Samsung UE50H6400AK Panel or T-Con? Has Backlights And Audio
  • Ridahz
    • May 2017
    • 32
    • United Kingdom
    Hi Guys! Had to join this forum as the advice is top quality and right now I'm in desperate need of some help.
    The other day I purchased this model for £120 thinking I'd be able to replace the T-Con and be up and running. I'm now having doubts to say the least lol.
    Basically the TV has backlights and sound. But after reading some posts I thought I'd try the 1 ribbon to the T-Con and here's my results...
    Right T-con plugged in half screen goes white for a second then goes black again with backlights and audio.
    Left strip plugged in I get half a screen with working picture and audio and the left side of the screen goes white with a line down it.
    I've read similar posts where Budm has mentioned this being down to a bad panel but they were relatively old posts and I don't know if fixes and methods have come up since then.
    I currently have a T-Con on order from eBay ATM but beginning to have lost faith before it even arrives. Is the panel bad or could it actually be the T-Con? I have not used a multimeter to test any readings yet as I don't actually have a clue what I'd be looking for.
    Any advice would be greatly appreciated. I will post pics asap if required.
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Samsung UE50H6400AK Panel or T-Con? Has Backlights And Audio
    post some pics, but it sounds like panel.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • Ridahz
      • May 2017
      • 32
      • United Kingdom
      Hi! Hopefully I've attached these pics correctly. Sorry for the bad quality in advance.
      This is what i see when the left side LCD ribbon is plugged into the T-Con.
      • Ridahz
        • May 2017
        • 32
        • United Kingdom
        Any ideas anyone?
        • dskall
          • Oct 2016
          • 2905
          • usa
          One side would seem to have problem. If it were me I would be looking for shorts on the panel pcb
          • Ridahz
            • May 2017
            • 32
            • United Kingdom
            Hi bud.
            Just had a look over the panel and ribbons and they look immaculate all the way down the strips. No damage/burns at all! Tried jiggleing and tapping them and nothing on the screen was affected it just stayed the exact same. Left me completely lost with it all lol.
            Did the same thing with 1 ribbon taken out the T-Con and when the LCD was half displaying there was 3 blue lights illuminated on the T-Con. When I put the other side in where all I can see is backlights only 2 lights were illuminated on the T-Con. Exact same 2 blue lights illuminated when both ribbons are inserted. Don't understand why and where the issue lies. Will upload pics in a minute
            • dskall
              • Oct 2016
              • 2905
              • usa
              I would check voltages on t-con with each ribbon removed one at a time to see if any voltages getting dragged down on one side of panel.
              • Ridahz
                • May 2017
                • 32
                • United Kingdom
                Both Ribbons plugged in
                1 Ribbon inserted where I can see half the panel
                • Ridahz
                  • May 2017
                  • 32
                  • United Kingdom
                  Any idea which parts I should check bud? Also you think it could be a bad panel or T-Con?
                  • zomi
                    • Nov 2011
                    • 505
                    I would check for shorted caps on the lcd board.
                    • Ridahz
                      • May 2017
                      • 32
                      • United Kingdom
                      Are these caps easy to check and replace?
                      • attainteddragon
                        • Apr 2013
                        • 764
                        • australia
                        you will have to remove the bezel to see them. they are surface mount. we can guide through the testing of them.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          They are at other end of the two ribbon cables on t-con
                          • Ridahz
                            • May 2017
                            • 32
                            • United Kingdom
                            Ok guys received the replacement T-Con today. Sadly exact same issue as before which definitely means it's the board the panel connects to. I'll strip it down later on and post some pics and wait for advice with my multimeter at the ready haha.
                            • Ridahz
                              • May 2017
                              • 32
                              • United Kingdom
                              Ok guys pulled the bottom down of the panel. Is there anyway to test this board with the multimeter? If so what should I put it on and how shall I test it? Many thanks for any info.
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Need close ups of panel pcb. What do you upload pictures with?
                                • Ridahz
                                  • May 2017
                                  • 32
                                  • United Kingdom
                                  Photobucket bud on my iPhone 6S. I'll get some close ups now!
                                  • Ridahz
                                    • May 2017
                                    • 32
                                    • United Kingdom
                                    This is the right side of the board...
                                    • Ridahz
                                      • May 2017
                                      • 32
                                      • United Kingdom
                                      Left side of the board starting at Tcon
                                      I hope these pics are clear to see and make sense?
                                      • attainteddragon
                                        • Apr 2013
                                        • 764
                                        • australia
                                        now you need to check the resistance on all of the ceramic caps.
                                        i have highlighted some so you know which to check.
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • NWArkGuy
                                          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                          by NWArkGuy
                                          Well, I will be the first to admit that I screwed up...
                                          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                          I have 2 that I have found and have in my possession. ...
                                          10-12-2023, 10:13 PM
