KDL-60W600B won't open just Red Blinks 6 times
  • Ali101
    • Jul 2017
    • 152
    • Taiwan
    #121
    Re: KDL-60W600B won't open just Red Blinks 6 times
    Yes i will manag it, one more question, once i find out ic is gd than,do i check it via power on tv? I need to replace new zener new right? What ohms it should be?
      If the resistance between the pin 24 and pin 23 no longer show very low Ohm like you had before then it will be safe to turn on the TV to do the quick test. The Zener is probably 15V Zener for clamping the Voltage to safe level in case the 12V goes bad an put out way above 12V.
      • Ali101
        • Jul 2017
        • 152
        • Taiwan
        #123
        how much resistance between the pin 24 and pin 23 show than it means IC is good, and i probably need to replace cap also which i'll remove right? yello mark in picture, that cap is how much V? ohms should be how much on that yellow mark cap when i buy or reply new one?
        Thanks.
          It should be in hundreds if not thousands of Ohms. Something is definitely bad to cause the 4.7 Ohms resistor to go bad due to over current flowing through the resistor.
          So what resistance do you get between pin 24 and 23 with the cap removed?
          • Ali101
            • Jul 2017
            • 152
            • Taiwan
            #125
            I not remove yet, sorry, helping my wife for shopping atm, due to i have work off today so you know wife's huge demand lmao, i asked you alot of questions coz i known soon you will go for sleep and you may reply me tomorrow, i will be at home in a while and check and get back to you,
            One again thank you very much.
            • Ali101
              • Jul 2017
              • 152
              • Taiwan
              #126
              Hi budm
              As instructed i checked with removed yellow mark cap in picture & following are results,
              Meter set on 200 ohms rang
              Black probe on 23 pin & Red probe on 24 pin results 1
              Red probe on 23 pin & Black probe on 24 pin results 147.8
              Black or Red probe on 24 pin & Black or Red probe on resistor which i just solder, up side leg near to IC & results 0.8,
              Black or Red probe on 24 pin & Black or Red probe on resistor down side leg results 4.3,
              Black probe on 23 pin & Red probe on resistor up side leg results 1,
              Red probe on 23 pin & black probe on resistor up side leg results 147.9,
              Black probe on 23 pin & red probe on resistor down side leg results 1,
              Red probe on 23 pin & black probe on resistor down side leg results 144.2,
              so IC is not bad right? i can go ahead & check board with power on tv right?
              waiting for your reply before proceed,
              Thanks.
                "Red probe on 23 pin & Black probe on 24 pin results 147.8" I do not expect it to show such low resistance but go ahead and power up the TV anyway, worst case will just damage the resistor. At this point I think you need new IC.
                • Ali101
                  • Jul 2017
                  • 152
                  • Taiwan
                  #128
                  Yes, after plugin tv on power, smoke come out from resistor, so now we need to replace IC right, and that cap and zener as well right,
                  Thanks.
                    The cap and Zener are OK, the Zener is probably 15V Zener, and the cap is 0.1uf 50V.
                    So try to locate the the IC and go from there.
                    • Ali101
                      • Jul 2017
                      • 152
                      • Taiwan
                      #130
                      Got it, Thanks budm.
                      • Ali101
                        • Jul 2017
                        • 152
                        • Taiwan
                        #131
                        Hi budm, yesterday i went to buy cap & zener & IC around city electric street but unfortunately not found similar type & shape Zener & Cap which you recommend to me, can you advise any link around web where i can find 15V Zener, and the cap 0.1uf 50V which should work on my board, below link you can advise which one is perfect for this board
                        http://www.mouser.tw/Semiconductors/...z0z7ptZ1yuq6ad
                        Thanks.
                          Did the old Zener get destroyed when you removed them?
                          I cannot tel from the pictures as to what size they are, you need to get the caliper to measure the width and the length.
                          • Ali101
                            • Jul 2017
                            • 152
                            • Taiwan
                            #133
                            yea zener & cap both been destroyed while removing, can't we just use similar size as per board zener & cap places? i means similar size on board have other places zeners & caps,
                            check below pic where zener & cap looks same size almost,
                            Thanks.
                              To get the replacement you need to get the correct physical size that is why you need to know the dimensions of the parts, it may be 0402, etc.
                              For example: http://www.radio-electronics.com/inf...t_packages.php
                              • Ali101
                                • Jul 2017
                                • 152
                                • Taiwan
                                #135
                                Dear budm,
                                yesterday i got IC, zener & cap which i ordered two months before on web lol, anyways after soldering my TV back in life again & every thing working fine now,
                                I thanks you for your all help & efforts, since without your help it was impossible to find where actually it had issue in my TV, you are my real hero, Thanks again,
                                God Bless you bro from your kindness,
                                Thanks.
                                Regards,
                                Ali
                                  Glad to hear the TV is fixed. How much did the parts cost you?
                                  2 months to get part from China? China is right next door.
                                  BTW, make sure to turn down the Backlights level to as low as possible to make the LED backlights last otherwise they will fail.
                                  • Ali101
                                    • Jul 2017
                                    • 152
                                    • Taiwan
                                    #137
                                    haha yea that's funny, it took two months since shipper send it via economy shipping and not sure why it keep stuck in China custom for more than one month,
                                    parts cost below,
                                    IC: USD $10/1 (Original Japan) , zener & cap USD $2/10, Shipping USD $3 , Total: USD $15,
                                    Thanks budm, really appreciated your help,
                                    • htv239
                                      LG UH8500 Backlight Troubleshooting Help
                                      by htv239
                                      I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                      Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                      What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                      10-11-2021, 01:53 PM
                                    • x_orange90_x
                                      TCL 50S535 bad tcon or panel issue?
                                      by x_orange90_x
                                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                      03-29-2025, 11:02 PM
                                    • Samunggg
                                      Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
                                      by Samunggg
                                      I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
                                      I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
                                      09-06-2023, 06:39 PM
                                    • advant
                                      by advant
                                      02-03-2020, 12:25 AM
                                    • mecha1166
                                      XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                      by mecha1166
                                      I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                      07-01-2024, 05:47 PM
