Bad Fimware on Vizio E422VA?
  • lkvee
    • Feb 2009
    • 198
    TV perpetually power cycles with a backlit Vizio logo. Looks like it keeps failing a power-on-self-test. Been reading about a possibly bad EEPROM, but the one thing I have yet to try is to plug in the TV via WIRED Ethernet.
    Supposedly, the TV will download the most recent firmware and self-update.
    Has this worked based on your experiences?
    I can't find scorching, heat, or burning on the "offending" EEPROM on the video board.
  • howardc64
    • Jun 2017
    • 626
    Re: Bad Fimware on Vizio E422VA?
    ditto, same symptom on a failed E422VA. Tried enet to download firmware but didn't work (didn't think it would since not getting past V logo means OS not up and running so no enet driver and download software stack)
    VIZIO service manual (links below) indicate USB firmware loading is possible but firmware not available anywhere online
    https://www.manualslib.com/download/...io-E422va.html
    https://electronicshelponline.blogsp...-firmware.html
    Anyone has the firmware here? Also trying my luck with VIZIO support.
    • mu2
      • Oct 2009
      • 217
      I think Nick's tv can do a board repair for that problem.
      I have used their service several times and can recommend them.
      https://www.nickstvs.com/apps/search...filter=product
      Mike
      • howardc64
        • Jun 2017
        • 626
        Thanks for the link. Got this broken TV for free probably not worth beyond DIY at this point but hate to see it become trash.
        Sounds like the EEPROM is the common failure and link below seems to be the only seller. Service manual shows its actually a 256Mx8 NAND Flash. I wonder if wear leveling is the issue? I have a 2013 Tesla Model S and the entertainment unit has a NAND Flash that wears out as Tesla dumps linux log like crazy and kills it. A few aftermarket shops doing flash replacement (10x bigger capacity so a lot more durable) + data transfer.
        Going to leave some info here for future DIYers.
        Service Manual
        EEPROM source
        https://www.youtube.com/watch?v=OABcBIrg5KE&t=5m50s
        5m50s mark describes other possible issues including failing wifi board. Pulled wifi plug on mine and no difference.
        Misc
        Pulled side panel board plug in case whiskers shorted the power switches. Not issue in my case
        Pulled CCFL connector, IR/LED board connector, T-Con connector, speaker connector. None changed failure behavior
        Did the press power button for 60s while unplugged trick, no joy.
        Plugged in USB drive in both USB ports and no difference (no firmware on it since can't find any online). Wanted to test is boot will recognize USB drive echo on screen. My guess is board might not be booting far enough to do so. Vizio US based support actually called back and said USB firmware update not available on this model. Not sure how true this is but they didn't have the files regardless.
        Attaching my board pics for reference. Will take some voltage readings next.
        • howardc64
          • Jun 2017
          • 626
          Deleted
            • 12181
            • U.S.
            Maybe that will work: https://www.ebay.com/itm/EEPROM-FIRM...kAAOSweoBa~yzP
            • howardc64
              • Jun 2017
              • 626
              Yes, thanks. Know about this option. Provider has to have a flash image and a programmer to make these. I think likely my problem. Like to study the main board some more to make sure CPU is not an issue. I would guess IR power on, V logo + T-Con board working probably means CPU is fine. When powered on and stuck on Vizio logo, enet IP/Mac address shows up on my network. Sounds like CPU is probably good.
              Took readings on voltages. All the main board to PSU connection signal looks reasonable although I have no spec. 5, 12, 24V all there as well as 390V on the big PSU caps when BL on.
              EEPROM/Flash seems to be the likely failure.
              • howardc64
                • Jun 2017
                • 626
                FIXED with reflow
                Fixed this with a simple reflow after diagnostic steps below
                - googled and read a whole bunch. Was able to ping the TV (enet connected) 10s after Vizio logo showed up. I reasoned the main CPU+RAM must be good based on this. Suspected the EEPROM (NAND Flash).
                - Reviewed the ebay EEPROM seller's feedback on this part. One buyer mentioned NAND works but wasn't his problem problem. Had to reflow the main SOC.
                - contacted the ebay seller with my symptoms, asked if he thought EEPROM will fix it. He said no but could be wrong of course. Hearing this, didn't want to gamble on EEPROM hearing from an expert.
                - From board repair services and ebay seller's youtube videos, found HDMI area also potential issue.
                - Took a heat gun and generally heated the backside and topside of the main SOC area (didn't remove EMI shield) and HDMI area. Didn't have a temp sensor so didn't dare to get it too hot. Didn't even see exposed solder joint get shiny.
                Anyhow, it works now. Will test it for awhile and do a proper reflow if any problem shall occur.
                BTW, my flash part was Hynix H27UAG8T2MTR BC which is a 16Gbit SLC flash. This is 4X bigger than many Samsung parts I see in most google photos of boards. My main board number shows its one of the later versions. 16Gbit SLC with wear leveling should be more durable than the Samsung 4Gbit parts. However, I don't know where wear leveling is done (in SOC HW or SOC SW) or if its even done at all.
                • howardc64
                  • Jun 2017
                  • 626
                  FIXED with reflow
                  BTW, running the main board for about 1/2 day so far and nothing on there gets very hot. So no high temps thats commonly associated with failing solder joints. Maybe the board flexes in a particular way (CCFL panel is what gets hot on this set)? Maybe some whiskers got melted away? Don't know why such limited hot hair would have fixed this.
                  • jason123
                    Vizio D50-F1 - Can't update Software / Firmware
                    by jason123
                    Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
                    I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
                    I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
                    08-15-2021, 06:48 AM
                  • Lee M.
                    Vizio E55-DO firmware corrupted?
                    by Lee M.
                    I was given this set and do not have the original remote. It will turn on with the power button and display "oobe V1.1.12 firmware V0" but that's all it will do. It does not respond to the input select button or volume button. I have a remote from the cable company and programmed it for Vizio and it will turn the set on and off but that's it, no response from any other buttons. The white standby led comes on bright at first and then dims but stays on while the set is on. I pulled the back off and looked for anything obvious like loose connectors, bad solder, bad caps and didn't find...
                    04-02-2023, 03:12 PM
                  • TheUser
                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                    by TheUser
                    Hello to everyone ,
                    This is my first post here, and i would like to share with you a small story in case you can help me.
                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                    02-10-2024, 02:07 PM
                  • gurj1979
                    Ubiquiti firmware help. US-8-150W POE
                    by gurj1979
                    Hi guys.
                    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                    Got New chip and writes good.
                    THE PROBLEM...
                    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                    Does anyone have a Good Firmware I can have?...
                    07-22-2024, 05:13 PM
