Seiki SE39HY03UK won't go past Seiki start up screen?
  • Loz2212
    • Jan 2016
    • 61
    • United Kingdom
    Hi guys,
    Just been given this TV for free from a neighbour. They told me it would sometimes load up and sometimes wouldn't. It's just stuck on the Seiki screen.
    I took it home, plugged it in and it worked fine all day yesterday.
    Come to it this morning and it's back to how it was with them. The seiki logo just stays on the screen and after a while it restarts and does the same again.
    Really appreciate any help from you guys.
    Thanks.
  • Loz2212
    • Jan 2016
    • 61
    • United Kingdom
    Re: Seiki SE39HY03UK won't go past Seiki start up screen?
    This is a picture of the back. Not used to these new tv's. Seems like the psu and main board are combined??
    • dskall
      • Oct 2016
      • 2905
      • usa
      Looks like there is an eeprom for this board
      • Loz2212
        • Jan 2016
        • 61
        • United Kingdom
        It's strange that it is only partially corrupted.. I've had it working twice (last night and this morning until I turned it off then it wouldn't work again). It's just stuck in this boot loop. Can't get a board or eeprom anywhere.. Not really sure what to do next
        Loz
        • dskall
          • Oct 2016
          • 2905
          • usa
          Not good at troubleshooting integrated boards could be another problem. Did find eeprom: http://www.ebay.com/sch/i.html?_from...1.p83&_sacat=0
          • vinceroger69
            • Mar 2012
            • 6714
            try cooling or heating the eeprom ic that may prove its at fault then
            • Loz2212
              • Jan 2016
              • 61
              • United Kingdom
              It's got the textbook issues with the bootloop, but I'm no expert. That eeprom is for the 32inch model for the same board.. (unless that doesn't matter). I spoke to a TV guy earlier who sells eeprom chips on ebay.. He said the board and screen number both have to match.. Can't vouch for that so bit apprehensive to order. Thanks for the reply
              • Loz2212
                • Jan 2016
                • 61
                • United Kingdom
                Will give that a go Vince. Thanks... Now just to find out where the Mrs hairdryer is..
                • vinceroger69
                  • Mar 2012
                  • 6714
                  cooling is usually the better option maplin sell electronics freeze spary not cheap but is good or poundland air duster works (hold can upside down) dosnt get as cold as proper spray but does the job usually regarding heating the eeprom some people have luck and some dont but hey worth a try.
                  • layad
                    • Nov 2011
                    • 244
                    Any solution for this problem?? I have seike TV 50 inch does the same thing sometimes it takes ages to come on, bootloop for ages then it comes on
                      • 12272
                      • U.S.
                      If it takes quite a while to come on then works, it may be a weak/bad capacitor, usually located on powerboard.
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
