Failed HV transformer on VIT7101 inverter (Beko TV)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I'm in the process of (hopefully) repairing this TV, so I thought I'd do something different for a change and post "as I go", instead of asking for help before starting or posting my results AFTER I've finished. The TV would come on normally, but the backlight would cut out after a few seconds.
    This particular TV is called Beko, though I've seen the exact same chassis and components under a different brand name, so it may apply to other TVs as well. The inverter says VIT7101 on it, followed by a bunch of other numbers, so I took a picture of that, instead of writing it all down
    I took the back off to take some measurements - you know, the usual stuff, make sure the inverter gets power and an ON signal, bla bla - and as I was doing this, shortly after power-up, I suddenly noticed this massive flash coming from the inverter side (it was like an arc welder). This flash also coincided with the moment the backlight went off, so I knew I was dealing with a failed transformer/PCB track somewhere.
    I powered the TV again and this time paid close attention to the inverter: sure enough, one of the HV transformers was emitting a very bright light from underneath - T203 in my case. I marked it, removed it and immediately noticed the insulation on the bottom was indeed melted and the secondary winding had some charring on in - none of this was visible from the top side, so I could've examined it all I wanted, I would NOT have found the issue from the "outside". Bingo. I'm now waiting for a replacement to arrive, so in the meantime I thought I'd post my findings. Hopefully nothing else breaks down afterwards
    Wattevah...
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Failed HV transformer on VIT7101 inverter (Beko TV)
    did you find the piece of missing casing floating around the tv?
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      No...it might've fallen out when I opened it.
      Wattevah...
      • diif
        • Feb 2014
        • 6978
        • England
        Holy shit ! You've found the enter key
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          What exactly do u mean ?
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Replaced the transformer and the TV is good as new.....yeah I know it's been a long while since I last updated this thread, but I thought I'd let you know it was a happy end
            Wattevah...
              Thanks for the follow-up but keep an eye on it since bad lamp will draw lots of current and causes the winding to burn up. You may want to compare the temperature of the transformers.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Can't a HV transformer burn out "naturally" on its own, without the failure being caused by the lamp ?
                Wattevah...
                  Sure if the coating has broken down and cause shorted turn, or overloaded and caused the wire to burn up, but one way to find if there is problem is to check the temperature, if it is a lot hotter then you know what that means.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    I actually had this issue with another TV recently: just like with this one, the outputs of 2 transformers were in series to run a single lamp, however only one of the transformers was significantly hotter than the other for some reason - either that particular transformer was failing or the lamp caused uneven load. There was also a dead lamp towards the top of the screen (darker shade there) so both of its transformers were stone cold - had to bypass the timer capacitor to get the thing to stay on, at least until the rest of the "bulbs" burn out.
                    Wattevah...
                    • ahmedtou
                      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                      by ahmedtou
                      help me please
                      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                      I will share all the details with you, including the disc information.
                      Code:
                      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                      Current Profile: BD-R
                      Disc Information:
                      Status: Empty
                      State of Last Session: Empty
                      Erasable: No
                      Free Sectors: 12,219,392
                      Free Space: 25,025,314,816 bytes
                      Free Time: 2715:27:17 (MM:SS:FF)
                      Next
                      Yesterday, 08:49 AM
                    • ohren
                      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                      by ohren
                      Hello!
                      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                      Measured voltages with no load:
                      After rectifier diodes
                      12V: 6.17 V
                      5V: 5.67 V
                      Secondary transformer pins AC measurement (really don't know if this says anything)
                      12V: 2-2.5 V
                      5V: 1.04 V
                      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                      03-18-2023, 10:33 AM
                    • mikey5791
                      Is it possible for transformer substitution?
                      by mikey5791
                      Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                      Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                      My questions are
                      1. How do i test to see if the transformer is in good working condition?
                      2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                      Hope you guys understand what i was asking. My intention is...
                      11-03-2022, 02:11 AM
                    • x_orange90_x
                      by x_orange90_x
                      01-29-2025, 09:24 PM
                      ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                      This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 04:40 PM
