Sharp LC-60LE832U
+ More Options
Posts
  • RickSinGA
    • Jul 2017
    • 60
    Re: Sharp LC-60LE832U
    I will get back. Got very confused with the plug layout, seemed to be backwards somehow on the other end?
    • dskall
      • Oct 2016
      • 2905
      • usa
      Your picture not clear. Top row I think is odd number. Bottom row is even
      • RickSinGA
        • Jul 2017
        • 60
        Yes, trying to read from the other end of the cord but it seems to be backwards and after multiple tries I am going to call it a night. Seems to get different reading every time I try?
        Thanks for your help, please be patient.
        • dskall
          • Oct 2016
          • 2905
          • usa
          You can backprobe connector at power board.
          • RickSinGA
            • Jul 2017
            • 60
            Second reading; taken from the solder pins on the bottom of the board. I did accidentally
            bridge 3 & 5 with my probe creating a small arc at one point. I was using 3 as a ground
            source. I did recheck the readings I had done prior and they remaind consitant afterwards.
            With PB disconnected from the system and a 1k Resistor jumping 14 and 15. FYI, I did get
            some minor fluctuation in the readings and used the most consistant numbers. I did double
            and triple check the readings for consistacy.
            Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
            1 - PNL 12v - 1.3mv - ???v
            2 - PNL 12v - 1.3mv - ???v
            3 - GND - 000v - ???v
            4 - GND - 000v - ???v
            5 - S13.2v - 13.06v - ???v
            6 - S13.2v - 13.06v - ???v
            7 - UR13.2v - 13.06v - ???v
            8 - UR13.2v - 13.06v - ???v
            9 - GND - 0.4mv - ???v
            10 - GND - 0.4mv - ???v
            11 - GND - 0.3mv - ???v
            12 - GND - 0.3mv - ???v
            13 - AC-DET - 3.34v - ???v
            14 - PS-ON - 4.68v - ???v
            15 - BU5v - 5.08v - ???v
            16 - PNL-POW - 117.1mv- ???v
            17 - PWM1 - 5.1mv - ???v
            18 - NC - 16mv - ???v
            19 - DIMMER - 2.3mv - ???v
            20 - NC - 000v - ???v
            21 - NC - 000v - ???v
            22 - ERROR - 2.2mv - ???v
            23 - PWM2 - 3.6mv - ???v
            24 - STB - 2.2mv - ???v
            Looking back at it now I wonder if 16 shoiuld have been volts?
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              Don't understand your ???v
              • RickSinGA
                • Jul 2017
                • 60
                When I plug in the PB these are the reading, I am guessing this would be the standby power? Will not power on, so I have no idea.
                • RickSinGA
                  • Jul 2017
                  • 60
                  Starting to think you guys have abandoned me or are you waiting for me to do something else?
                    "1 - PNL 12v - 1.3mv - ???v" We still do not understand what the exact Voltage is for the ????V when TV is ON. 1V?10V? 1000V? Your meter shows ???V on the display? Bad data = less or no help.
                    • RickSinGA
                      • Jul 2017
                      • 60
                      TV will not turn on. The voltages described are with TV plugged in. One long and one short blink of the Power indicator on the front of the TV. Nothing else works on the panel or the remote.
                      I used the outline you provided showing the Pin#, Description, Standby Power and Power On status. I assumed the readings I got were standby readings hence the ???v for Power On status.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        What are readings when you push power button?
                        • RickSinGA
                          • Jul 2017
                          • 60
                          I haven't tried that, will do and get back to you. Do I need to remove the resistor and plug everything back in. Not sure how to power it in on without hooking things back up?
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            #33
                            Ok sorry reading back through post those are readings with power supply forced on with resistor correct?
                            • RickSinGA
                              • Jul 2017
                              • 60
                              I wondered what the resistor was for?
                              Those readings were with the resistor jumping 14 and 15.
                                So you disconnected the cable from the power supply board that goes to the main board and then you install the 1K Resistor between BU5V (pin 15) and the PS-ON (pin 14) to force on the power supply, correct?
                                The example on one of the Voltage reading:
                                It does not make any sense when you do have 13.06V in Standby, and ???V POWER ON. It made no sense at all for having ????V. Since the power supply is no longer controlled by the main board so it does not have Standby condition any more since it is being forced on by the resistor, so that S13.2V should be present the minute you plug the power cord into the AC outlet.
                                • RickSinGA
                                  • Jul 2017
                                  • 60
                                  I did not realize that the resistor was forcing the board on. I assumed those were standby readings but i guess they were in fact power on readings. Is that correct?
                                  So, should I remove the resistor and take standby readings and move the readings I had in standby to power on?
                                    Leave the resistor in place and report all the DCV readings of all those pins again after you plug the power cord into the AC outlet.
                                    • RickSinGA
                                      • Jul 2017
                                      • 60
                                      That is what the most recent readings were. Resistor was in place and I thought those were standby readings when it now appears they were power on readings.
                                      If that is the case should I remove the resistor and take readings to place in the standby column?
                                      Sorry if I am confusing you.
                                        So are you telling me that per this reading with the resistor in place you are getting ????V which I do not know what that level since there is no such thing as ???V
                                        Example:
                                        • RickSinGA
                                          • Jul 2017
                                          • 60
                                          No, it should have read 5 - S13.2v - ???v - 13.06.
                                          I have not done the Standby readings. I will redo with the standby voltage without the jumper.
                                          Again I did not realize the jumper forced a power on state.
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • EazyBone
                                            Un50cu7000 2 blink oddity *partially solved
                                            by EazyBone
                                            I write this to maybe help another with this TV.
                                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                            03-18-2024, 10:24 PM
                                          • Mitike
                                            SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
                                            by Mitike
                                            Hello guys,
                                            I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
                                            According to other sharp SM-s it is lamp error (I can't find SM for this model)
                                            And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
                                            If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
                                            02-16-2020, 08:11 PM
                                          • SdlewisSr
                                            Sharp LC-80LE632U 2-5 blink code
                                            by SdlewisSr
                                            I have a Sharp LC-80LE632U with a 2-5 blink code. I have narrowed it down to the T-Con/Panel. I get the error if both or either ribbon cable is connected between the T-Con and the Panel. If I disconnect both ribbon cables, I get no error and the TV powers up just fine.
                                            Does anyone know if this is a definite bad Panel or is there a chance that the T-Con could still be at fault?
                                            07-11-2021, 07:36 PM
                                          • c00lman
                                            Sharp LC-90LE745U 3 slow and 1 fast Blink
                                            by c00lman
                                            hi, new member her and apologize if this has been discussed.. tried to search and most of the result are for LC-xxLe6xx series and not sure if it's applicable to the 745U.
                                            the TV stopped turning on and after the V logo stayed solid for a minute or 2, it gives the 3 slow and 1 fast blinks which from what I researched are internal communication error.
                                            did some voltage measurement on the power supply out.
                                            Pin 1 and 2 = 0V --> PNL 12V
                                            Pin 3 and 4 = 0 V --> GND
                                            Pin 5 to 8 = 13V --> UR 13V
                                            Pin 9 to 12 = 0 V --> GND
                                            PIN 13...
                                            06-21-2021, 05:18 PM
