Vizio E470i-A0 - FL test ok, half bl working
  • anthonystv
    • Jun 2014
    • 73
    Re: Vizio E470i-A0 - FL test ok, half bl working
    BTW I can light both Strings with Shop Jimmy tester at the plug to the board (Disconected) 76.1 vdc and 76.3 vdc
      Originally posted by anthonystv
      105v LED 1
      Retrun .7VDC
      103 LED 2
      Reurn Sometimes .7 vdc sometimes 6 v not sure why not sensative to touch also has no bearing on wether the channel shuts down or not
      I have on occasion got it to stay up if the tv gets by the first 10 secs of start up iy will stay on for hours but turn the tv off and back on and drops again will drop with in 10 secs if its going to drop I have swapped the leds from ch 1 to ch 2 but ch2 always shuts down no matter what it hooked to it and eve if NO LEDS hooked to it it will shutdown while ch1 will stay up even with no leds hooked to it
      Are you testing right at the pin of the LED connector?
      LED 1 (CN301 pin 1) is the Cathode return line of LED string #1
      Vout 1 (CN301 pin 3) is the boosted Voltage of the LED power supply #1 which is fed to the Anode of the LED string.
      LED 2 (CN301 pin 5) is the Cathode return line of LED string #2
      Vout 2 (CN301 pin 7) is the boosted Voltage of the LED power supply #1 which is fed to the Anode of the LED string.
      So what you are reporting does not make sense to me. All the measurement are ref to chassis GND.
      And BTW, you keep referring to CH1 and CH2, where are the test points for CH1 & 2?
      is this the EXACT board you have? See post #5.
      https://www.badcaps.net/forum/attach...4&d=1491364065
      What is the P/N of the LED driver IC 9101? We need to look up the spec sheet of the IC.
      • anthonystv
        • Jun 2014
        • 73
        YES at the board
        Yes
        YES
        And BTW, you keep referring to CH1 and CH2, where are the test points for CH1 & 2? Channel 1 is the working channel on the outside area of the board D9202 D9202A
        CH 2 is D9102 D9102A
        YES
        THe only thing IM sure about is the problem IS on this board
        • anthonystv
          • Jun 2014
          • 73
          SEM5028 IC I( have this on the way from Shopjimmy in some sort of repair kit I have 2 of these boards acting exactly the same ... 1 from ShopJimmy that I will return when I figure this mess out ...
          • anthonystv
            • Jun 2014
            • 73
            Regarding this IC could not find a spec sheet for it only the 5027 which is a single channel driver ... 5028 is Dual Channel
              1) If you look at the pin out of the 5027, you will see OVP (Over Voltage protection) which will shutdown the Boost converter when the Output has no load connected sothe output will drop down from over 100V to 60V (Input Voltage the boost converter). So the 5028 may have Two OVP circuit for each LED driver.
              2) How many LED's are there in the set? Base on your reading on your LED tester, 76.1 vdc and 76.3 vdc, since the drive the current is about 30mA fronm the tester, so the Vf of each LED at 30mA will be about 2.7 ~2.9V, so that will be about 28 LED's. When the LEDs are driven at full current, the Vf will be about 3V, so the power supply has to put out about 28 x 3 =84V + 20V for the PWM controlled MOSFET and the current sensing resistors. You indicated that you do have over 100V feeding the LED strings but you had only about 0.7V on the return pins which does not make sense to me unless you still have open circuit.
              http://4.bp.blogspot.com/-80jXWtC6Hj...D%2BDRIVER.jpg
              • anthonystv
                • Jun 2014
                • 73
                not open thats the channel thats lit .7 in ref to ground
                and this supply does stay up with no leds I tend to look at this like a stereo amplifier and I use the working channel to troubleshoot the bad one...
                The pulsing is the doubler shutting down without load and resarting over and over
                the BAD channel does this too except only like 3 times then it quits .. the good channel will pulse forever without a load... it never stops trying A spec sheet on that IC will help becuase without it I dont know what Im looking at on this IC
                • anthonystv
                  • Jun 2014
                  • 73
                  there are 6 strings of 9 leds
                  3 strings on each supply circuit
                  • anthonystv
                    • Jun 2014
                    • 73
                    I would tend to think the leds are turned on hard to ground with the .7 reading ...
                    dont they vary the return to achieve lowering the drive to the leds by switching transistors to gnd ? .. if i have resistance to gnd on that return side wont you see a higher voltage here ? and a dimmer led? I switched some parts from 1 channel to the other as I will do when im working on a stereo amp becuase I move the problem from one ch to the other than I know I found the part ... I swapped diodes caps and current resistors ... nothing changed
                      If you truly has on 0.7V (V drops on the MOSFET and the current sensing resistor) on the Cathode return, the LED would have been flashed real bright then the circuit will shutdown due to over current condition, the 0.7V reading is more likely to be open circuit in the LED string some where. Typical Vdrops on the PWM Control MOSFET is 10 ~ 20V typical.
