HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
  • ahmedtou
    • Aug 2025
    • 5
    • ALGERIA
    help me please
    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
    Click image for larger version  Name:	Capture.png Views:	0 Size:	29.0 KB ID:	3713121
    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
    I will share all the details with you, including the disc information.
    Click image for larger version  Name:	Capture1.png Views:	0 Size:	14.2 KB ID:	3713122
    Code:
    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12,219,392
    Free Space: 25,025,314,816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next Writable Address: 0
    MID: RITEK-BR3-000
    Supported Write Speeds: 2x
    Disc Definition Structure:
    Certified: No
    Scanned: No
    BD Disc Information:
    Disc ID: RITEK-BR3-000
    Disc Type: BD-R
    Disc Size: 120 mm
    Disc Class: 0
    Disc Version: 1
    Disc Time Stamp: 10/2010
    Code:
    I 12:36:21 ImgBurn Version 2.5.8.0 started!
    I 12:36:21 Microsoft Windows 8 Professional Edition (6.2, Build 9200)
    I 12:36:21 Total Physical Memory: 2,031,156 KiB  -  Available: 1,445,516 KiB
    I 12:36:21 Initialising SPTI...
    I 12:36:21 Searching for SCSI / ATAPI devices...
    I 12:36:22 -> Drive 1 - Info: HL-DT-ST BD-RE  GGW-H20N XA02-03 (F:) (ATA)
    I 12:36:22 Found 1 HD DVD-ROM/BD-RE!
    I 12:42:25 Operation Started!
    I 12:42:25 Source File: C:\Users\vendour-pc\Desktop\BD-J 2\Lapse-1.2.iso
    I 12:42:25 Source File Sectors: 2,576 (MODE1/2048)
    I 12:42:25 Source File Size: 5,275,648 bytes
    I 12:42:25 Source File Volume Identifier: BD-JB
    I 12:42:25 Source File Volume Set Identifier: 68AAA07468AA9F0D
    I 12:42:25 Source File Implementation Identifier: NetBSD makefs 10.0
    I 12:42:25 Source File File System(s): UDF (1.02)
    I 12:42:25 Destination Device: [1:0:0] HL-DT-ST BD-RE  GGW-H20N XA02 (F:) (ATA)
    I 12:42:25 Destination Media Type: BD-R (Disc ID: RITEK-BR3-000)
    I 12:42:25 Destination Media Supported Write Speeds: 2x
    I 12:42:25 Destination Media Sectors: 12,219,392
    I 12:42:25 Write Mode: BD
    I 12:42:25 Write Type: DAO
    I 12:42:25 Write Speed: 2x
    I 12:42:25 Hardware Defect Management Active: No
    I 12:42:25 BD-R Verify Not Required: Yes
    I 12:42:26 Link Size: Auto
    I 12:42:26 Lock Volume: Yes
    I 12:42:26 Test Mode: No
    I 12:42:26 OPC: No
    I 12:42:26 BURN-Proof: Enabled
    I 12:42:26 Write Speed Successfully Set! - Effective: 8,991 KB/s (2x)
    I 12:42:42 Filling Buffer... (80 MiB)
    I 12:42:42 Writing LeadIn...
    W 12:42:42 Failed to Write Sectors 96 - 127 - Reason: Write Error
    W 12:42:42 Retrying (1 of 20)...
    W 12:42:42 Retry Failed - Reason: Invalid Address For Write
    W 12:42:42 Retrying (2 of 20)...
    W 12:42:42 Retrying (3 of 20)...
    W 12:42:42 Retrying (4 of 20)...
    W 12:42:42 Retrying (5 of 20)...
    W 12:42:42 Retrying (6 of 20)...
    W 12:42:42 Retrying (7 of 20)...
    W 12:42:42 Retrying (8 of 20)...
    W 12:42:42 Retrying (9 of 20)...
    W 12:42:42 Retrying (10 of 20)...
    W 12:42:42 Retrying (11 of 20)...
