Proscan LED 32" TV not working.
+ More Options
Posts
  • THERED117
    • May 2017
    • 25
    I’ve checked everything I can think of and have run out of ideas. It will not turn on and there is no stand by light. I have been looking for some schematic drawings with no luck. Thanks any help will be appreciated.
    My Spelling and Grammer Sucks.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Proscan LED 32" TV not working.
    We need good clear sraight on pictures of back of tv with cover off and one of each board.
    We also need the voltages from the power supply connectors.
    Format:
    Pin Label - Pin Voltage standby - Pin voltage power on
    1 - XXXXXXX - XXv - XXXv
    2 - XXXXXXX - XXXv - XXXv
    3 - XXXXXXX - XXXv - XXXv
    4 - etc.
    Please remember we dont have the tv in front of us so we go from the information you provide us ie pictures voltage readings etc.
    • THERED117
      • May 2017
      • 25
      So far all I could check was the Power board. Starting at the top and each pin grounded to its own plug gnd pin. each plug's measured voltage is separated with a semi-colon.
      25.65, 25.65, 25.65, and 25.65 VDC : 25.67, 25.7 : 13.62, 13.62, 5.04, 5.04, 5.04, 5.04, 0, and 0 VDC
      • THERED117
        • May 2017
        • 25
        I played with paint to see if this would help.
        • vinceroger69
          • Mar 2012
          • 6714
          theres two pins marked plus 5v so your getting no voltage to them as it looks like it uses the same pcb trace as the working two plus 5v pins or are they not used on the top side of the board
          can you upload a picture showing the whole back of the tv and how all the boards are connected
          • THERED117
            • May 2017
            • 25
            I separated the wires (i.e. the 5VDC).My finger is on one and my tweaker is pointed at the other end. The color bars are medium blue line and wire with no bands.
            • THERED117
              • May 2017
              • 25
              Does anyone have an Electrical schematic?
                To make it easier for us to figure what Voltage and Control signals are present, please look at the bottom side of the board and list the pin names of each connector and follow by the the DCV readings for each pin after the power switch is activated.
                http://www.shopjimmy.com/catalogsear...t/?q=PLED3216a
                http://www.shopjimmy.com/proscan-ay0...upply-unit.htm
                Pictures provided by shopjimmy.
                • THERED117
                  • May 2017
                  • 25
                  I thought I did. the only pins I didn't get VDC on was the bottom pins ie the 2 5vcd pins. Zoom in. Maybe?
                  • THERED117
                    • May 2017
                    • 25
                    I (DO) have 5 VDC on the pins mentioned above.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      thats good it looks like the psu is ok too me do you get any sound on the tv? maybe try a dvd player etc through a scart socket roughly at the centre of the tv theres two metal covers covering two boards tcon and led driver board naybe can you remove the covers and take pictures of these two boards
                        It looks like the power supply board does not have the connector installed where the ON/OFF, ADJ pins are located for controlling the backlights circuits.
                        You do have PS-ON command signals so the main board is not completely dead that is why you are getting the switched 5V, 12V, and 24V.
                        The small board in the middle is the LED driver board, I can see two wire going to the main board which I believe those two wire contain the Backlights ON/OFF control signal and the Dimming control signal.
                        So check to see if the PS-ON pin does change state or not when you turn the TV ON and OFF.
                        Then probe those two wires on the LED driver board to see what DCV you have when turning the TV ON and OFF.
                        • THERED117
                          • May 2017
                          • 25
                          PS-ON does not change. It stays high at 5VDC.
                          Ill get you the other info as soon as I can.
                          • THERED117
                            • May 2017
                            • 25
                            Here is the other pics. Let me know if your guys need anything else.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              on your second picture theres a fuse marked f1 if you dont want too put all the tv boards back in place and measure the voltage to each side of the fuse you could measure the ohms reading straight across the fuse just to check its not open
                              • THERED117
                                • May 2017
                                • 25
                                I was thinking that my stand by was in the center of my power button. I was mistaken. I found this a little while ago.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  yes thats the standby led board and remote sensor etc so the standby button led does work it looks like red in standy blue when on
                                  • THERED117
                                    • May 2017
                                    • 25
                                    I believe its green when on. so.... Power supply looks good. what else do I need to check. I Work 11pm to 7am. CDT. Ill get back with you guys after my shift starts.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      sorry it is green i zoomed in on the pcb in your picture and now have seen the print g and r i would check you get voltage too both sides of fuse marked f1 im not sure why ps on voltage dosnt change so maybe a mainboard fault? im sure budm will advise us
                                        At this point you have main board problem, that PS-ON should never stay in one level, it should change state when power switch is toggled.
                                        I see 3-pin Voltage regulator ICs on the main that you should check the Voltages, see the link on how to test and how to report the readings properly.
                                        • MMH3
                                          Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                          by MMH3
                                          i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                          Never ever i experienced problems with that.
                                          Now i have one 5050sff machine, where this jumper isnt working at all.
                                          I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                          The history of the machine is that i used it in my office...
                                          03-23-2025, 09:28 PM
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                        • obelix24
                                          Macbook Air 2020 (a2179) - touch id not working
                                          by obelix24
                                          Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                          I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                          02-09-2025, 12:57 PM
                                        • hopkok
                                          Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                          by hopkok
                                          Hi masters, I need your help.
                                          I am working on Lenovo Legion 16ITHg6
                                          Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                          INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                          My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                          AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                          Power LED is not working as well, power button working well.
                                          UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                          Motherboard...
                                          05-04-2025, 09:35 AM
                                        • bociub
                                          laptop freezes, usb 2.0 not working, usb 3.0 working
                                          by bociub
                                          Hi there,
                                          It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                                          Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                                          08-25-2024, 03:44 PM
