LG 42LN575V backlight issue.
  • Darkstar_
    • Jan 2017
    • 7
    Re: LG 42LN575V backlight issue.
    Sorry,
    The figures for those P801 pins are (from top to bottom based on picture I just uploaded).
    All readings fluctuate between two values:
    214/231
    34/74
    39/105
    45/80
    Another dumb question, I didn't realise there was a second set of pins to test.
    How can I test them? I tried removed the cable connected in there, but I assume the cable must be connected for the TV to function to a level where I can test it (the power button for example).
    I could remove the board completely, but then it won't be grounded?
    Again, apologies.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      that connector goes from the psu to the main board it may be easier to measure readings there just push the red lead probe down the side of each wire in turn it will touch a metal pin and make contact ok
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Don't worry about those readings. From the readings given for the led connector it looks very much like you have an Led fault(s).
        At this point do a search for testing leds as there are plenty of helpful guides on this Forum.
        There are also plenty of Youtube video's which are useful aid to finding faulty leds.
        https://www.youtube.com/watch?v=K_VfM4grw3I
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          just be really carefull with the strip down as the lcd panel is very thin and easily cracked also keep all the sheets that are under the lcd panel in the correct order and try to keep dust/dirt finger prints to a minimum as may show when you have the tv working again.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            There are 10 leds per strip (2 x 5 leds per strip) and 5 rows in total = 50 leds
            Each led requires 3V to operate so 50 x 3 = 150V to operate them all (board says 157V)
            so the led readings at the connector should be in the order of:-
            150V
            120V
            90V
            60V
            30V
            https://tinyurl.com/z27dmxp
            • Darkstar_
              • Jan 2017
              • 7
              Thanks guys for all your help.
              While I am basing this on your initial diagnosis, I think I will write it off.
              I don't have the patience to strip it down and test the LEDs, I really don't.
              Nor do I have the money to purchase a power supply to test it and then £65+ for the strips.
              We shall save and get a new one, if this has happened once before with this LG tv, it could again and I would rather cut and run.
              I have learnt some good things doing this and I do appreciate the time you guys have taken to respond to my post.
              It may disappoint some to know I am just giving up, but I really don't have it in me.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                well a battery can test the leds and if you can solder you can buy just buy the leds and swop them easily enough so could still be a very cheap repair if you have time i dont have a tester i use a old atx power supply sometimes or just a battery pack and multimeter.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  Well you can take it apart down to backlights, power it on and they should flash and tell you which are bad. Buy one strip to use to repair the bad led's. Very low cost repair.
                  If you buy new tv turn backlights down as low as possible as all TV's with led's are susceptible. A new tv may fail in a year or just out of warranty
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    I agree with dskall and vinceroger69.
                    The website was just to show you the led strips.
                    You can buy individual strips off ebay once you have the part numbers needed after lifting the lcd panel. It could just be that one strip has faulty leds so £15 to repair.
                    Or if there are more than 1 strip with faulty leds you can buy one replacement strip and use the leds from that strip to replace the faulty ones.
                    There is plenty of information on how to do it but you do need to take care when removing/replacing the panel.
                    You could get in touch with Flocko (on this site) and buy some stackable leds from him.
                    • sordids999
                      • May 2013
                      • 2158
                      • uk
                      #30
                      hi guys this tv im working on has no backlight
                      led + connector 104 volts steady
                      led _ connector 3.50 volts steady
                      main capacitor 322 volts
                      legend voltages seem ok but no 12v voltages on the tcon board fuse (swapped the tcon board with a working one still the same )
                      thanks
                      • attainteddragon
                        • Apr 2013
                        • 764
                        • australia
                        #31
                        pfc voltage looks low to me.
                        you could jump the ps without the main attached to check the ps and backlights to start with.