    W 12:42:42 Retrying (12 of 20)...
    W 12:42:43 Retry Failed - Reason: Invalid Address For Write
    W 12:42:43 Retrying (13 of 20)...
    W 12:42:43 Retrying (14 of 20)...
    W 12:42:43 Retrying (15 of 20)...
    W 12:42:43 Retrying (16 of 20)...
    W 12:42:43 Retrying (17 of 20)...
    W 12:42:43 Retrying (18 of 20)...
    W 12:42:43 Retrying (19 of 20)...
    W 12:42:43 Retrying (20 of 20)...
    E 12:43:10 Failed to Write Sectors 96 - 127 - Reason: Write Error
    E 12:43:10 Next Writable Address: 0
    I 12:43:10 Synchronising Cache...
    W 12:43:11 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Write Error
    W 12:43:11 Synchronise Cache Failed! - Reason: Write Error
    E 12:43:13 Synchronise Cache Failed! - Reason: Write Error
    I 12:43:15 Closing Track...
    W 12:43:15 Close Track Failed! - Reason: Cannot Write Medium - Incompatible Format
    E 12:43:16 Close Track Failed! - Reason: Cannot Write Medium - Incompatible Format
    I 12:43:16 Finalising Disc...
    W 12:43:16 Finalise Disc Failed! - Reason: Cannot Write Medium - Incompatible Format
    E 12:43:17 Finalise Disc Failed! - Reason: Cannot Write Medium - Incompatible Format
    E 12:43:17 Failed to Write Image!
    E 12:43:17 Operation Failed! - Duration: 00:00:51
    I 12:43:17 Average Write Rate: 0 KiB/s (0.0x) - Maximum Write Rate: 0 KiB/s (0.0x)
    I have searched extensively for firmware updates that could help, but to no avail. All the updates I found did not recognize my drive in order to proceed with the update.
    Click image for larger version  Name:	Untitled.png Views:	0 Size:	28.1 KB ID:	3713123
    Most recently, I managed to dump the drive’s firmware and analyzed it using the MediaCodeSpeedEdit tool.
    Upon inspection, I discovered that the types of discs "RITEK-BR3-000 "I’m trying to burn are not listed in the supported media list, which explains why burning fails when using ImgBurn.​
    Code:
    Media Code Speed Edit V 1.2.0.10
    Firmware: BD-RE  GGW-H20N  XA02-03 011508
    Bootcode: GGW-H20NCORE
    Overall  supported media types:  435
    DVD+R9   supported media types:   20
    DVD+R    supported media types:  107
    DVD+RW   supported media types:   31
    DVD-R9   supported media types:   12
    DVD-R    supported media types:  171
    DVD-RW   supported media types:   46
    BD-R     supported media types:   23
    BD-R DL  supported media types:    6
    BD-RE    supported media types:   16
    BD-RE DL supported media types:    3
    CMC MAG  D01-000 2.4x
    CMC MAG  D03-064 4x,2.4x
    CMC MAG  D04-000 4x,2.4x
    DEFAULT  16X-000 12x,8x,4x
    DEFAULT  8X -000 2.4x
    INFOME   D01-000 2.4x
    JVCco    RD2-065 2.4x
    KIC00000 D20-000 2.4x
    MBIPG101 R10-065 4x,2.4x
    MKM      001-000 2.4x
    MKM      003-000 8x,4x
    MKM      004-000 12x,8x,4x
