Hisense LHD32D33EU repair, vertical lines, T-CON, BOE HV320WX2-206 cell
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    No solution to this one yet. Possibly there won’t be any.
    Vertical lines covering all the panel, they depend on image. See pictures. Greenish one is with antena connected. Blueish one is without antena. White strip moves every second, I guess there’s a "no signal" screen saver moving along the screen. See the rounded "aura" that looks very familiar to T-CON problems.
    Visual inspection at T-CON is normal, nothing burnt or ugly. It has a Global Mixed Mode G5562A Bias Power Supply IC. It has two coils and two diodes (DC-DC). One measures 16V and the other is 3.3V. I can measure other T-CON testpoints if they’re relevant to this issue.
    Can it be saved?
  • Diah
    • Feb 2013
    • 6599
    Re: Hisense LHD32D33EU repair, vertical lines, T-CON, BOE HV320WX2-206 cell
    read my post about Hisense, i had white and solve it with Flash LCD driver, search your model at different region of Hisense, and flash complete firmware it may help
    try this i found at spain server
    http://www.hisense.es/es/descargas-d...are-lhd32d33eu
    • Chungalin
      • Jul 2014
      • 423
      • Spain
      I’d have bet that this is no FW problem at all, but I’ve tried anyway. It’s risky to upgrade FW without seeing anything on screen. Connected USB with bin file and plugged the TV. LED starts flashing between blue and red, slowly. After a minute it blinks faster, indefinitely. After 10 minutes I decide to unplug and plug again. Same problem, as expected. Now it seems it has lost tuned TV channels.
      • Diah
        • Feb 2013
        • 6599
        after Flash finished the Tv go to standby mode. so no need to unplug it.. how about when it start show the logo correct.? if no, then need first to inspect the panel taps if there water damage.
        • Chungalin
          • Jul 2014
          • 423
          • Spain
          Not in my case. I've tried two times. Got tired of waiting for it to go to standby after 15 minutes. I don't know if it has updated, but now I'm unable to put it in TV mode. No improvement in image.
          I've removed front frame to inspect LCD glass borders and tab bonds. Nothing to report. No abnormal dirtiness or cracks.
          Seems bad LCD panel to me.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            have you disconnected one of the ribbon cables that links from the t-con to the panel to see if you get half a clear picture. do each side and see what happens.
            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
            • Chungalin
              • Jul 2014
              • 423
              • Spain
              This T-CON is not detachable. It’s a long PCB that has 4 tab bonds that go directly to LCD panel. No connectors. I’ve touched every tab bond with no changes in image.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                doh, not sure if you had a shorted cap on the panel driver board, that it would give you a pic at all, but worth checking.
                • Chungalin
                  • Jul 2014
                  • 423
                  • Spain
                  Thanks for all advice and ideas. This case is closed with no solution and the TV is back to the customer.
                  • geeforce
                    • Oct 2017
                    • 87
                    This looks like the same problem as a tv I was thinking of buying... Maybe I should avoid it...
                    Haven't physically seen it however.
                    • kajubi
                      From Uganda
                      • Sep 2013
                      • 5
                      • Uganda
                      I can easily fix this in just 30 minutes .That problem is related to missing Von or Voff on the COF ,the Cofs comes in about three different types .You will have yo bypass that missing voltage using a very small wire for my case I get those wires from 12v Relays .For more info about this am always available at no charge.Even on other models.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Then feel free at no charge to start a thread documenting how to do this repair next time you fix one.
                        • Stanley1843
                          by Stanley1843
                          06-29-2024, 11:54 AM
                        • pni
                          LG 49uf695v vertical coloured lines
                          by pni
                          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                          11-14-2025, 03:15 AM
                        • Daren87
                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                          by Daren87
                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                          08-13-2023, 03:25 PM
                        • Falki
                          Colorful LCD Vertical Lines on Samsung ue55es8090
                          by Falki
                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                          A similar issue has been posted as well but also with no actual response ...
                          08-12-2025, 04:19 AM
                        • gpo23
                          Sony KDL-40V3000 - Vertical lines
                          by gpo23
                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                          With the new t-con the color are good but there are vertical lines on all the screen :
                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                          Is there a way to fix the vertical lines on the new t-con ?
                          Thank you for your help
                          gpo23...
                          10-04-2023, 09:11 AM
