LG TV stopped working.
  • TvNoob
    • Mar 2017
    • 9
    • England
    Recently whilst watching my tv it stopped working. I unplugged it for about 10 mins and tried the TV again. The TV displayed the home screen for a split second and then goes black and then the standby light flashes 3 times and then stays a solid red.
    It's a 48 inch LG LCD smart tv with a dual core processor. It's only 2 years old.I checked the capacitors for any swelling or bursts and they all seem fine.
    No scorch marks anywhere or lose wires that i am aware of.
  • electronicsurplus
    • 210
    Re: LG TV stopped working.
    What is the model?
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
    • TvNoob
      • Mar 2017
      • 9
      • England
      The model number is- 47LN578V
      • TvNoob
        • Mar 2017
        • 9
        • England
        I just took it apart again and to look at the soldering and put it back together. The tv actually works but the screen is so black it looks like it is not on but i can see the menu and operate the tv.
        Back light issues?
        • TvNoob
          • Mar 2017
          • 9
          • England
          I will have to order the LED back lights for it....never done it before but i reckon i can do it.
          • TvNoob
            • Mar 2017
            • 9
            • England
            Or could be a faulty power board. I'm not skilled with this sort of stuff....i will purchase a testing kit.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Have a read through the following Thread which you should find helpful. From what you say in post#4 it would appear to be a backlight problem.
              https://www.badcaps.net/forum/showthread.php?t=45990
              • TvNoob
                • Mar 2017
                • 9
                • England
                Thank you for the response, the thread helped a lot.
                I am just debating if it's worth fixing as many people are finding it hard to find replacements. I did look on ebay and they seem to have some strips that seem to match the same as the sticker identified on the back panel of my tv.
                I'm just debating now if i should try and fix it myself, try and ring up a few places see how much it will cost for a repair or just get a new one.
                I have basic knowledge when it comes to TV's.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Well I would buy a strip or two and use them to do a stacking repair. Very cheap repair if you don't break panel. You can search youtube about doing it.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    This is why bcn is here dont be a baby and get on with it if not you've just wasted peoples time here you can do it have faith in yourself ! Watch my vids on the stacking method or order the Leds and be very careful with the Lcd screen when removing it making sure to tape the tab boards to the panel then carefully lifting it.
                    Also please dont tell me your the person who bid £140 for this model on ebay lol or you could sell it to me
                    • TvNoob
                      • Mar 2017
                      • 9
                      • England
                      You're right, i will give it a go. Nothing to lose really.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Good man keep us updated, just remember go slow and be careful with the screen they break easy
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          If your careful you will do just fine. I did about 30 of these now,they are not too hard.
                          One tip: putting the screen back in it's place,make sure the metal frame is laying down flat,supported with something(block it up like a car). The metal housing flexes a lot and makes it to not sit perfectly flush/straight?If then you put the screen in,it will most likely crack(don't ask how I know).Stacking led's like reeceyBurger or even replacing the led's themselves is really not that hard.Do it step by step and ANY question or doubt you have,just stop and post it in this post,you will be helped
                          Proud owner of dozens of broken TV's and many,many,many boards.
                          Our website and passion:http://hollenhundshepherds.com/
                          • TvNoob
                            • Mar 2017
                            • 9
                            • England
                            Hello again. I am about to order parts that i have seen on ebay but doesn't quite match the model of the tv.
                            I was wondering what do i need to match, is the model of the tv important of the sticker located on the back plate for the LED lights.
                            http://www.ebay.co.uk/itm/NEW-6916L-...EAAOSwwpdW6uv1
                            The sticker labelled read LCH470DUE (SF) (R1) the only thing that seemed like it didn't match was the model number.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              There are two strips to make a full length. One with 5 leds which connect to one strip with 4 led so 9 led total per length.
                              You could buy 1 strip and use the leds from that strip to replace the faulty ones you find or just buy replacement strips.
                              https://tinyurl.com/jmndxax
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                maybe flocko has them in stock? if your doing the stacking method maybe cheaper than buying a new strip to cut up i will see if i can find his ebay shop link.
                                • zomi
                                  • Nov 2011
                                  • 509
                                  Saw that lg 47 go for £140 too couldnt believe it
                                  Don't kno whats wrong with people bidding prices so high lol
                                  esp when you run the risk of blackened diffusers etc...
                                  mad days recently
                                  • sordids999
                                    • May 2013
                                    • 2160
                                    EAX64905501 power supply
                                    TV LG 47LN575V totally dead
                                    basically have voltage across the primary side but no voltage readings on secondary side,also legend voltages have no reading
                                    done so far:
                                    checked all diodes for shorts all ok
                                    voltage reading across main cap 330 volts
                                    no fuses blown
                                    any ideas
                                    thanks
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      i cant find a schematic for your tv but this link is possibly the one for the psu so maybe of use my guess is the pfc circuit has a issue a 330 does seem a little low too me
                                      https://www.scribd.com/document/3318...2-power-supply
                                        • 12276
                                        • U.S.
                                        Could very well be the backlights, I'd test it out before I had to rip into it tho.