                      One thing to watch out too is that the tester only puts out 30mA while the drive current of the LED power supply is about 200 ~ 400mA range, so bad LED will breakdown at higher current so the tester cannot simulate that condition.
                      Something is not making any sense to me right now based on your reported readings.
                      So the bottom line is that one of the string does not even flash on once, correct?
                      • anthonystv
                        • Jun 2014
                        • 73
                        like I said I have the screen off all the leds light just fine one set of 3 wont stay lit ... when you first turn on the tv they all light at full strength then they all dim down as it seeks signal then they come back up not quite as bright as initial turn on this is all normal the tv plays for about 10 secs and one set of 3 strings (powered by ch 2 ) of leds will shut down leaving 3 strings of leds lit up (Channel 1) it doesnt flash they light up solid and I switched the leds for the 3 that quit and made no difference no matter what set of leds If they are powered by Ch 2 they shut down
                        • anthonystv
                          • Jun 2014
                          • 73
                          I Have also measured the volatges as it goes through the strings as its some thing like this 105V enters first string 74 V leaves enters second string 38 volts feeds the 3 string as it leaves the 2cd string and by the time you get through the 3rd string you have .7 out the other end all 3 strings lit solid
                          STEADY VOLTS
                          So 105v >>>>>>>27 LEDS .7 VDC ,,,,,,,back to power board
                          thats from the set that works with no issues
                          the other set is about the same but the starting voltage is lower 103v then as the set plays you can watch that 103 drop 102 still lit 101 still lit 100 still lit.....99v OUT then falls fast to 66 V ...
                            'STEADY VOLTS
                            thats from the set that works with no issues'
                            27 LEDs x 3Vf = 81V, but you have 105V feeding the Anode and 0.7V on the Cathode return, so V drops on the string is 105V - 0.7V = 104.3V but 27 LED's with total Vf of 81V so where does the extra Voltage drops of 104.3V - 81V = 23.30V go to.
                            Not only that we are taking about the total Vdrops on the PWM Controlled MOSFET and current sensing resistor (Q9105 + R9110 (0.15 Ohms) for string #1, Q9215 +R9210 (0.15 Ohms)) for string #2) of only 0.70V.
                            As you can see it does not add up, and you get the same result with replacement power supply.
                            But you indicated that you have working TV for comparison so if you transfer the board from non-working to the working TV one at a time then you can see if the boards from the bad set are good or not.
                              BTW, looking at the color of R9110, 9210 again; they look to be 0.50 Ohms 1%(Green/Black/Silver/ Brown).
                              • anthonystv
                                • Jun 2014
                                • 73
                                Ts gets even starnger
                                CH 2 is affected b the incoming sgnal CH 1 is NOT!
                                The crazy readings I was getting on the return of CH2 is due to the incoming signal now I know newer tvs varry that with signal to different leds never saw a simple 2 channel supply do it and why not both supplys being affected equally?
                                this would mean the backlights in edge lower and top vary with signal but the leds in the center dont?
                                Im going to see if the menu setting is affecting both channels
                                • anthonystv
                                  • Jun 2014
                                  • 73
                                  all kinds of vdeo uploading .. SInce the leds were staying on I installed the screen this morning
                                  • anthonystv
                                    • Jun 2014
                                    • 73
                                    https://www.youtube.com/watch?v=fRnvOHwYq5w
                                    Aparently I am Crazy! ARGH!!!
                                    • anthonystv
                                      • Jun 2014
                                      • 73
                                      https://www.youtube.com/watch?v=t7solMfM0HM
                                      • anthonystv
                                        • Jun 2014
                                        • 73
                                        https://www.youtube.com/watch?v=ugTW0UlTG1M
                                        • anthonystv
                                          • Jun 2014
                                          • 73
                                          Are you going as crazy as I am ?
                                          https://www.youtube.com/watch?v=LP71svARSuI
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • chth96
                                            How Can I test PWM DM0365R?
                                            by chth96
                                            Hello
                                            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                            06-18-2025, 04:14 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • gavric
                                            Vizio M70-C3 Half picture is bad, main board on its last leg?
                                            by gavric
                                            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                            When tv powers on vizio V logo shows nice on whole screen. picture 1
                                            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                            When i click video to start playing picture goes black(like when you change...
                                            09-02-2021, 08:55 PM
