KDL-60W600B won't open just Red Blinks 6 times
    Re: KDL-60W600B won't open just Red Blinks 6 times
    wHAT DO YOU HAVE ON Power supply board CN6401 BL_ERROR pin 3, BL-ON pin 5?
    So far your LED connector readings do not show open circuit.
    • Ali101
      • Jul 2017
      • 152
      • Taiwan
      Thank for help budm, but sorry i not understand, what i need to check now to make sure which part of PSU have problem so i change it,
      Thanks.
        Rurn in the TV and check the DC Voltage on the power supply connector CN6401 pin 3 (BL-ERROR), and pin 5 (BL-ON) with reference to the chassis GND.
        • Ali101
          • Jul 2017
          • 152
          • Taiwan
          Dear budm, i had check PSU & BAXL with below results,
          Multi Meter Range set on 20 DC
          CN6401: on PSU
          Pin 1 = 3.5 V after turn on tv it goes 0.00 V
          Pin 2 to 5 = 0.00 V
          Pin 6 to 8 = 12.7 V after turn on tv it goes 0.00 V
          Pin 9 to 14 = 0.00 V
          as per chassis GND it says Check JL9106* at (BACKLIGHT_MON) of CN9101 on the BAXL Board
          so below is CN9101 resluts
          Pin 1 = 3.54 V after turn on tv 3.54 V is still there
          Pin 2 to 5 = 0.00
          Pin 6 = 3.56 after turn on tv it goes 0.00 V
          Pin 9 to 11 = 12.71 after turn on tv it goes 0.00 V
          Pin 12 to 15 = 0.00 V
          any advise will be highly appreciated,
          Thanks.
          • Ali101
            • Jul 2017
            • 152
            • Taiwan
            As per chassis GND in BAXL i have no idea where is JL9106* & i need to check how much out put with what range of Multi meter set,
            • Ali101
              • Jul 2017
              • 152
              • Taiwan
              #26
              @tom66 & @budm any suggestions?
              you guys are experts and your help will be highly appreciated to find actual fault on my tv,
              Thanks.
              • Ali101
                • Jul 2017
                • 152
                • Taiwan
                #27
                Anyone? Any help on this issue? I need help to find which board have fault so i replace that board only, since i need to buy from ebay so first make sure which is faulty, kindly help me on this point,
                Thanks.
                  I look through those service manual, it does not say what the normal Voltage should be if there is no backlights error.
                  • Ali101
                    • Jul 2017
                    • 152
                    • Taiwan
                    #29
                    So there is no way we can find which one is faulty board?
                    Whether its PSU or BAXL or TCon,
                      I did not look in details to see if the backlights can be forced on or not to help narrowing down the board. Most power supplies and backlights cicuits can be forced using resistors between standby power supply output pin and BL-ON, and PS-ON pin.
                      • Ali101
                        • Jul 2017
                        • 152
                        • Taiwan
                        #31
                        Dear budm appreciated your reply, hope you will help me to find actual faultu board on my tv, @tom any advise? Really need help on this point,
                        Thanks.
                          Perhaps, if you are brave enough to remove 60" LCD panel, it is worth checking the LEDs in the backlight and see if they are okay.
                          You should be able to test them using a 3-4V power supply, some multimeters will also do this.
                          • Ali101
                            • Jul 2017
                            • 152
                            • Taiwan
                            #33
                            Thanks for advised tom, since i am not much expert so i am afraid if i open LCD panel it may damage inside panel or its totally safe to open panel? Or you think i should call some tec ppls to fix my tv, waiting for your reply,
                            Thanks.
                              It's not easy to open the panel and it's easily damaged if you are not careful. A tech may cost a lot of money though, so it's entirely up to you.
                              • Ali101
                                • Jul 2017
                                • 152
                                • Taiwan
                                #35
                                is there any other way to check without open LCD panel?
                                  You can get LED tester, something similar to this:
                                  http://www.ebay.com/itm/0-300V-SID-G...item1c740cd5ab
                                    Can you check the DCV between the two legs of the filter cap C6801? That will be the Voltage that is fed to the Voltage Boost converter for driving the LED's strings.
                                    Also need the Voltage rating of the cap C6801 and C6804, it is printed on the body of the caps.
                                    • Ali101
                                      • Jul 2017
                                      • 152
                                      • Taiwan
                                      #38
                                      Thanks for help budm, appreciated your kind assistance,
                                      so i have to open LCD panel to check whether some led got bad? from all above tests/board readings seems like my LED panel have issue right?
                                      Not sure if filter cap is attached image, if so than below is reading i take while tv power on, but if filter cap is different than below image than your help will be appreciated to find & test further more,
                                      Thanks.
                                      CN6801:
                                      Pin 1=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
                                      Pin 2=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
                                      Pin 3=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
                                      Pin 4=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
                                      CN6802:
                                      Pin 1=13.5 V, after turn tv on it drop slowly 12...11..10......3.2.1
                                      Pin 2=13.7 V, after turn tv on it drop slowly 12...11..10......3.2.1
                                      Pin 3=13.6 V, after turn tv on it drop slowly 12...11..10......3.2.1
                                      Pin 4=13.6 V, after turn tv on it drop slowly 12...11..10......3.2.1
                                      Pin 5=0.00 V,
                                        Thanks.
                                        CN6801:
                                        CN6802:
                                        Pin 5=0.00 V,
                                        We already know what Voltage you have on the LED connectors, what I need is the dcv on the cap I listed above so we can find out if the boost converter is working or not. Please re-read my request again and look for those caps on that power supply board.
                                        https://www.badcaps.net/forum/attach...1&d=1501157949
                                        • Ali101
                                          • Jul 2017
                                          • 152
                                          • Taiwan
                                          #40
                                          Dear budm, sorry my bad, since i am very nervous due to it might LCD penal fault so recognized C6801 Cap as CN6801, please accept my sincere apology, will check & get back to you with results,
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            08-24-2025, 03:47 AM
                                          • JarzabekPZ
                                            HP Victus 15-fb0104nw not turning on, charging led blinks 3 times
                                            by JarzabekPZ
                                            I'm working on a HP Victus that is not turning on. When power button pressed it only blinks 3 times with charging led. I have checked input mosfets and they are fine. Also all coils are fine too. Battery was empty but I charged it with my lab PSU and laptop started on batery but is not charging. When battery is disconected and only PSU connected it takes 0 current and not starting. What can be the reason?
                                            09-18-2025, 08:16 AM
                                          • htv239
                                            LG UH8500 Backlight Troubleshooting Help
                                            by htv239
                                            I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                            Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                            What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                            10-11-2021, 01:53 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • netgearnetgear
                                            TCL 43S423 TCON OR PANEL FAULTY???
                                            by netgearnetgear
                                            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                            08-20-2025, 06:04 PM
