Philips 37PFL8605 help
  • focus6666
    • Jun 2017
    • 3
    • Bosnia
    Hi friends
    I recently bought Philips 37PFL8605 , but I have problems with picture.
    When I turn on TV I have vertical strips in middle of screen, and T-Con is overheating , these two ICs on Tcon get very hot.
    Also my power supply gets hot, only on transformer marked as 2NP000080DA-R.
    I want to order new boards, but I can not diagnose fault, is it bad T-Con ,or power supply or lcd panel.
    Can you please help me with diagnose.
    Thank you
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Philips 37PFL8605 help
    post a picture of the screen problem.
    advanced, manage attachments, then upload the pic.
    from there it will appear as a thumb tile that we can blow up if we need to.
    add a pic of the entire rear of the tv too thanks.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • focus6666
      • Jun 2017
      • 3
      • Bosnia
      Here you can see vertical lines I have on display.
      • dskall
        • Oct 2016
        • 2905
        • usa
        I would say bad panel. Possibly something shorted on panel pcb
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          if you slightly flex the panel, (bottom edge in this case), does the picture change at all?
          and is the fault over the menu screen?
            One of those tab bonding board on the bottom edge of the panel which gets damage by the cleaning fluid, so look for corrosion on that area of the tab bonding board.
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • tehmatix
              Pc monitor Philips 279M1 - red vertical stripe
              by tehmatix
              I got this monitor Philips 279M1 and the issue is : when is cold (turn off for few hours, not in standby) and turn it on it's coming whit a red vertical stripe. After 5 minutes or less (depend on the room temperature) the stripe disappearing
              A short video
              https://youtu.be/gj5vKF_xBMU...
              06-09-2023, 09:42 AM
            • mopenstein
              Looking for Vertical IC for RCA Chassis CTC159L CRT
              by mopenstein
              I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
              Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
              I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
              09-24-2023, 10:41 AM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