    PHILIPS  CD2-000 2.4x
    RICOHJPN D00-001 2.4x
    RICOHJPN D01-002 8x,4x
    RICOHJPN D01-067 8x,4x
    RICOHJPN D02-076 12x,8x,4x
    RITEK    D01-001 2.4x
    RITEK    S01-001 2.4x
    RITEK    S04-066 4x,2.4x
             001-000 2.4x
             001-000 8x,4x
    AML      001-000 4x,2.4x
    AML      002-000 8x,4x
    AML      003-000 16x,12x,8x,4x
    BEALL P0 001-000 2.4x
    BeAll000 P40-000 4x,2.4x
    BeAll000 P80-000 8x,4x
    BeAll000 PG0-000 16x,12x,8x,4x
    CMC MAG  E01-000 8x,4x
    CMC MAG  F01-000 4x,2.4x
    CMC MAG  M01-000 16x,12x,8x,4x
    CMC MAG  R01-000 2.4x
    DAXON    AZ1-001 4x,2.4x
    DAXON    AZ2-000 8x,4x
    DAXON    AZ3-000 16x,12x,8x,4x
    DAXON    CY3-000 16x,12x,8x,4x
    DDDessau V30-000 8x,4x
    DDT 01   001-001 4x,2.4x
    DEFAULT  16 -000 16x,12x,8x,4x
    DEFAULT  2_4-000 2.4x
    DEFAULT  4  -000 4x,2.4x
    DEFAULT  8  -000 8x,4x
    DT-D03   004-000 8x,4x
    Dvsn+160 001-000 16x,12x,8x,4x
    EMDPAZ01 000-000 12x,8x,4x
    INFODISC R10-002 4x,2.4x
    INFODISC R20-000 8x,4x
    INFOME   R20-000 8x,4x
    INFOME   R30-000 16x,12x,8x,4x
    IS01     001-000 4x,2.4x
    KIC00000 S80-000 8x,4x
    LGEP16   001-000 16x,12x,8x,4x
    MAM      M02-000 8x,4x
    MAM..... M04-000 16x,12x,8x,4x
    MAXELL   001-000 4x,2.4x
    MAXELL   002-000 8x,4x
    MAXELL   003-000 16x,12x,8x,4x
    MBIPG101 R03-000 4x,2.4x
    MBIPG101 R04-001 8x,4x
    MBIPG101 R05-001 16x,12x,8x,4x
    MCC..... 001-000 2.4x
    MCC..... 002-000 4x,2.4x
    MCC..... 003-000 8x,4x
    MCC..... 004-000 16x,12x,8x,4x
    MICRON   001-000 8x,4x
    MJC      003-000 8x,4x
    MJC      005-000 12x,8x,4x
    MUST     006-000 16x,12x,8x,4x
    MUST     006-002 16x,12x,8x,4x
    NAN YA   FLX-000 16x,12x,8x,4x
    NANYA    CHX-000 8x,4x
    NANYA    CLX-000 8x,4x
    NANYA    RJB-000 8x,4x
    NOT USED 000-000 8x,4x
    NOT USED 000-000 12x,8x,4x
    NSD      R40-000 16x,12x,8x,4x
    OPTODISC F16-000 12x,8x,4x
    OPTODISC OP1-001 2.4x
    OPTODISC OR4-000 4x,2.4x
    OPTODISC OR8-000 8x,4x
    OPTODISC R16-000 16x,12x,8x,4x
    PHILIPS  C08-000 8x,4x
    PHILIPS  C16-000 12x,8x,4x
    PHILIPS  C16-001 16x,12x,8x,4x
    PRODISC  R01-001 2.4x
    PRODISC  R02-000 4x,2.4x
    PRODISC  R03-003 8x,4x
    PRODISC  R04-004 16x,12x,8x,4x
    PRODISC  R05-001 16x,12x,8x,4x
    Philips  081-000 8x,4x
    RICOHJPN R00-001 2.4x
    RICOHJPN R01-002 4x,2.4x
    RICOHJPN R02-003 8x,4x
    RICOHJPN R03-004 12x,8x,4x
    RICOHJPN R03-012 16x,12x,8x,4x
    RITEK    F16-001 16x,12x,8x,4x
    RITEK    M02-001 4x,2.4x
    RITEK    P16-000 16x,12x,8x,4x
    RITEK    R01-001 2.4x
    RITEK    R02-001 4x,2.4x
    RITEK    R03-001 8x,4x
    RITEK    R03-002 8x,4x
    RITEK    R04-001 16x,12x,8x,4x
    RITEK    R05-001 12x,8x,4x
    SKC      P80-000 8x,4x
    SONY     D01-000 4x,2.4x
