Share: T-Con training manual from LG
  • yoritomo
    • Sep 2012
    • 147
    • Belgium
    Hello all
    I want to share this excellent manual to better understand, troubleshoot and fix t-con boards which still be difficult to diagnose by missing informations usually
    Please read carefully especially the page 29 to understand how precious is this manual, it describes how to activate the internal self test pattern of the T-CON board to clear if T-Con and panel are in trouble or not. This test is working without a mainboard, only a 12v power supply and working (forced on) backlight are necessary.
    There is the doc in PDF format.
    http://www.lcdrepairguide.com/screen...28/LG-TCON.pdf
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Share: T-Con training manual from LG
    Thanks for sharing.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      +1
      • vinceroger69
        • Mar 2012
        • 6714
        Thanks for sharing.
        • CapLeaker
          Leaking Member
          • 8161
          Nice share! Thanks!
          • dskall
            • Oct 2016
            • 2905
            • usa
            Should go in the TV Repair Reference Library
            • CBS
              • 7
              Thanks.It's hard to find information about tcon.
                I put that info in earlier this month.
                https://www.badcaps.net/forum/showpo...&postcount=302
                • yoritomo
                  • Sep 2012
                  • 147
                  • Belgium
                  Hello
                  I am glad if it may help you , i learnt a lot of things about it too using this doc.
                  Sorry budm, i did not see you posted it already, so it will be double visibility ;-)
                  • chocoyito
                    • Sep 2016
                    • 16
                    • peru
                    Thanks bro!!
                    • anfsujee
                      • Mar 2019
                      • Srilanka
                      Thanks brother ��
                      • x_orange90_x
                        TCL 50S535 bad tcon or panel issue?
                        by x_orange90_x
                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                        03-29-2025, 11:02 PM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
                      • Hakuu
                        by Hakuu
                        Hi There,
                        More Details
                        TV Model - LG OLED77G1PUA
                        07-12-2023, 02:37 PM
                      • Daren87
                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                        by Daren87
                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                        08-13-2023, 03:25 PM
                      • alltvrepairs
                        Lg TCon test pins for screen test
                        by alltvrepairs
                        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                        Appreciate your help....
                        06-13-2025, 06:33 AM
