Count of Leds burnt in backlight POLL !?
  • web5
    • Apr 2017
    • 21
    • US
    How many Leds you discovered Burnt when you openned TV ?
    I have TV with backlight stopped working, and
    before i start to tear down it, i would like to
    narrow down to the number of possible burnt Leds.
    ( Tested power supply - power does not go to led strips)
    12
    1-2
    0%
    3
    3-5
    0%
    6
    6-10
    0%
    1
    11-All
    0%
    2
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Count of Leds burnt in backlight POLL !?
    I think this is rather useless as every tv and tv's same model differs
    It wont help at all , what would be better is the working voltage of the strings for various models would be helpful , better still the running voltage using LED tester would help narrow the fault to LED panel or power supply driver
    • web5
      • Apr 2017
      • 21
      • US
      Before i tear down tv for repair i would like to order some quantity of led
      replacements, and how many is more likely be enough.
      Tested yesterday, my 50" TV led supply puts 124.5 VDC.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ive had 18 out before in Lg 50"
        • web5
          • Apr 2017
          • 21
          • US
          Wow, didn't expected that number !
          On Tube i see from 2 to 4 leds blown.
          • freakaftr8
            • Oct 2012
            • 3743
            Good god man that's a tv that doesn't want to be resurrected fro. The dead!!
            • dskall
              • Oct 2016
              • 2905
              • usa
              15 should be enough
              • web5
                • Apr 2017
                • 21
                • US
                Originally posted by dskall
                15 should be enough
                1/5 of all leds in my tv, i think you are right.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Tbh I dont know what happened as 6 were open and 12 shorted LG LN series always seem to fail badly
                    12 on SAMSUNG, 9 open, 3 shorted.
                    I would stock 50 of them (I order 100 at a time. How much is the price difference between 15 and 25 or 50?
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      The only LED TV i've worked on -- Vizio, 50" IIRC. struck by lightning. All LEDs open.
                      Follow the white rabbit.
                      • whiz62
                        whiz62
                        • Dec 2013
                        • 242
                        • usa
                        Vizio 47", 4 LEDS open out of 54.
                        • augiedoggy
                          • Aug 2016
                          • 62
                          • united states
                          I have found that about 30-40% of the tvs I just replace the burnt leds instead of the strips end up having another led failure shortly after. I think one of the reasons being is if an led shorts closed the voltage increases to all the other leds and stresses them. some tvs only have one shorted open led and thats all it sometimes takes to make the whole tv go dark and on other sets Ive had to replace as much as 5 bad leds. By far the most unreliable LEDS are the ones LG uses in their economy sets as well as many of the vizios they make. (I have an LG 47" set sitting here now I have to repair AGAIN after replacing the bad leds and having another fail 2 weeks later.)
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            I am modifying the current supplies to the leds on vizio and LG. They run there current at 400ma+ on leds only rated for about 350ma. I want to set them below 350ma. Funny thing is I reduced max. current over 100ma with little noticeable change in brightness. Makes you wonder if it's calculated to kill the tv after warrantee the same as the failing bad caps did.
                            • augiedoggy
                              • Aug 2016
                              • 62
                              • united states
                              Curious, Will you share how are you modifying them?
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Just learning this stuff. Need to modify led controller current sense resistors.
                                https://www.badcaps.net/forum/showthread.php?t=61722
                                • pni
                                  Backlight panel diffuser melt by backlight leds broken
                                  by pni
                                  Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                                  10-12-2025, 12:08 AM
                                • triplefour
                                  by triplefour
                                  09-13-2023, 10:43 PM
                                • hollox123
                                  ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                  by hollox123
                                  Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                  1. Laptop keyboard doesn't work
                                  2. The backlight on the laptop keyboard doesn't work
                                  3. The x2 side LEDs (red) on the laptop don't work
                                  The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                  I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                  But I am strongly aiming that it is somehow a BIOS-related problem,...
                                  05-11-2025, 08:05 AM
                                • signal.quest
                                  Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                  by signal.quest
                                  I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                  03-17-2024, 10:14 AM
                                • willis6732
                                  Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
                                  by willis6732
                                  This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
                                  Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
                                  The Driver board looked pretty toasty in the LED Driver Area.
                                  So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
                                  12-17-2024, 04:09 PM