    SONY     D11-000 8x,4x
    SONY     D21-000 16x,12x,8x,4x
    TDK      001-000 4x,2.4x
    TDK      002-000 8x,4x
    TDK      003-000 12x,8x,4x
    TDK      003-000 16x,12x,8x,4x
    UME      002-000 8x,4x
    VDSPMSAB 004-000 12x,8x,4x
    WFKA11   111-000 4x,2.4x
    WFKA11   211-000 8x,4x
    WFKA11   321-000 12x,8x,4x
    WINGSHIN 001-000 8x,4x
    YUDEN000 T01-000 4x,2.4x
    YUDEN000 T01-001 4x,2.4x
    YUDEN000 T02-000 8x,4x
    YUDEN000 T03-000 16x,12x,8x,4x
    CMC MAG  W01-000 2.4x
    CMC MAG  W02-000 4x,2.4x
    CMC MAG  W03-000 8x,4x
    DAXON    D42-000 4x,2.4x
    INFODISC A01-001 2.4x
    INFODISC A10-001 4x,2.4x
    MBIPG101 W04-000 4x,2.4x
    MBIPG101 W05-000 8x,4x
    MCC..... A01-000 2.4x
    MKM      A02-000 4x,2.4x
    MKM      A03-000 8x,4x
    NANYA    DRW-000 4x,2.4x
    OPTODISC OP4-001 4x,2.4x
    OPTODISC OP8-001 8x,4x
    PHILIPS  010-049 2.4x
    PHILIPS  041-000 4x,2.4x
    PHILIPS  RW8-000 8x,4x
    PRODISC  W01-002 2.4x
    PRODISC  W02-000 4x,2.4x
    RICOHJPN W01-001 2.4x
    RICOHJPN W11-001 4x,2.4x
    RICOHJPN W21-001 8x,4x
    RITEK    001-001 4x,2.4x
    RITEK    004-048 4x,2.4x
    RITEK    008-000 8x,4x
    SENTINEL W02-000 4x,2.4x
    SONY     S11-000 4x,2.4x
    CMC MAG. AD4    4x,2x
    DEFAULT         2x
    DEFAULT 12X     2x
    DEFAULT 8X      2x
    JVC-RD40        2x
    MKM 01RD30      4x,2x
    MKM 03RD30      8x,4x
    MKM 04RD30      4x,2x
    MXL RGD02       4x,2x
    PRINCORDL32     4x,2x
    RITEKP01        4x,2x
    TYG11           4x,2x
    1FUJIFILM       2x
    AML             4x,2x
    AN32            4x,2x
    BEAll G001      2x
    BeAll G16001    16x,12x,8x,4x
    BeAll G40001    4x,2x
    BeAll G80001    8x,4x
    BeAllG00001     2x
    CMC MAG.        2x
    CMC MAG. AE1    8x,4x
    CMC MAG. AF1    4x,2x
    CMC MAG. AM1    12x,8x,4x
    CMC MAG. AM3    16x,12x,8x,4x
    CMC00RG200      2x
    CMC00RG300      2x
    DATA TRACK      4x,2x
    DAXON004        4x,2x
    DAXON008S       8x,4x
    DAXON016        16x,12x,8x,4x
    DAXON016S       16x,12x,8x,4x
    DDT01           4x,2x
    DDTRG001        4x,2x
    DDTRG002        8x,4x
    DEFAULT 16X     16x,12x,8x,4x
    DEFAULT 2X      2x
    DEFAULT 4X      4x,2x
    DEFAULT 8X      8x,4x
    Dvsn            4x,2x
    Dvsn A001       4x,2x
    EDMA01          12x,8x,4x
    FORNEX101       4x,2x
    FUJIFILM02      4x,2x
    FUJIFILM03      8x,4x
    FUJIFILM04      16x,12x,8x,4x
    GSC001          4x,2x
    GSC001          2x
    GSC001          4x,2x
    GSC002          4x,2x
    GSC003          8x,4x
    GSC004          8x,4x
    GSC005          16x,12x,8x,4x
    IMC JPN R01     8x,4x
    INFOD K-R01     2x
    INFODISC-R01    4x,2x
    INFODISC-R20    8x,4x
    INFOMEDIAR20    8x,4x
    INFOMEDIAR30    12x,8x,4x
    INFOMEDIAR30    16x,12x,8x,4x
    INFOSMART01     4x,2x
