LED Backlight current mod.
  • dskall
    • Oct 2016
    • 2905
    • usa
    I just repaired backlights on Vizio E500d-A0. I am now in the process of trying to modify led current. It is running about 410ma. I am trying to reduce it to between 320~350ma. This is trial and error for me as I have no math or engineering background. I would like to make mods to all Tv's when I repair the backlights. The led driver for this board is BD9285F IC300 and IC400. It gives formula to adjust current. Changing the isense resistors. The formula works out to a few ohms. I traced (I think) my isence resistors to R411 and R311 which are 1k resistors. So now am confused. I have changed some values with mixed results do to inconsistent readings with inductive ammeter. Any guidance would be appreciated.
    Powerboard: FSP155-2PSZ01 https://www.shopjimmy.com/vizio-0500...t-inverter.htm
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LED Backlight current mod.
    In the Service Mode on most TVs there is a selection to adjust the backlight. Trying to do it as you are doing will work to an extent but you would be wasting Watts and the Joules would result in heat. I wouldn't take that route though as for the most of it you would be guessing at approximate values and outcomes. This would be a tedious exercise also. Good Luck..
      The I sense resistor is the one that is connected between the PWM control MOSFET and GND for the LED return current path, it should be very low Ohms usually <1 Ohm.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Ok thanks budm. I found 4 smd 1ohm's next to mosfet. I removed one which increased current. So will try adding one.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Haven't been able to enter service mode. Tried this
          Turn The TV off.
          Press and hold the {CH +} & {CH -} buttons on the TV.
          Then press and release the {POWER} button on the TV.
          Release the {CH +} & {CH -} buttons.
          Now press the {MENU} button on the remote.
          You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
          Press and hold the {MENU} button for few seconds.
          The Service Menu will be displayed
          No luck
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            OK. So we'll be adding this resistor in parallel, so the equivalent resistance is lower.
              You need to INCREASE the resistance so it will take less current flow through the LEDs and the circuit to develop the same Vdrops on the current sensing resistor as when the resistance is lower.
              • dskall
                • Oct 2016
                • 2905
                • usa
                I tried the changing current sense resistor. It was four 1ohm .25ohm. Removed one so it was .33ohm but didn't work. Looked at datasheet again it said to change isense resistor which is connected to isence. They were four 12ohm. Changed to four 20ohm and now max. current is around 300ma and seems to be plenty bright as opposed to the 420ma they were being driven at. I feel better that the 350ma led's are not being overdriven since I want to sell this tv and not worry that it will get set to max.
                  skip.
                    Are you sure they (Four 1 ohms) are not for the Boost converter MOSFET??
                    You have current sensing resistor for the Boost converter and current sensing resistor (this is the one that you want to change) for the PWM Controlled MOSFET for the LED current.
                    So when change to four 20 Ohms in parallel the Vdrops at 300mA will be = 5 ohms x 0.3 = 1.5V so the cirucit to main tain the same Vdrops on the original resistors (3 Ohms total resistance, it will need 500mA of current to produce the same 1.5 Vdrops.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      As per page 13 of datasheet the resistor at bottom of gate and cs terminal are four 1ohm resistors. I pulled one to increase resistance but didn't work. According to page 17 to set current you have to change isence resistor which are four 12ohm resistors in parallel . I replaced with four 20ohm and it dropped max. current
                        CS pin of the IC is for current sensing of the boost converter circuit not for the current control of the LED. CS goes to the Source pin of the MOSFET, the current sensing resistor for that MOSFET will not have effect on the LED current
                        Then you have Isense pin which is connected to the current sensing resistor (that is the one I have indicated that you need to increase the value to reduce the LED current) which is connected to the Source pin of the MOSFET that is used for maintaining the constant current through the LEDS.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          I understand the circuit a little better now.
                          • augiedoggy
                            • Aug 2016
                            • 62
                            • united states
                            I believe the issue is also the fact that when you first turn the set on the leds are at full brightness being overdriven for a few moments until the software adjusts it down. I saw a while back on youtube, another person adding some sort of resistors in the same fashion and he talked about this.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              Well again just learning but if you set your sense resistor full brightness will be whatever max. is set on controller which now is around 300ma. Max for these leds is 350ma as opposed to 400ma which in my opinion is deliberate to limit life of tv.
                              • unimatrix93
                                Identifying backlight resistors, power supply is a BN44-00852
                                by unimatrix93
                                Dear forum, I would like to ask some help identifying the backlight circuits resistors to limit the ampere to the backlight leds.
                                The power supply is a BN44-00852 and I want to decrease the backlight to increase the lifetime of the LEDs.
                                The TV is pretty much always on, used for CCTV cameras.
                                I suspecting R9838 -> R9841 resistors but I'm not sure. Thanks in advance!
                                04-29-2024, 04:49 AM
                              • unimatrix93
                                Which resistor should I remove/replace to decrease current to backlight leds?
                                by unimatrix93
                                Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
                                However I need some help identifying the resistor I need to replace to achieve this.
                                Thank you!
                                11-29-2024, 05:05 AM
                              • DanPoka
                                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                by DanPoka
                                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                02-15-2025, 05:05 AM
                                Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                by sam_sam_sam
                                I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                02-04-2025, 08:08 PM
                              • cheebster
                                iPad Pro 12.9 5th Gen Backlight Issue
                                by cheebster
                                Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                Anyone...
                                05-20-2025, 09:17 AM
