Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
  • Roman555
    • Jul 2023
    • 20
    • Ukraine
    Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
    • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
    • USB stick with MS-DOS can be loaded via F8 boot menu;
    • Other OSes won't load - hangs or goes reboot;
    • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
    • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
    What I've already done and it hasn't helped:
    • Cleared CMOS many times;
    • Flashed different versions of BIOS in a CH341 programmer;
    • Updated BIOS to new version using BIOS embedded utility EZ Flash. What is interesting that after this ME region wasn't updated;
    • Updated ME region to newer versions using ME update utility for DOS fwupdlcl.exe;
    • Set another fully working and tested Ivy Bridge CPU.
    Hello everyone!
    It was a fully working system MB Asus P8H77-M LE and 2-core CPU Pentium G2030 Ivy Bridge. Recently I was trying to install stable FreeBSD-13.2 there but I think it's not the point. I didn't manage it because after some tries (every installation were successful but OS didn't boot - error about missing operation system) the system got unstable. Finally I tried to run already installed Linux or Windows but they didn't boot. USB sticks didn't boot too.
    The system hangs with blank screen at debug (post) code A3 that means the system ready to boot OS. But it never happens. Also the system has very long reaction after pressing Alt-Ctrl-Del and Reset button. Reset always goes with full shutdown. After some fiddlings I realized that I could start loading OS via F8 Boot Menu or call OS loading in UEFI BIOS menu. But OS loading hangs or suddenly goes to reboot. Linux has error just after loading start : "smpboot: do_boot_cpu failed(-1) to wakeup CPU#1". Windows 10 suddenly reboots.
    It looks like problem with ME of PCH but I haven't managed to solve it flashing/updating BIOS and ME.
    With Sandy Bridge CPU (2nd-gen 32nm Celeron G540 and Pentium G840 2-core CPU-s) everything works well. Just CPU was changed (no other changes).
    I'm stuck now. Any constructive ideas are appreciated.
  • Roman555
    • Jul 2023
    • 20
    • Ukraine
    New observation:
    With a discrete PCIe graphics card as main graphics the mainboard + Ivy Bridge CPU are getting boot.
    I measured VCCGFX in different modes with a discrete gfxs card installed:
    1. Main gfxs is discrete independently of CPU model - VCCGFX = 0.02v (always no voltage)
    2. Sandy Bridge CPU, main gfxs - iGPU - VCCGFX = 0.47-0.5v (bios menu, desktop) / 1.22v (3D apps)
    3. Ivy Bridge CPU, main gfxs - iGPU - VCCGFX = 0.125v (bios menu) / ? (OS won't boot)
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      Maybe your G2030 iGPU is dead. Did you try a different Ivy Bridge CPU?
      • Roman555
        • Jul 2023
        • 20
        • Ukraine
        Yes, I did. G1610 is working for sure but the board behaves the same way.
        Finally I've found an option in BIOS settings that can mitigate the problem a little bit. It's a GPU voltage adjustment. It allows to set VCCGFX voltage manually. If I set it into 0.8v or 0.9v the mainboard loads OS normally (no freezing).
        I guess a PWM controller of CPU VRM is faulty. But haven't replaced it yet
        • прямо
          • Sep 2022
          • 261
          • Indonesia
          Congrats for finally confirmed your suspicion that low VCCGFX is the culprit.
          • privato89
            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
            by privato89
            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
            Let's begin:
            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
            03-26-2024, 06:37 AM
          • Luke Anders
            Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
            by Luke Anders
            A few details about the laptop itself:
            Name: Lenovo Legion 5
            Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
            BIOS Version: GKCN60WW
            EC Version: GKEC65WW
            Serial Number: PF39AQ7Z
            Board Model: NM-D562 Rev 3.0
            RAM: 16GB Installed, DDR4 (brand new)
            NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
            I bought this laptop recently from eBay as a faulty device....
            10-12-2024, 05:13 AM
          • NolesFan
            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
            by NolesFan
            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
            10-24-2024, 06:36 PM
          • praveenramavath
            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
            by praveenramavath
            Hello All,
            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
            https://www.hifivision.com/threads/m...-screen.98243/
            Troubleshooting Summary: Majority Internet Radio - Flash Chip
            04-26-2025, 09:08 AM
          • torchzack
            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
            by torchzack
            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
            08-28-2023, 07:42 AM