    KIC 00RG200     2x
    KIC01RG080      8x,4x
    KIC01RG160      16x,12x,8x,4x
    KIC01RG20       4x,2x
    LEADDATA S03    8x,4x
    LEADDATA S04    12x,8x,4x
    LEADDATA01      4x,2x
    LGE             2x
    LGE04           4x,2x
    LGE08           8x,4x
    LGE16           16x,12x,8x,4x
    LONGTEN 001     2x
    LONGTEN 001     4x,2x
    MAM8XG01        8x,4x
    MAMSXG01        16x,12x,8x,4x
    MBI 01RG20      4x,2x
    MBI 01RG40      16x,12x,8x,4x
    MBI 03RG30      8x,4x
    MBI 03RG40      16x,12x,8x,4x
    MCC 00RG200     2x
    MCC 01RG20      4x,2x
    MCC 02RG20      8x,4x
    MCC 03RG20      16x,12x,8x,4x
    MCIG01          2x
    ME 153          4x,2x
    MEI 00V001      2x
    MEI 00V002      4x,2x
    MEI 00V003      2x
    MUST 001        4x,2x
    MUST 003        8x,4x
    MXL RG01        2x
    MXL RG01        2x
    MXL RG02        4x,2x
    MXL RG03        8x,4x
    MXL RG04        12x,8x,4x
    MXL RG04        16x,12x,8x,4x
    NAN YA A01      8x,4x
    NAN YA F02      16x,12x,8x,4x
    NANYA-JC001     4x,2x
    NOT USED        8x,4x
    NOT USED        8x,4x
    NOT USED        8x,4x
    NOT USED        8x,4x
    NOT USED        8x,4x
    NOT USED        8x,4x
    NOT USED        8x,4x
    NOT USED        8x,4x
    NOT USED        12x,8x,4x
    NOT USED        12x,8x,4x
    NOT USED        12x,8x,4x
    NOT USED        12x,8x,4x
    NOT USED        12x,8x,4x
    NOT USED        12x,8x,4x
    NSDR40          16x,12x,8x,4x
    ONIDTECH        4x,2x
    OPTODISC        2x
    OPTODISCK001    2x
    OPTODISCK001    4x,2x
    OPTODISCK001    4x,2x
    OPTODISCR004    4x,2x
    OPTODISCR004    4x,2x
    OPTODISCR008    8x,4x
    OPTODISCR016    16x,12x,8x,4x
    POSG04          4x,2x
    POSG06          8x,4x
    PRINCO         2x
    PRINCO          2x
    PRINCO          4x,2x
    PRINCO          4x,2x
    PRINCO          4x,2x
    PRINCO          4x,2x
    PRINCO          4x,2x
    PRINCO          4x,2x
    PRINCO8X02      8x,4x
    PRODISCG02      2x
    PVC001001       2x
    PVCR001002      4x,2x
    Plasmon1A       8x,4x
    ProdiscF01      8x,4x
    ProdiscF02      16x,12x,8x,4x
    ProdiscS03      4x,2x
    ProdiscS04      8x,4x
    ProdiscS05      16x,12x,8x,4x
    RITEKF1         16x,12x,8x,4x
    RITEKG01        2x
    RITEKG03        2x
    RITEKG04        4x,2x
    RITEKG05        8x,4x
    RITEKG06        8x,4x
    RITEKG07        16x,12x,8x,4x
    RITEKM02        4x,2x
    RITEKM16        16x,12x,8x,4x
    SKC Co.,Ltd.    2x
    SKC Co.,Ltd.    4x,2x
    SKC Co.,Ltd.    4x,2x
    SKC M801        8x,4x
    SONY            2x
    SONY04D1        4x,2x
    SONY08D1        8x,4x
    SONY16D1        16x,12x,8x,4x
    TAIYOYUDEN..    2x
    TAROKO-MX4      4x,2x
    TDKG010000d9    2x
    TDKG02000000    2x
    TMI001.2003     4x,2x