                        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                        • sordids999
                          • May 2013
                          • 2158
                          • uk
                          #32
                          ##UPDATE##
                          luckily had a replacement 42ln613v main board tv all working again and in test mode
                          • sordids999
                            • May 2013
                            • 2158
                            • uk
                            #33
                            no back light
                            legend P201 voltages seem ok
                            main caps 322 volts
                            LED + fluctuates to 210 volts then goes back to 230 volts always fluctuating
                            LED - fluctuates to 91 v then back upto 110 volts always flucutating
                            any ideas guys
                            • sordids999
                              • May 2013
                              • 2158
                              • uk
                              #34
                              Originally posted by sordids999
                              no back light
                              main caps 322 volts
                              any ideas guys
                              #UPDATE#
                              two shorted LEDS testing now
                              • sordids999
                                • May 2013
                                • 2158
                                • uk
                                #35
                                i recently repaired the led`s but i have now noticed in the top hand right corner there is a dark patch about 2 inches in size and it will flash from time to time
                                has anyone experienced this before ?
                                thanks
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #36
                                  probably another failing led
                                  • sordids999
                                    • May 2013
                                    • 2158
                                    • uk
                                    #37
                                    yes that what i was thinking ill strip it later then update
                                    thanks
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #38
                                      I have now been replacing all the leds in a tv when i have any too repair then turn the back lights down i know this takes more time but its also a risk removing the panel again then again to replace another led and the lcd tab bonds may get weaker too.
                                      • lysy
                                        • May 2018
                                        Hi
                                        trying to fix 42LN575s with no backlight but still can see picture with flashlight.
                                        Here are my voltage testing:
                                        When led unplugged (1 led+ 2 led- 3 led+ 4 led-):
                                        1 220-235V
                                        2 0V
                                        3 0V
                                        4 0V
                                        When led plugged:
                                        1 220-235V
                                        2 140-160V
                                        3 130–150V
                                        4 95-115V
                                        Cap 335V
                                        Would that still looks like bad led strip? even if pin 1 voltage is more than specs?
                                        thanks
                                        • zomi
                                          • Nov 2011
                                          • 509
                                          #40
                                          Have you had any back since doing this ?
                                          • Cornito
                                            Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                                            by Cornito
                                            Hello Team,
                                            I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                                            Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                                            Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                                            08-08-2024, 08:09 AM
                                          • cheebster
                                            iPad Pro 12.9 5th Gen Backlight Issue
                                            by cheebster
                                            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                            Anyone...
                                            05-20-2025, 09:17 AM
                                          • Cornito
                                            TCL 65C715 backlight issue
                                            by Cornito
                                            Hello team,
                                            I'm back with another topic.
                                            It's a 65C715 TCL tv with backlight issue.
                                            But the problem is a bit strange.
                                            When I took this tv from the marketplace backlight didn't work but picture was ok.
                                            Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                                            Putting all back together the tv worked fine for weeks. => Contact issue??
                                            Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                                            06-09-2024, 02:24 AM
                                          • Riananyaina
                                            MacBook A1708 820-00840-A backlight issue
                                            by Riananyaina
                                            Hello Everyone ,
                                            today I'm coming to you regarding my issue which is no Backlight .
                                            I have image on my screen but no light .
                                            The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                                            First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                                            Please find below few informations which can help for the analysis...
                                            04-24-2023, 05:03 AM
                                          • fuzzyrunner
                                            Samsung LN52B750U1FXZA - Backlight Issue
                                            by fuzzyrunner
                                            Hello All!
                                            So here is the issue I am having. When everything is plugged in as normal, the TV turns on and I get a quick flash of the backlight. After that the backlight never turns back on but the rest of the TV works fine. If I pull the PWM pin from the cable between the main board and power board the backlight turns on and the tv works "normally". If it is plugged in I get nothing. I did do a factory reset but that didn't solve my issue. When everything is plugged in normally I get .6v at start up and continues rise over about 10 seconds. (~.6v then ~.8v then ~1.8v...
                                            02-28-2024, 07:36 PM
