Vizio M470VSE LED half image
  • OldMan
    • Jun 2011
    • 47
    Don't remember where I got this TV but here is what I'm dealing with.
    TV powers on and stays on. Responsive to both remote and buttons. It has audio but video is only displayed on half of the screen (see photo). Power board output measures normal.
    I initially thought it was the TCON, replaced it but no luck. Exactly the same thinng...LED driver illuminates entire screen, video only on half.
    What are the chances the main board is to blame? What about the ribbon or LVDS cables? I haven't done much with LEDs to know what to suspect and try first. I recall fixing an LG which had bad tab bonds by using weather stripping. Could the half screen video be a tab bond issue?
    Look forward to thoughts.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio M470VSE LED half image
    I don't think a mainboard will cause just half screen to fail. Can you switch your ribbon cables and see if problem switches to other side.
    • irad
      • Aug 2010
      • 27
      Switch the ribbon cables running from tcon to the panel. If the other half of screen starts working it is the ribbon cable. Go into menu to see more of the screen lit with an image.
      • OldMan
        • Jun 2011
        • 47
        Switched the ribbons from left and right last night only to get the same issue. Doesn't look like the ribbon. I think I'll take the surround off of the panel this weekend and see if I get anywhere by putting pressure on the TABs.
        • vinceroger69
          • Mar 2012
          • 6714
          half a image could also be a shorted smd capacitor on that side of the lcd panel pcb there been a few threads lately.
          • CapLeaker
            Leaking Member
            • 8324
            that gets my vote too.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Aye Vince agree as well.
              • vinceroger69
                • Mar 2012
                • 6714
                i was trying to find the thread to link to this one but couldnt find it.
                • OldMan
                  • Jun 2011
                  • 47
                  Glad to hear everyone in agreement on the SMD idea. Assuming I test all of them on the bad half and identify it/them, should be able to just replace it correct?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    you may notice it getting hot but yes test all on that side there very small though this may not be the fault but at least you can rule them out.
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • dicky96
                      HP Elitebook Screen blank - backlights but no image
                      by dicky96
                      Hi guys
                      I'm trying to fix this laptop screen
                      Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                      OK so I have the original screen which works but has lines across the bottom quarter of the screen
                      I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                      04-28-2021, 07:30 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • valvashon
                      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                      by valvashon
                      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                      11-24-2024, 12:08 PM