    TTG01           4x,2x
    TTG02           8x,4x
    TTH01           8x,4x
    TTH02           12x,8x,4x
    TTH02           16x,12x,8x,4x
    TYG01           4x,2x
    TYG02           8x,4x
    TYG02           8x,4x
    TYG03           16x,12x,8x,4x
    UME01           8x,4x
    UTJR001001      4x,2x
    VANGUARD        4x,2x
    VANGUARD01      8x,4x
    VDSPMSAB 01     4x,2x
    WFI A40001      4x,2x
    WFI A80001      8x,4x
    Yi Jhan 001     4x,2x
    CMCW02          2x
    CMCW03          4x,2x
    CMCW04          6x,4x,2x
    DAXON_RW2X01    2x
    DEFAULT 1X      1x
    DEFAULT 2X      2x
    DEFAULT 4X      4x,2x
    DEFAULT 6X      6x,4x,2x
    INFOMEDIAA20    4x,2x
    JVC/VictorT7    1x
    JVC0VictorD7    4x,2x
    JVC1Victord7    6x,4x,2x
    JVC_VictorW7    1x
    JVC_VictorW7    2x
    JVC_VictorW7    2x
    MBI01RWG 20     4x,2x
    MCC 00RW11N9    1x
    MCC 01RW11n9    2x
    MCC 01RW11n9    2x
    MCC 01RW4X      4x,2x
    MKM 01RW6X01    6x,4x,2x
    OPTODISCK001    1x
    OPTODISCK001    2x
    OPTODISCW002    2x
    OPTODISCW004    4x,2x
    OPTODISCW006    6x,4x,2x
    PRINCO          1x
    PRINCO          2x
    PVCW000001Q9    1x
    PVCW00D002K9    2x
    PVCW00V00245    2x
    Prodisc DW04    2x
    Prodisc DW06    4x,2x
    ProdiscDVDRW    1x
    RITEK000V11A    1x
    RITEK004V11     1x
    RITEKW01        2x
    RITEKW04        4x,2x
    RITEKW06        6x,4x,2x
    SONY000000U9    1x
    TDK401saku=3    1x
    TDK501saku]3    1x
    TDK502sakuM3    2x
    TDK502sakuM3    2x
    TDK601saku      4x,2x
    TDK701saku      6x,4x,2x
    CMCMAG   BA2-000 2x
    CMCMAG   BA3-000 4x,2x
    MAXELL   RS1-000 6x,4x,2x
    MAXELL   RS2-000 6x,4x,2x
    MEI      T01-001 2x
    MEI      T02-001 4x,2x
    NO_ID_   NO_-000 4x,2x
    NO_ID_   NO_-000 6x,4x,2x
    PHILIP   R02-000 4x,2x
    PHILIP   R04-000 4x,2x
    RICOH    R01-000 2x
    RICOH    R02-000 4x,2x
    RITEK    BR1-000 2x
    RITEK    BR1-000 2x
    SONY     NO_-001 2x
    SONY     RBA-001 2x
    TDKBLD   RBA-000 4x,2x
    TDKBLD   RBB-000 6x,4x,2x
    VERBAT   IMa-000 6x,4x,2x
    VERBAT   IMc-000 6x,4x,2x
    VERBAT   IMz-000 2x
    MEI      T01-000 4x,2x
    MEI      T01-001 2x
    NO_ID_   NO_-000 2x
    TDKBLD   RFA-000 2x
    TDKBLD   RFB-000 4x,2x
    VERBAT   IMb-000 4x,2x
    CMCMAG   CN2-000 2x
    CMCMAG   CN2-000 2x
    IMATN    E_2-000 2x
    JVCRE1   101-001 2x
    JVCRE1   101-001 2x
    LGEBRE   S01-000 2x
    MAXELL   ES1-000 2x
    MEI      T01-001 2x
    NO_ID_   NO_-000 1x
    PHILIP   W02-000 2x
    RITEK    BW1-000 2x
    RITEK    BW1-000 2x
    SONY     ES1-001 2x
    SONY     NO_-001 2x
    TDKBLD   WBA-000 2x
    VERBAT   IM0-000 2x
    MEI      T01-000 2x
    NO_ID_   NO_-000 1x
    TDKBLD   Wfa-000 2x
    -My questions are:
    1-How can I update this type of drive?
