Vizio E420-A0 Horizontal Lines
  • De3rcr
    • Apr 2010
    • 94
    I turned on my TV the other day and the screen had these lines that were shifting up and down. I re-seated the cables from the main board to the panel and there was no change. Should I buy a new main board or is it the panel?
  • CapLeaker
    Leaking Member
    • 8150
    Re: Vizio E420-A0 Horizontal Lines
    remove one side of the ribbon cable from the tcon to the panel, while leaving the other side plugged in. Check the picture then do the same thing vice versa.
    • De3rcr
      • Apr 2010
      • 94
      When I disconnect the top cable from the board the screen is half black and half white and I can see some lines in the black half but not the white half. With the bottom cable disconnected same half black half white but I see no lines in the black half
      • dskall
        • Oct 2016
        • 2905
        • usa
        Since you have no t-con I would say mainboard
        • CapLeaker
          Leaking Member
          • 8150
          try this trick:
          https://www.youtube.com/watch?v=j7vl7-vZEL8
          • dskall
            • Oct 2016
            • 2905
            • usa
            Can someone explain why this works.
            • De3rcr
              • Apr 2010
              • 94
              Don't know why it worked for him. But tried it and no help, guess it's time to order one unless there are any other suggestions?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Panel fault IMO.
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  You will have to experiment with how many tracks you block with the tape and which tracks. It takes time but it often does work.
                  Proud owner of dozens of broken TV's and many,many,many boards.
                  Our website and passion:http://hollenhundshepherds.com/
                  • CapLeaker
                    Leaking Member
                    • 8150
                    It's a panel fault. This trick does work but not always... unfortunately...
                    as martino already mentioned you have to experiment on which and how many tracks to cover. I thought it was worth a shot...
                    • De3rcr
                      • Apr 2010
                      • 94
                      Got around to playing with tape widths and so far I found the right tracks to cover and the picture looks fine. It worked, don't know why, but go figure. Will see how long it lasts
                      • CapLeaker
                        Leaking Member
                        • 8150
                        Good to hear!
                        • connedbycraigslist
                          • Apr 2020
                          Hi there, any chance you could share which tracks you covered? I'm afraid I just bought the same model and am having this issue. Thank you.
                            • 12187
                            • U.S.
                            You might have a long wait, that post 3 years ago was his last, you just need to experiment with how many you cover, some only need to cover a few on one end.
                              • Apr 2020
                              No worries, thanks for the response. Was just checking in case I couldn't get it. Hopefully no one else needs the information, but if they do... left one, towards the right side with a very small piece of post it worked for me. Covered maybe 4-7 pins. Thanks so much for keeping this place up and going!
                                • 12187
                                • U.S.
                                Nice work, thanks for feedback, I'm sure it will help someone else.
                                • howardc64
                                  by howardc64
                                  07-24-2025, 05:17 PM
                                • Gjackson
                                  LCD Tv starts to display black horizontal lines after half an hour of use
                                  by Gjackson
                                  Hi, I have a sort of old Grundig LCD Led TV that starts to display black horizontal lines after some use. After it's been turned off for a while and cold it does not display any artifacts however after some use it starts to display some faint horizontal lines at the top of the screen and a bunch in the middle of the screen. The longer the tv is on the worse they get until they become very clearly visible. I suspect that heat has something to do with this as when the lines start to appear i notice that the tv's metal case has gotten warm. Could the T-CON start to malfunction when it starts to get...
                                  01-31-2022, 02:25 PM
                                • dvu0627
                                  Sony XBR65X900H TV with Horizontal Lines right half of screen
                                  by dvu0627
                                  I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
                                  I replaced the T-Con board but the lines are still there.
                                  I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
                                  Thank you for the help....
                                  02-05-2023, 03:39 PM
                                • rapid911
                                  Vizio M58Q7 colored horizontal lines
                                  by rapid911
                                  Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
                                  05-28-2023, 04:17 PM
                                • jason123
                                  Vizio V555-H1 - Horizontal lines then double image bursts
                                  by jason123
                                  Hi there,
                                  I think it might be a bad panel but I thought I'd ask before I chuck it..
                                  thin colored horizontal lines bottom and thin section on top. As it runs warmer, you can see some ghosting or double image. Right hand side of the screen darker then brighter (backlight is always on, so it's the actual LCD that gets darker and brighter)
                                  Replaced the Main board, because I had one handy, no change.
                                  Is it worth replacing TCON? disconnecting ribbon on one side of the panel, the lines appear still on the other side (unplugged side.)
                                  12-15-2022, 03:53 PM
