.
                    If probing is a problem you can probably unscrew the board, put a piece of cardboard to isolate it from the chassis (a short may blow a fuse or damage the board, so make sure it is definitely isolated), and flip it over. Then you can very carefully probe the other side, including BL ON. Be very careful as the high voltage is exposed on the board more easily this way. Do not touch anything on the high voltage side as you could get an electric shock.
                    • Ali101
                      • Jul 2017
                      • 152
                      • Taiwan
                      #70
                      @budm, OMG how stupid i am, thank you so much for make me on correct path, before i was keep thinking which pins you are asking, sorry my bad,
                      @tom bro, indeed your suggestions help me to not let make board more short, thanks alot,
                      Below are results,
                      CN6401 BL_ERROR pin 3= 1.6V after tv turn on it goes 0.00v very fast within one or two seconds,
                      BL-ON pin 5= 0.00v after tv turn on it goes 3.29V for one to two seconds and again goes to 0.00v
                      Thanks again @budm @tom
                      • Ali101
                        • Jul 2017
                        • 152
                        • Taiwan
                        #71
                        @budm waiting for your comments,
                        Thanks.
                          So bl-on was present for seconds and you do see the 90V at the output of the LED connector and then the BL-ON drops down so the 90V drops down also, the drops down is probably due to protection kicks in due to the backlights did not come on.
                          At this point it looks like the power supply/LED needs to be replace, or you will have to go deeper into troubleshooting the backlights driver circuit, it may be the LED driver IC that is bad.
                          May be look up the IC6801 spec sheet and we can start checking the Voltages on the pins.
                          • Ali101
                            • Jul 2017
                            • 152
                            • Taiwan
                            #73
                            so we need to open LCD panel to check LEDs right? or it have any other option you think we can try before we touch LCD panel?
                              No, we need to find the specification sheet of that SMD LED driver IC.
                              But if you want to check the LED you can use LED tester to test the LEDs without opening up the LCD panel. At this point I do not believe the LED's are bad.
                              • Ali101
                                • Jul 2017
                                • 152
                                • Taiwan
                                #75
                                Thanks budm, admired your help,
                                God bless you bro.
                                • Ali101
                                  • Jul 2017
                                  • 152
                                  • Taiwan
                                  #76
                                  @budm @tom any help?
                                  sorry to annoying you guys from so long & none reslut came, just waiting for your guys final so i decide whether how i go through,
                                  already appreciated your guys help,
                                  Thank alot.
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    #77
                                    Read post 72 and 74
                                    • Ali101
                                      • Jul 2017
                                      • 152
                                      • Taiwan
                                      #78
                                      @dskall i already read post 72 & 74 but issue is i don't know how to check backlights driver circuit, or LED driver IC, or where to find IC6801 spec sheet to checking the Voltages on the pins, so i need support & i am waiting for budm & tom further instruction hope i'll get some help,
                                      Thanks.
                                        IC6801 is the SMD IC on the bottom side of the board, you will need to get the P/N as printed on the top of the IC first then you will search the WEB for the specification sheet for that IC.
                                        • Ali101
                                          • Jul 2017
                                          • 152
                                          • Taiwan
                                          #80
                                          @budm, got it, will check & get back to you,
                                          Thanks for help & support, appreciated.
                                          • htv239
                                            LG UH8500 Backlight Troubleshooting Help
                                            by htv239
                                            I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                            Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                            What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                            10-11-2021, 01:53 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • Samunggg
                                            Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
                                            by Samunggg
                                            I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
                                            I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
                                            09-06-2023, 06:39 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • mecha1166
                                            XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                            by mecha1166
                                            I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                            07-01-2024, 05:47 PM