    2-Is it possible to modify or patch the current firmware file?
    3-Can the drive be flashed with a different firmware, such as XL07 instead of XA02?
    4- Where can I find the dump file for version XL07?
    If anyone has experience with this or has attempted something similar, I would really appreciate your input.​
    • 31214
    https://www.hd-dvd.org/firmware.html#ggw-h20n
    • ahmedtou
      • Aug 2025
      • 5
      • ALGERIA
      the same drive not detected by driveUpdate tool
        • 31214
        running as admin?
        • Ahmedtoufik
          • Aug 2025
          • Algeria
          Originally posted by stj
          running as admin?
          Yes, I tried all the methods, but after you gave me the link, I noticed that it’s possible to cross-flash it, so I thought, why not try converting it and then converting it back to XL07? I downloaded another firmware and faced the same issue, so I considered putting it into flash mode or safe mode—I’m not sure what it’s called. The method is to turn off the computer, then hold the eject button and power on the computer for about ten seconds.
          After the computer booted up, I was able to flash it normally with the XL07 firmware without converting it first.
          The strange thing is, I had tried this before and it didn’t work—I don’t know why it worked this time.
          Thank you, you help me 🙏 ❤️
            • 31214
            the XL07 is the best firmware from what i could see.
            glad you got it flashed.
            • Ahmedtoufik
              • Aug 2025
              • Algeria
              Yes, I dumped the new XL07 firmware from my drive and checked it again using Media Code Tool. It supports a wide range of disc types, including the one I have: RITEK-BR3-000. I also successfully burned a disc with it 🙏❤️
              Thanks again my brother 😊
              • ChaosLegionnaire
                bug of the month: write caching setting for the hard drive in device manager
                by ChaosLegionnaire
                i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                10-06-2019, 01:39 PM
              • vbogoev
                Lenovo S6000 won't turn on. Data recovery needed.
                by vbogoev
                Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                Code:
                [PWRAP] pwrap_init_preloader
                [PWRAP] pwrap_init
                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                [PMIC_WRAP]wrap_init pass,the return
                06-20-2023, 06:36 AM
              • alphabetty
                novice user attempting first BIOS write on ASUS laptop
                by alphabetty
                Hello first post!
                Ok so after an (ASUSTek) optional Windows update, my old ASUS E403NA laptop rebooted and froze in the BIOS menu screen and was unresponsive so after about 30 mins I powered off and back on again. Now i just get a power LED and a black screen, I have tried all the basic suggestions and all the suggestions on the ASUS site, spoke to ASUS support who said I will need to pay for an RMA.
                The laptop is worth €50 so I won't be doing the RMA at god knows what price.
                So I have seen some videos where people have reprogrammed the BIOS...
                03-07-2024, 08:31 AM
              • CapThatBrass
                RT809F Chip Write Failure - Winbond 25R256JV
                by CapThatBrass
                I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
                I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
                The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
                10-04-2022, 11:56 AM
              • lalle-
                Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                by lalle-
                Hello!
                I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                08-11-2024, 02:01 PM
