lg 47le5400 powers up, black screen, no sound
    Re: lg 47le5400 powers up, black screen, no sound
    You count the pins wrong, please upload good clear pictures of the connector and the pin labels as printed on the board, it helps to show pictures of your power supply board since there are more than one version of the boards used in this TV model.
    https://www.shopjimmy.com/catalogsea...?q=lg+47le5400
    The connector has odd column number pins and even column number pins.
    • maxim22
      • Oct 2013
      • 5
      Originally posted by maxim22
      In PowerOn mode all voltages seem to be OK except PowerOn voltage (pin 1) which is 3.23V instead of 20V (as written on the board).
      In StandBy mode there is only 3.4 V on 2 pins (pin5,6), all others are 0V.
      I got a light on the screen by 2 jumpers from 3.4 V pins to Drv ON and Power On pins. Previously disconnected power connector on the main board as visible on the picture.
      Another picture shows voltages on the connector.
      • maxim22
        • Oct 2013
        • 5
        There is also 12.5 V on pins 2,3,4 in the 2nd row from top.
          The exposed pins you see on the top side of the board are the odd number pins, pin 1 is marked with black arrow, the even number pins you you have to probe from the bottom side of the board or from the backside of the female connector.
          So if you have all connector in place but you do not have DRV-ON which is from the main board then you need to troubleshoot the main board next.
          • maxim22
            • Oct 2013
            • 5
            The picture with voltages is actually the bottom of the connector. Do you have any tips for the main board? I tried heating the board at 385F in the oven but no luck.
              What you can do to see if other function of the main board, T-CON board, LCD panel are OK or not is to put all the connectors back in place then disconnect the DRV wire going back to the main board and then force on the backlights and see if you will get pictures on the screen, sound, and all the function or not, if not then you have more than just bad DRV control signal.
              More likely the MCU needs to be reballed, baking in the oven may or may not work and it is usually go bad again.
              • diif
                • Feb 2014
                • 6978
                • England
                #27
                Originally posted by Jov4e@lazarev
                Hi I HAVE THE SAME PROBLEM TV TURNS ON BUT NO BACKLIGHT NO PICTURE NO SOUND.I BAKING THE MAIN BOARD IN THE OVEN 200C ON 10 MINUTES BUT NO RESULTS.TV MODEL LG 42LE5500
                It's not a cake, there is no baking involved, you are trying to get the solder balls under the processor to remelt and remake any broken solder connections.
                Lead free solder melts at around 220c.
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  #28
                  That around 428° farenheit. That temp will melt every plastic piece and cause most capacitors to explode.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #29
                    Probably, I wouldn't know having a BGA rework machine and only knowing centigrade.
                    The point I was trying to make is that baking at 200c/385f is kinda pointless.
                      • 12201
                      • U.S.
                      #30
                      Only a temporary fix if successful, trick is to melt the solder under the chip, OVERHEATING can kill the chip, lots of videos on youtube, one guy uses an old repurposed halogen floor lamp.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #31
                        I watch some videos on YouTube they put the motherboard in the oven because Im not professionalI think that will help but nothing can I try with with hair dryer I dont have heat gun
                        If it gets hot enough yes a hair dryer can be used. I have also seen examples where a tea light candle was used.
                        https://www.geektechnique.org/projec...rd-repair.html
                        https://www.overclock.net/forum/69-n...-tealight.html
                        Probably safer than heating the whole board in the oven to 220c.
                        Perhaps it would be worth investing in a cheap thermometer/thermocouple so you know the correct temperature has been reached. Also don't forget flux.
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • Audeze
                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                          by Audeze
                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                          Does...
                          10-06-2024, 08:54 PM
                        • HTR-Informatique
                          by HTR-Informatique
                          02-09-2025, 06:51 AM
                        • totof
                          LG 43UF640V backlight good but black screen and no sound
                          by totof
                          Good morning.
                          I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                          I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                          In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                          HVDD : 7,28...
                          04-13-2024, 11:37 PM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
