Eeprom dump thread!
This is a sticky topic.
  • cheeky2
    • Dec 2012
    • 338
    • uk
    #1901
    Originally posted by lotas
    Try this dump, but the panel is unknown.
    Thanks I will give it a go over the next few days and let you know the results
    • dinche_ze
      • Feb 2020
      • 19
      • Bosnia Hercegovina
      #1902
      hello friend
      I need spi flash for TESLA TV
      model: 43S306BF
      dont know matric number
      • lotas
        • Jan 2016
        • 4830
        • Russia
        #1903
        Originally posted by dinche_ze
        hello friend
        model: 43S306BF
        Don't you know the motherboard number either?
        • dinche_ze
          • Feb 2020
          • 19
          #1904
          • lotas
            • Jan 2016
            • 4830
            • Russia
            #1905
            Post here your original, non-working dump, I'll try to fix it.​
            • dinche_ze
              • Feb 2020
              • 19
              #1906
              problem is that remote control is not working, other things works fine.
              • lotas
                • Jan 2016
                • 4830
                • Russia
                #1907
                So what does the firmware have to do with it? If it doesn't work for you via the remote control, check the remote control, try via a universal remote control. If it doesn't work, replace the IR receiver, make sure the pulses reach the processor...
                • dinche_ze
                  • Feb 2020
                  • 19
                  #1908
                  probao sam, ispravan daljinski, nece ni univerzalni. a ir prijemnik sa 4 pina,( 2 gnd, na jednom stalnih 5V, a na drugom 5V koji opada na 3,5V kada koristim daljinski), nemam takav ir da bi testirao ,mada sumnjam da je do njeg jer reaguje
                  • cheeky2
                    • Dec 2012
                    • 338
                    • uk
                    #1909
                    Thanks Lotas it worked a treat
                    • lotas
                      • Jan 2016
                      • 4830
                      • Russia
                      #1910
                      Ok!
                      • dinche_ze
                        • Feb 2020
                        • 19
                        #1911
                        Pozdrav prijatelji,
                        imam Toshiba 32el933g TV. Samo crveno svjetlo svijetli, ne pali se ni ništa. Kada sam ažurirao firmware, otkrio sam da se TV uključuje, ali nema slike. Mislim da se matrica ne podudara. Moja matrica je LG. Za drugu ne znam. Objavit ću originalni firmware od TV-a i novi ako netko zna kako ih uskladiti.
                        • lotas
                          • Jan 2016
                          • 4830
                          • Russia
                          #1912
                          Pozdrav prijatelji,
                          Try.
                          • dinche_ze
                            • Feb 2020
                            • 19
                            #1913
                            Try.
                            it works.
                            than you very much
                            • lotas
                              • Jan 2016
                              • 4830
                              • Russia
                              #1914
                              it works.
                              than you very much
                              That's good.
                              • Salvatore Cancellieri
                                • May 2025
                                • 8
                                • Italia
                                #1915
                                Hi everyone, I have a 65" Philips TV, it turns on and after a while it restarts endlessly, I checked the power supply and everything is ok, I disconnected all the devices and the panel but it continues to restart, I assume it is a dump problem, below is the original dump
                                TV model 65PUS6523/12
                                Board model 703TQHPL433 715G8709-M0B-B01-005K​
                                • luzmina
                                  • May 2015
                                  • 17
                                  • US
                                  #1916
                                  Here is the dump for the Hisense 70H6570G and 70A6G. It fixed the corrupted EMMC issue that put the TV into a loop.
                                  Board RSAG7.820.9783/ROH
                                  https://drive.google.com/file/d/129h...usp=drive_link
                                  • digitel
                                    • Apr 2013
                                    • 9
                                    • Alicante
                                    #1917
                                    Please, do you have the firmware for a Hitachi 43HAE4251 TV, with Mainboard 17MB171 and Panel VES430UNDH-N2-N45? The memory is not SPI Flash. It's EMMc. Thank you.
                                    • sordids999
                                      • May 2013
                                      • 2161
                                      • uk
                                      #1918
                                      Hi does anyone have the firmware for a Panasonic 50lx650 main board 17mb185
                                      Screen ves500qnzh-n2-z01
                                      23798312
                                      • digitel
                                        • Apr 2013
                                        • 9
                                        • Alicante
                                        #1919
                                        Hitachi 43HAE4251 firmware
                                        Please, do you have the firmware for a Hitachi 43HAE4251 TV, with Mainboard 17MB171 and Panel VES430UNDH-N2-N45 The memory is not SPI Flash. It's EMMc. Thank you.
                                        • kamaku
                                          • Jul 2014
                                          • 6
                                          • Spain
                                          #1920
                                          Hi does anyone have the usb firmware or emmc dump for a Cecotec ALH30032S main: TPD.RT2841A.PB782
